TPS3000-48
TPS3000-48
    TDK(东电化)
    TPS3000-48
TPS3000-48 数据手册
TPS3000 Series https://product.tdk.com/en/power/tps www.emea.lambda.tdk.com/tps 3200W 3-Phase Input Industrial Power Supplies The TPS3000 series industrial AC-DC power supplies offer output power up to 3,200W in a 2U high package with 3 phase supply input. Features include voltage and current programming, remote on/off, remote sense, a standby supply, PMBusTM communication, built in ORing FET and wide operating temperature range of -40°C to +70°C. The TPS3000 is also designed to meet MIL-STD-810F vibration and shock. Features Benefits • 400/440/480Vac (Nominal) 3 Phase Delta or Wye • Global Use • Fully Regulated, Wide Range Voltage Adjustment • Versatile Application • Voltage and Current Programming • Flexible Control and Adjustment • -40°C (start up) to +70°C Operation • Suitable for Rugged Environments • 92% Typical Efficiency • Less Energy Used • PMBus Communication • Remote Output Programming and Monitoring • Built in ORing FET for Parallel Operation • Suitable for N + 1 Redundancy TM Model Selector Model TPS3000-24 TPS3000-48 Nominal Output Adjustment Maximum Maximum Max Voltage (V) Range (V) (1) Current (A) Power (W) Current (A) (2) 24 19.2 - 28.5 125 3000 133.3 48 38.4 - 56.5 66.7 3200 66.7 Maximum Power (W) (2) 3200 3200 *Wider range adjustment as stated on the UL safety files are possible, although some parameters might not meet some of the listed specifications. Related Products Type EMC filter Part Number Description RTMN-5020 High attenuation 20A 500Vac 3-phase input two stage filter Specifications Model Input Input Voltage range Input Frequency Input Current (At nominal Vin) Inrush Current at 400-480Vac (Cold Start) Dropped Phase Power Leakage Current Power Factor (400-480Vac) Harmonics Hold Up Time (typ) Efficiency (Typical) Conducted & Radiated EMI Safety Certifications and Markings Voltage Dips Vac Hz A A W mA - - ms % - - - TPF3000 350 - 528, Delta or Wye 3 phase (Note: Safety certified for 400-480Vac only) 47 - 63 (Note: Safety certified for 50 to 60Hz only) 6 per phase (steady state) 95%. TPS3000 Series Specifications Model TPS3000 Output Line Regulation %
TPS3000-48 价格&库存
很抱歉,暂时无法提供与“TPS3000-48”相匹配的价格&库存,您可以联系我们找货
