TPX205950MT-7036A1
TPX205950MT-7036A1
    TDK(东电化)
    SMD-8P,1.2x2mm
    MULTILAYER HIGH PASS FILTER FOR
TPX205950MT-7036A1 数据手册
The products in this catalog are not recommended for new design R F C o m p o n e n t s November 2018 Multilayer Triplexer For 1559-1606MHz / 2400-2500MHz / 4900-5950MHz TPX205950MT-7036A1 2.0x1.25mm [EIA 0805]* * Dimensions Code JIS[EIA] The products in this catalog are not recommended for new design RF Components Multilayer Triplexer Conformity to RoHS Directive For 1559-1606MHz / 2400-2500MHz / 4900-5950MHz TPX205950MT-7036A1 SHAPES AND DIMENSIONS [Top view] 0.60max. 2.00±0.15 (7) (6) (5) (1) (2) (3) (4) Marking 0.30±0.05 0.20±0.05 (1) (2) (3) (4) (8) (7) (6) (5) 0.10±0.10 0.20±0.05 [Bottom view] 0.25±0.05 0.275±0.10 1.25±0.15 (8) Terminal functions 1 GND 2 Common Port 3 GND 4 Low-Band Port 5 GND 6 Middle-Band Port 7 GND 8 High-Band Port Dimensions in mm RECOMMENDED LAND PATTERN EVALUATION BOARD 0.30 0.20 0.25 Mid-Band High-Band Low-Band 0.20 Dimensions in mm Resist Common Material, Layer Top resist Copper surface pattern FR4 Copper inner GND FR4 Copper bottom GND Thru Hole Thickness Resist 0.035mm 0.100mm 0.018mm 0.300mm 0.035mm Line width should be designed to match 50Ω characteristic impedance, depending on PCB material and thickness. RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20181101 / rf_tpx_tpx205950mt-7036a1_en.fm The products in this catalog are not recommended for new design RF Components TPX205950MT-7036A1 ELECTRICAL CHARACTERISTICS LOW-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Frequency Range (MHz) Min. Typ. Max. 1559 to 1606 1559 to 1606 1559 to 1606 2400 to 2500 4900 to 5950 — — 10 19 28 0.58 — 22 23 32 50 (Nominal) 0.70 0.90 (–40 to +85°C) — — — Frequency Range (MHz) Min. Typ. Max. 2400 to 2500 2400 to 2500 2400 to 2500 1560 to 1606 4800 to 5000 7200 to 7500 — — 10 25 25 15 1.09 — 16 28 29 25 50 (Nominal) 1.25 1.45 (–40 to +85°C) — — — — Frequency Range (MHz) Min. Typ. Max. 4900 to 5100 5150 to 5950 4900 to 5100 5150 to 5950 4900 to 5100 5150 to 5950 1560 to 1606 3400 to 3600 3600 to 3800 6900 to 7200 7200 to 7800 10300 to 11700 15300 to 16200 — — — — 10 9 25 30 30 10 13 21 15 1.03 1.14 — — 15 13 44 44 42 15 15 24 25 50 (Nominal) 1.50 1.50 1.70 (–40 to +85°C) 1.70 (–40 to +85°C) — — — — — — — — — Characteristic Impedance () ・Ta: +25±5°C MIDDLE-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Characteristic Impedance () ・Ta: +25±5°C HIGH-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Characteristic Impedance () ・Ta: +25±5°C • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20181101 / rf_tpx_tpx205950mt-7036a1_en.fm The products in this catalog are not recommended for new design RF Components TPX205950MT-7036A1 ELECTRICAL CHARACTERISTICS COMMON Frequency Range (MHz) Item Low to Middle Isolation (dB) Middle to High Low to High 1560 to 1606 2400 to 2500 2400 to 2500 4900 to 5950 1560 to 1606 4900 to 5950 Power Handling (W) Characteristic Impedance () Min. Typ. Max. 25 19 30 20 25 28 — 31 27 35 27 43 35 — 50 (Nominal) — — — — — — 0.5 ・Ta: +25±5°C TEMPERATURE RANGE Operating temperature (°C) –40 to +85 Storage temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20181101 / rf_tpx_tpx205950mt-7036a1_en.fm The products in this catalog are not recommended for new design RF Components TPX205950MT-7036A1 FREQUENCY CHARACTERISTICS MIDDLE-BAND Insertion Loss 0.0 0.0 0.5 0.5 1.0 1.0 Insertion Loss(dB) Insertion Loss(dB) LOW-BAND Insertion Loss 1.5 2.0 2.0 2.5 2.5 3.0 1000 1200 1400 1600 1800 Frequency (MHz) 2000 2200 3.0 2000 2400 0 10 10 Return Loss(dB) 0 20 30 40 2800 3000 2200 2400 2600 Frequency (MHz) 2800 3000 20 30 1200 1400 1600 1800 Frequency (MHz) 2000 2200 50 2000 2400 Attenuation 0 0 10 10 Attenuation(dB) Attenuation Attenuation(dB) 2400 2600 Frequency (MHz) 40 50 1000 20 30 20 30 40 40 50 2200 Return Loss Return Loss Return Loss(dB) 1.5 50 0 1000 2000 3000 4000 5000 Frequency (MHz) 6000 7000 8000 0 1000 2000 3000 4000 5000 Frequency (MHz) 6000 7000 8000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20181101 / rf_tpx_tpx205950mt-7036a1_en.fm The products in this catalog are not recommended for new design RF Components TPX205950MT-7036A1 FREQUENCY CHARACTERISTICS HIGH-BAND Insertion Loss 0.0 Insertion Loss(dB) 0.5 1.0 1.5 2.0 2.5 3.0 4000 4500 5000 5500 Frequency (MHz) 6000 6500 7000 4500 5000 5500 Frequency (MHz) 6000 6500 7000 6000 8000 10000 12000 Frequency (MHz) Return Loss 0 Return Loss(dB) 10 20 30 40 50 4000 Attenuation 0 Attenuation(dB) 10 20 30 40 50 0 2000 4000 14000 16000 18000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20181101 / rf_tpx_tpx205950mt-7036a1_en.fm The products in this catalog are not recommended for new design RF Components TPX205950MT-7036A1 FREQUENCY CHARACTERISTICS Isolation (Low-Mid) 0 0 10 10 Isolation (Low-Mid) (dB) Return Loss(dB) COMMON Return Loss 20 30 30 40 40 50 20 50 0 1000 2000 3000 4000 5000 Frequency (MHz) 6000 7000 8000 0 1000 2000 3000 4000 5000 Frequency (MHz) 6000 7000 8000 3000 4000 5000 Frequency (MHz) 6000 7000 8000 3000 4000 5000 Frequency (MHz) 6000 7000 8000 Isolation (Low-High) 0 Isolation (Low-High) (dB) 10 20 30 40 50 0 1000 2000 Isolation (Mid-High) 0 Isolation (Mid-High) (dB) 10 20 30 40 50 0 1000 2000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20181101 / rf_tpx_tpx205950mt-7036a1_en.fm The products in this catalog are not recommended for new design RF Components TPX205950MT-7036A1 RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 150°C T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec Peak Temp. T4 240 to 260°C Time t3 30sec max. t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20181101 / rf_tpx_tpx205950mt-7036a1_en.fm The products in this catalog are not recommended for new design RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20181101 / rf_tpx_tpx205950mt-7036a1_en.fm
TPX205950MT-7036A1 价格&库存
很抱歉,暂时无法提供与“TPX205950MT-7036A1”相匹配的价格&库存,您可以联系我们找货
TPX205950MT-7036A1
  • 1+3.703951+0.46351
  • 10+3.0272110+0.37883
  • 25+2.7928025+0.34949
  • 50+2.6252250+0.32852
  • 100+2.46895100+0.30897
  • 250+2.27664250+0.28490
  • 500+2.14142500+0.26798
  • 1000+2.014321000+0.25207
库存:1940
