TPX252690MT-7029A1
TPX252690MT-7029A1
    TDK(东电化)
    多层三工器,适用于698 - 960MHZ/1452 - 2170MHZ/2496 - 5850MHZ
TPX252690MT-7029A1 数据手册
R F C o m p o n e n t s February 2019 Multilayer Triplexer For 698-960MHz / 1452-2170MHz / 2496-5850MHz TPX252690MT-7029A1 2.5x2.0mm [EIA 1008]* * Dimensions Code JIS[EIA] RF Components Multilayer Triplexer Conformity to RoHS Directive For 698-960MHz / 1452-2170MHz / 2496-5850MHz TPX252690MT-7029A1 SHAPES AND DIMENSIONS 2.50±0.10 0.90±0.10 2.00±0.10 [Top view] 0.90±0.10 1 2 3 8 9 4 7 6 5 0.10±0.10 0.55±0.10 0.30±0.10 0.40±0.10 [Bottom view] 0.10±0.10 Marking 0.40±0.10 Terminal functions 1 High-Band Port 2 GND 3 Middle-Band Port 4 GND 5 Low-Band Port 6 GND 7 Common Port 8 GND 9 GND Dimensions in mm RECOMMENDED LAND PATTERN 0.30 0.55 0.40 0.40 0.30 0.40 0.90 Dimensions in mm RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190214 / rf_tpx_tpx252690mt-7029a1_en.fm RF Components TPX252690MT-7029A1 ELECTRICAL CHARACTERISTICS LOW-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Isolation (dB) -Mid -Mid -High Power Handling (W) Characteristic Impedance () Frequency Range (MHz) Min. Typ. Max. 698 to 960 698 to 960 698 to 960 1452 to 1496 1565 to 1606 1710 to 2170 2496 to 2690 3400 to 3800 4900 to 5850 1452 to 1496 1710 to 2170 2496 to 2690 698 to 960 — — 9.54 12 15 20 20 20 20 10 18 25 — 0.43 0.53 15.6 14 18 22 31 43 35 14 22 35 — 50 (Nominal) 0.70 0.85 (–40 to +85°C) — — — — — — — — — — 1.5 Frequency Range (MHz) Min. Typ. Max. 1452 to 1496 1710 to 2170 1452 to 1496 1710 to 2170 1452 to 1496 1710 to 2170 698 to 960 2496 to 2690 3400 to 3800 4900 to 5850 698 to 960 2496 to 2690 1452 to 1496 1710 to 2170 — — — — 6.49 9.54 23 18 20 20 25 18 — — 1.66 1.16 1.79 1.34 8.6 22.6 27 22 23 27 28 21 — — 50 (Nominal) 2.30 1.50 2.50 (–40 to +85°C) 1.70 (–40 to +85°C) — — — — — — — — 1.0 1.0 ・Ta: +25±5°C MIDDLE-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Isolation (dB) -Low -High Power Handling (W) Characteristic Impedance () ・Ta: +25±5°C • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190214 / rf_tpx_tpx252690mt-7029a1_en.fm RF Components TPX252690MT-7029A1 ELECTRICAL CHARACTERISTICS HIGH-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Isolation (dB) -Low -Mid -Mid Power Handling (W) Frequency Range (MHz) Min. Typ. Max. 2496 to 2690 3400 to 3800 4900 to 5850 2496 to 2690 3400 to 3800 4900 to 5850 2496 to 2690 3400 to 3800 4900 to 5850 698 to 960 1452 to 1496 1710 to 2170 698 to 960 1452 to 1496 1710 to 2170 2496 to 2690 3400 to 3800 4900 to 5850 — — — — — — 9.54 7.71 9.54 23 30 20 20 28 18 — — — 1.40 0.82 0.16 1.51 0.89 0.22 11.3 9.2 15.6 26 39 25 25 32 22 — — — 50 (Nominal) 1.84 1.20 0.50 2.04 (–40 to +85°C) 1.40 (–40 to +85°C) 0.70 (–40 to +85°C) — — — — — — — — — 1.0 1.0 2.0 Characteristic Impedance () ・Ta: +25±5°C TEMPERATURE RANGE Operating temperature (°C) –40 to +85 Storage temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190214 / rf_tpx_tpx252690mt-7029a1_en.fm RF Components TPX252690MT-7029A1 FREQUENCY CHARACTERISTICS MIDDLE-BAND Insertion Loss 0.0 0.0 0.5 0.5 1.0 1.0 Insertion Loss(dB) Insertion Loss(dB) LOW-BAND Insertion Loss 1.5 2.0 600 700 800 900 1000 Frequency (MHz) 1100 1200 1300 3.0 1200 1400 0 10 10 Return Loss(dB) 0 20 30 40 50 500 1400 2200 2400 2600 1600 1800 2000 Frequency (MHz) 2200 2400 2600 2000 3000 4000 Frequency (MHz) 30 40 600 700 800 900 1000 Frequency (MHz) 1100 1200 1300 50 1200 1400 1400 0 0 10 10 Attenuation(dB) Attenuation Attenuation(dB) 1800 2000 Frequency (MHz) 20 Attenuation 20 30 20 30 40 40 50 1600 Return Loss Return Loss Return Loss(dB) 2.0 2.5 2.5 3.0 500 1.5 50 1000 2000 3000 4000 Frequency (MHz) 5000 6000 1000 5000 6000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190214 / rf_tpx_tpx252690mt-7029a1_en.fm RF Components TPX252690MT-7029A1 FREQUENCY CHARACTERISTICS HIGH-BAND Insertion Loss 0.0 Insertion Loss(dB) 0.5 1.0 1.5 2.0 2.5 3.0 2000 2500 3000 3500 4000 4500 Frequency (MHz) 5000 5500 6000 3000 3500 4000 4500 Frequency (MHz) 5000 5500 6000 Return Loss 0 Return Loss(dB) 10 20 30 40 50 2000 2500 Attenuation 0 Attenuation(dB) 10 20 30 40 50 1000 2000 3000 4000 Frequency (MHz) 5000 6000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190214 / rf_tpx_tpx252690mt-7029a1_en.fm RF Components TPX252690MT-7029A1 FREQUENCY CHARACTERISTICS Isolation (Low-Mid) 0 0 10 10 Isolation (Low-Mid) (dB) Return Loss(dB) COMMON Return Loss 20 30 30 40 40 50 20 50 1000 2000 3000 4000 Frequency (MHz) 5000 6000 1000 2000 3000 4000 Frequency (MHz) 5000 6000 3000 4000 Frequency (MHz) 5000 6000 3000 4000 Frequency (MHz) 5000 6000 Isolation (Low-High) 0 Isolation (Low-High) (dB) 10 20 30 40 50 1000 2000 Isolation (Mid-High) 0 Isolation (Mid-High) (dB) 10 20 30 40 50 1000 2000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190214 / rf_tpx_tpx252690mt-7029a1_en.fm RF Components TPX252690MT-7029A1 RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 150°C T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec Peak Temp. T4 240 to 260°C Time t3 30sec max. t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190214 / rf_tpx_tpx252690mt-7029a1_en.fm RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190214 / rf_tpx_tpx252690mt-7029a1_en.fm
TPX252690MT-7029A1 价格&库存
很抱歉,暂时无法提供与“TPX252690MT-7029A1”相匹配的价格&库存,您可以联系我们找货
TPX252690MT-7029A1
  • 1+0.74910
  • 2000+0.69080
库存:1852
TPX252690MT-7029A1
    • 5+1.44245
    • 50+1.12385
    • 150+0.98723
    • 500+0.81692
    库存:1439
    TPX252690MT-7029A1
      • 100+0.95140
      库存:1830
      TPX252690MT-7029A1
        • 1+1.267971+0.16425
        • 300+0.98620300+0.12775
        • 500+0.91161500+0.11809
        • 1000+0.861891000+0.11165
        • 4000+0.820454000+0.10628
        • 5000+0.820455000+0.10628
        • 10000+0.8121610000+0.10521
        库存:166000
