TPX253600MT-7019B2
TPX253600MT-7019B2
    TDK(东电化)
    TPX253600MT-7019B2
TPX253600MT-7019B2 数据手册
The products in this catalog are not recommended for new design R F C o m p o n e n t s March 2019 Multilayer Triplexer For 698-960MHz / 1427-2170MHz / 2500-3600MHz TPX253600MT-7019B2 2.5x2.0mm [EIA 1008]* * Dimensions Code JIS[EIA] The products in this catalog are not recommended for new design RF Components Multilayer Triplexer Conformity to RoHS Directive For 698-960MHz / 1427-2170MHz / 2500-3600MHz TPX253600MT-7019B2 SHAPES AND DIMENSIONS 2.50±0.10 0.90±0.10 2.00±0.10 [Top view] 0.90±0.10 1 2 3 8 9 4 7 6 5 0.10±0.10 0.55±0.10 0.30±0.10 0.40±0.10 [Bottom view] 0.10±0.10 Marking 0.40±0.10 Terminal functions 1 High-Band Port 2 GND 3 Middle-Band Port 4 GND 5 Low-Band Port 6 GND 7 Common Port 8 GND 9 GND Dimensions in mm RECOMMENDED LAND PATTERN 0.30 0.55 0.40 0.40 0.30 0.40 0.90 Dimensions in mm RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190312 / rf_tpx_tpx253600mt-7019b2_en.fm The products in this catalog are not recommended for new design RF Components TPX253600MT-7019B2 ELECTRICAL CHARACTERISTICS LOW-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Frequency Range (MHz) Min. Typ. Max. 698 to 960 698 to 803 803 to 960 1427 to 1511 1710 to 2170 2500 to 2690 3400 to 3600 — 14 14 7 12 27 35 0.50 17.0 20.7 10.7 15.3 32.2 51.3 50 (Nominal) 0.70 — — — — — — Frequency Range (MHz) Min. Typ. Max. 1427 to 1511 1710 to 2170 1427 to 1511 1710 to 2170 698 to 960 2500 to 2690 3400 to 3600 — — 14 14 14 10 15 0.98 0.83 20.5 16.4 18.2 15.4 19.2 50 (Nominal) 1.20 1.20 — — — — — Frequency Range (MHz) Min. Typ. Max. 2500 to 2690 3400 to 3600 2500 to 2690 3400 to 3600 698 to 960 1427 to 1511 1710 to 2170 — — 14 14 18 16 15 1.22 0.29 17.7 18.3 20.3 18.9 21.7 50 (Nominal) 1.50 0.60 — — — — — Characteristic Impedance () ・Ta: +25±5°C MIDDLE-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Characteristic Impedance () ・Ta: +25±5°C HIGH-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Characteristic Impedance () ・Ta: +25±5°C • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190312 / rf_tpx_tpx253600mt-7019b2_en.fm The products in this catalog are not recommended for new design RF Components TPX253600MT-7019B2 ELECTRICAL CHARACTERISTICS COMMON Item Low to Middle Isolation (dB) Low to High Middle to High Frequency Range (MHz) Min. Typ. Max. 698 to 960 1427 to 1511 1710 to 2170 698 to 960 2500 to 2690 3400 to 3600 1427 to 1511 1710 to 2170 2500 to 2690 3400 to 3600 14 7 13 15 30 30 15 15 13 15 17.4 10.4 16.5 19.6 37.6 38.7 19.4 20.0 16.7 19.5 50 (Nominal) — — — — — — — — — — Characteristic Impedance () ・Ta: +25±5°C TEMPERATURE RANGE Operating temperature (°C) –40 to +85 Storage temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190312 / rf_tpx_tpx253600mt-7019b2_en.fm The products in this catalog are not recommended for new design RF Components TPX253600MT-7019B2 FREQUENCY CHARACTERISTICS MIDDLE-BAND Insertion Loss 0.0 0.0 0.5 0.5 1.0 1.0 Insertion Loss(dB) Insertion Loss(dB) LOW-BAND Insertion Loss 1.5 2.0 2.0 2.5 2.5 3.0 500 600 700 800 900 Frequency (MHz) 1000 1100 3.0 1000 1200 1200 1400 1600 1800 Frequency (MHz) 2000 2200 2400 1400 1600 1800 Frequency (MHz) 2000 2200 2400 Return Loss Return Loss 0 0 10 10 Return Loss(dB) Return Loss(dB) 1.5 20 30 40 20 30 40 50 500 600 700 800 900 Frequency (MHz) 1000 1100 50 1000 1200 Attenuation Attenuation 0 0 10 1200 10 Attenuation(dB) Attenuation(dB) 20 30 40 20 30 40 50 60 50 0 500 1000 1500 2000 2500 Frequency (MHz) 3000 3500 4000 0 500 1000 1500 2000 2500 Frequency (MHz) 3000 3500 4000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190312 / rf_tpx_tpx253600mt-7019b2_en.fm The products in this catalog are not recommended for new design RF Components TPX253600MT-7019B2 FREQUENCY CHARACTERISTICS HIGH-BAND Insertion Loss 0.0 Insertion Loss(dB) 0.5 1.0 1.5 2.0 2.5 3.0 2000 2500 3000 Frequency (MHz) 3500 4000 2500 3000 Frequency (MHz) 3500 4000 1000 1500 2000 2500 Frequency (MHz) 3000 Return Loss 0 Return Loss(dB) 10 20 30 40 50 2000 Attenuation 0 Attenuation(dB) 10 20 30 40 50 0 500 3500 4000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190312 / rf_tpx_tpx253600mt-7019b2_en.fm The products in this catalog are not recommended for new design RF Components TPX253600MT-7019B2 FREQUENCY CHARACTERISTICS Isolation (Low-Mid) 0 0 10 10 Isolation (Low-Mid) (dB) Return Loss(dB) COMMON Return Loss 20 30 30 40 40 50 20 50 0 500 1000 1500 2000 2500 Frequency (MHz) 3000 3500 4000 0 500 1000 1500 2000 2500 Frequency (MHz) 3000 3500 4000 1500 2000 2500 Frequency (MHz) 3000 3500 4000 1500 2000 2500 Frequency (MHz) 3000 3500 4000 Isolation (Low-High) 0 Isolation (Low-High) (dB) 10 20 30 40 50 0 500 1000 Isolation (Mid-High) 0 Isolation (Mid-High) (dB) 10 20 30 40 50 0 500 1000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190312 / rf_tpx_tpx253600mt-7019b2_en.fm The products in this catalog are not recommended for new design RF Components TPX253600MT-7019B2 RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 150°C T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec Peak Temp. T4 240 to 260°C Time t3 30sec max. t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190312 / rf_tpx_tpx253600mt-7019b2_en.fm The products in this catalog are not recommended for new design RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190312 / rf_tpx_tpx253600mt-7019b2_en.fm
TPX253600MT-7019B2 价格&库存
很抱歉,暂时无法提供与“TPX253600MT-7019B2”相匹配的价格&库存,您可以联系我们找货
TPX253600MT-7019B2
  • 1+4.497681+0.58299
  • 10+3.6663610+0.47523
  • 25+3.3773125+0.43777
  • 50+3.1748150+0.41152
  • 100+2.98521100+0.38694
  • 250+2.75305250+0.35685
  • 500+2.58947500+0.33565
  • 1000+2.435761000+0.31572
库存:2000
TPX253600MT-7019B2
  • 1+4.498151+0.58305
  • 10+3.6667410+0.47528
  • 25+3.3776625+0.43781
  • 50+3.1751450+0.41156
  • 100+2.98551100+0.38698
  • 250+2.75334250+0.35689
  • 500+2.58974500+0.33568
  • 1000+2.436021000+0.31576
库存:2000
