TPX255000MT-7019B6
TPX255000MT-7019B6
    TDK(东电化)
    三工器 UMTS/LTE/5G 插入损耗:0.7dB 1008
TPX255000MT-7019B6 数据手册
1 of 5 Creation Date : September 21, 2023 (GMT) 三工器 TPX255000MT-7019B6 UMTS 应用 LTE 5G 蜂窝网络频带 Band 1/2/3/4/5/6/7/8/9/10/11/12/13/14/17/18/19/20/21/22/23/25/26/27/28/29/32/33/34/35/36/37/38/39/41/42/43/44/45/48/49/51/52/65/66/67/68/69/70/74/76/77/78/79/80/81/82/83/84/85/86 使用 一般等级 系列 TPX25 状态 品牌 量产体制 TDK 尺寸 长度(L) 2.50mm ±0.10mm 宽度(W) 2.00mm ±0.10mm 厚度(T) 0.90mm ±0.10mm 电气特性 ----- 低频带 ----开始/停止频率 698~960MHz 插入损耗 [Max.] 0.7dB 7dB at 1427~1511MHz 12dB at 1710~2170MHz 衰减量 [Min.] 27dB at 2500~2690MHz 35dB at 3400~3600MHz 35dB at 3300~4200MHz 35dB at 3300~3800MHz 反射损失 [Min.] 14dB ----- 中频带 ----开始/停止频率 1427~2170MHz 插入损耗 [Max.] 1.2dB 14dB at 698~960MHz 10dB at 2500~2690MHz 衰减量 [Min.] 15dB at 3400~3600MHz 15dB at 3300~4200MHz 15dB at 3300~3800MHz 15dB at 4400~5000MHz 反射损失 [Min.] 14dB ----- 高频带 ----开始/停止频率 2496~5000MHz 插入损耗 [Max.] 1.5dB 18dB at 698~960MHz 衰减量 [Min.] 16dB at 1427~1511MHz 15dB at 1710~2170MHz ! Images are for reference only and show exemplary products. ! This PDF document was created based on the data listed on the TDK Corporation website. ! All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved. 2 of 5 Creation Date : September 21, 2023 (GMT) 三工器 TPX255000MT-7019B6 反射损失 [Min.] 10dB 其他详细信息 请参照目录/规格书 其他 使用温度范围 -40~85°C AEC-Q200 NO 包装形式 塑封编带 (180mm卷筒、帯宽 8mm) 包装个数 2000pcs 重量 0.0142g 端子形状 LGA 端子数量 9 其他详细信息 请参照目录/规格书 ! Images are for reference only and show exemplary products. ! This PDF document was created based on the data listed on the TDK Corporation website. ! All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved. 3 of 5 Creation Date : September 21, 2023 (GMT) 三工器 TPX255000MT-7019B6 特性图表(这是参考数据,并不保证产品的特性。) 插入损耗 (Low Band) TPX255000MT-7019B6 衰减量 (Low Band) TPX255000MT-7019B6 插入损耗 (Middle Band) TPX255000MT-7019B6 衰减量 (Middle Band) TPX255000MT-7019B6 插入损耗 (High Band) TPX255000MT-7019B6 衰减量 (High Band) TPX255000MT-7019B6 ! Images are for reference only and show exemplary products. ! This PDF document was created based on the data listed on the TDK Corporation website. ! All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved. 4 of 5 Creation Date : September 21, 2023 (GMT) 三工器 TPX255000MT-7019B6 特性图表(这是参考数据,并不保证产品的特性。) 反射损失 (Low Band) Smith Chart (Low Band) TPX255000MT-7019B6 TPX255000MT-7019B6 反射损失 (Middle Band) Smith Chart (Middle Band) TPX255000MT-7019B6 TPX255000MT-7019B6 反射损失 (High Band) Smith Chart (High Band) TPX255000MT-7019B6 TPX255000MT-7019B6 ! Images are for reference only and show exemplary products. ! This PDF document was created based on the data listed on the TDK Corporation website. ! All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved. 5 of 5 Creation Date : September 21, 2023 (GMT) 三工器 TPX255000MT-7019B6 特性图表(这是参考数据,并不保证产品的特性。) 反射损失 (Common) Smith Chart (Common) TPX255000MT-7019B6 TPX255000MT-7019B6 Isolation (Low-High) TPX255000MT-7019B6 Isolation (Low-Middle) TPX255000MT-7019B6 Isolation (Middle-High) TPX255000MT-7019B6 ! Images are for reference only and show exemplary products. ! This PDF document was created based on the data listed on the TDK Corporation website. ! All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved.
TPX255000MT-7019B6 价格&库存
很抱歉,暂时无法提供与“TPX255000MT-7019B6”相匹配的价格&库存,您可以联系我们找货
TPX255000MT-7019B6
  • 1+3.440561+0.44652
  • 10+2.7748110+0.36012
  • 25+2.5615625+0.33245
  • 50+2.4064750+0.31232
  • 100+2.26289100+0.29368
  • 250+2.08692250+0.27085
  • 500+1.96291500+0.25475
  • 1000+1.846371000+0.23963
库存:3844
TPX255000MT-7019B6
  • 2000+1.687212000+0.21897
  • 4000+1.587134000+0.20598
  • 6000+1.531356000+0.19874
  • 10000+1.4638510000+0.18998
  • 14000+1.4210114000+0.18442
  • 20000+1.3769520000+0.17871
库存:3844
TPX255000MT-7019B6
库存:100020
TPX255000MT-7019B6
    • 1+0.79445
    • 200+0.31709
    • 500+0.30640
    • 1000+0.30122
