TPX255000MT-7090A1
TPX255000MT-7090A1
    TDK(东电化)
    射频双工器 三工器 617MHz ~ 960MHz / 3.3GHz ~ 5GHz 1008(2520 公制),9 PC 板
TPX255000MT-7090A1 数据手册
May. 2021 Ver.1.3a TDK Corporation   Multilayer Triplexer For 617-960 / 1447.9-2690 / 3300-5000 MHz TPX Series P/N: 2.5x2.0mm [EIA 1008] TYPE TPX255000MT-7090A1 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.1.3a TDK Corporation   TPX255000MT-7090A1 ■ SHAPES AND DIMENSIONS [Bottom View] [Top View] (7) (6) (5) (5) (6) (7) (8) (9) (4) (4) (9) (8) (1) (2) (3) (3) (2) (1) Dimensions (mm) L W T a b c d e f g h 2.50 2.00 0.75 0.40 0.55 0.95 0.40 0.30 0.70 0.80 0.90 +/-0.15 +/-0.15 Max +/-0.10 +/-0.10 +/-0.15 +/-0.10 +/-0.10 +/-0.15 +/-0.15 +/-0.15 Terminal functions High-Band Port (1) GND (2) Middle-Band Port (3) GND (4) Low-Band Port (5) (6) (7) (8) (9) GND Common Port GND GND ■ TERMINATION FINISH Material Ag All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.1.3a TDK Corporation   TPX255000MT-7090A1 ■ ELECTRICAL CHARACTERISTICS ( Measurement ) Low-Band Parameter Insertion Loss (dB) Insertion Loss (dB) ( –40 to +85 °C ) Return Loss@Common (dB) Return Loss@Low-Band (dB) Attenuation (dB) Characteristic Impedance (ohm) Ta = +25+/-5°C TDK Spec Min. Typ. Max. 960 0.50 0.65 Frequency (MHz) 617 to to 617 to 960 to 617 to 960 to 617 to 960 to 1164 to 1189 1447.9 to 1700 1700 to 2200 2200 to 6000 6000 to 9000 9000 to 12750 to - - 0.72 12 16.2 - 12 15.7 - 1 18 25 25 28 15 2.2 25.3 30.4 28.5 34.7 22.3 - 50 (Nominal) All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.1.3a TDK Corporation   TPX255000MT-7090A1 ■ ELECTRICAL CHARACTERISTICS ( Measurement ) Middle-Band Parameter Insertion Loss (dB) 1447.9 Insertion Loss (dB) ( –40 to +85 °C ) Return Loss@Common (dB) 1447.9 Return Loss@Middle-Band (dB) 1447.9 Attenuation (dB) Characteristic Impedance (ohm) Ta = +25+/-5°C TDK Spec Min. Typ. Max. 2690 0.71 0.85 Frequency (MHz) 1447.9 0 1164 3300 3500 6000 9000 to to to 2690 to to 2690 to to 2690 to to 960 to 1189 to 3500 to 6000 to 9000 to 12750 to 12 - 0.97 19.0 - 12 19.9 - 23 3 18 19 12 12 25.8 7.2 23.8 22.2 20.0 18.5 - 50 (Nominal) All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.1.3a TDK Corporation   TPX255000MT-7090A1 ■ ELECTRICAL CHARACTERISTICS ( Measurement ) High-Band Parameter TDK Spec Min. Typ. Max. 5000 0.93 1.30 Frequency (MHz) Insertion Loss (dB) 3300 to to Insertion Loss (dB) 3300 to 5000 1.50 ( –40 to +85 °C ) to Return Loss@Common (dB) 3300 to 5000 10 19.4 to Return Loss@High-Band (dB) 3300 to 5000 10 17.9 to Attenuation (dB) 0 to 1000 22 24.9 1164 to 1189 21 23.9 1447.9 to 2690 18 22.0 5100 0.5 1.0 6000 to 9000 15 21.9 9000 to 12750 15 21.5 to 50 (Nominal) Characteristic Impedance (ohm) Ta = +25+/-5°C Isolation Parameter Isolation (dB) LB - MB 617 to to to 617 to 3300 to to 1447.9 to 3300 to to 1447.9 LB - HB MB - HB TDK Spec Min. Typ. Max. 960 23 25.8 2690 18 24.6 - Frequency (MHz) 960 5000 22 30 25.2 44.5 - 2690 5000 18 18 22.0 22.2 - Ta = +25+/-5°C All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.1.3a TDK Corporation   TPX255000MT-7090A1 ■ MAXIMUM RATINGS Parameter Operating temperature (°C) Storage temperature (°C) Power Handling (W) *1 Low-Band Middle-Band High-Band Human Body Model : HBM Machine Model : MM Charged Device Model : CDM TDK Spec Conditions –40 to +85 °C –40 to +85 °C Frequency (MHz) CW 1 Duty 100% 617 to 960 CW 1447.9 to 2690 1 Duty 100% CW 1 Duty 100% 3300 to 5000 @Each Port (V) +/-1000 100pF / 1500ohm +/-150 200pF / 0ohm @Each Port (V) +/-500 Humidity : 60%RH max @Each Port (V) *1 : Refer to 3GPP TS 38.101-1 V15.2.0 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.1.3a TDK Corporation   TPX255000MT-7090A1 ■ FREQUENCY CHARACTERISTICS S21 Attenuation ― TDK SPEC S21 Insertion Loss Attenuation 1164 1189 1447.9 1700 2200 6000 9000 12750 5 Attenuation[dB] 10 15 20 25 MHz MHz MHz MHz MHz MHz MHz MHz Attenuation 2.2 2.7 25.3 30.4 43.1 44.3 40.1 25.0 dB dB dB dB dB dB dB dB 30 35 0 617 960 MHz MHz 0.35 0.50 dB dB 0.5 Insertion Loss[dB] 0 40 1 1.5 2 2.5 45 3 50 0 2000 4000 6000 8000 10000 500 12000 750 1000 1250 1500 Frequency[MHz] Frequency[MHz] S22 Return Loss S22 Smith Chart Insertion Loss 617 MHz 960 MHz 0 5 15.7 50.5 dB dB 26.5 9.1 7.2 29.7 23.8 30.9 20.0 26.6 dB dB dB dB dB dB dB dB 617 37.31 960 50.18 S22 MHz -6.87 MHz -0.24 Return Loss[dB] 10 15 20 25 30 35 40 500 750 1000 1250 1500 Frequency[MHz] S31 Attenuation S31 Insertion Loss Attenuation 960 1164 1189 3300 3500 6000 9000 12750 5 Attenuation[dB] 10 15 20 25 MHz MHz MHz MHz MHz MHz MHz MHz Attenuation 30 35 40 0 1447.9 MHz 2690 MHz 0.71 0.62 dB dB 0.5 Insertion Loss[dB] 0 1 1.5 2 2.5 45 3 50 0 2000 4000 6000 8000 10000 1000 12000 1500 2000 2500 3000 3500 Frequency[MHz] Frequency[MHz] S33 Return Loss S33 Smith Chart Insertion Loss 1447.9 MHz 2690 MHz 0 5 S33 19.9 29.2 dB dB Return Loss[dB] 10 15 20 25 30 35 40 1000 1500 2000 2500 3000 3500 Frequency[MHz] All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies 1447.9 42.56 2690 46.69 MHz 5.66 MHz -0.45 May. 2021 Ver.1.3a TDK Corporation   TPX255000MT-7090A1 ■ FREQUENCY CHARACTERISTICS S41 Attenuation ― TDK SPEC S41 Insertion Loss Attenuation 1000 1164 1189 1447.9 2690 5100 6000 9000 12750 5 10 Attenuation[dB] 15 20 25 30 35 MHz MHz MHz MHz MHz MHz MHz MHz MHz 24.9 24.5 23.9 22.0 23.0 1.0 27.5 21.9 30.4 dB dB dB dB dB dB dB dB dB 40 45 Insertion Loss 3300 MHz 4200 MHz 4400 MHz 5000 MHz 0 0.5 Insertion Loss[dB] 0 0.93 0.44 0.46 0.79 dB dB dB dB 1 1.5 2 2.5 50 55 3 60 0 2000 4000 6000 8000 10000 3000 12000 3300 3600 S44 Return Loss 4200 4500 4800 5100 5400 S44 Smith Chart Return Loss 3300 MHz 4200 MHz 4400 MHz 5000 MHz 0 5 10 Return Loss[dB] 3900 Frequency[MHz] Frequency[MHz] 17.9 25.1 25.8 24.9 3300 39.67 4200 45.15 4400 48.75 5000 55.52 S44 dB dB dB dB 15 20 MHz 4.95 MHz 2.18 MHz 4.93 MHz 2.40 25 30 35 40 3000 3300 3600 3900 4200 4500 4800 5100 5400 Frequency[MHz] S23 Isolation S24 Isolation Attenuation 0 617 960 1447.9 2690 5 Attenuation 41.7 26.6 24.6 29.0 dB dB dB dB Isolation[dB] Isolation[dB] 10 MHz MHz MHz MHz 15 20 25 30 35 40 45 50 0 300 600 900 1200 1500 1800 2100 2400 2700 0 5 10 15 20 25 30 35 40 45 50 55 60 65 70 617 960 3300 4200 4400 5000 0 3000 500 1000 1500 2000 2500 3000 3500 4000 4500 5000 MHz MHz MHz MHz MHz MHz 28.4 25.2 45.9 48.1 49.6 55.3 dB dB dB dB dB dB 5500 Frequency[MHz] Frequency[MHz] S34 Isolation 0 5 Isolation[dB] 10 15 20 Insertion Loss 1447.9 MHz 2690 MHz 3300 MHz 4200 MHz 4400 MHz 5000 MHz 22.0 22.5 35.3 24.8 26.8 35.9 dB dB dB dB dB dB Return Loss 617 MHz 960 MHz 1447.9 MHz 2690 MHz 3300 MHz 4200 MHz 4400 MHz 5000 MHz 16.2 34.8 19.7 25.3 20.0 22.2 23.4 26.8 dB dB dB dB dB dB dB dB 25 30 35 40 45 50 1000 2000 3000 4000 5000 Frequency[MHz] S11 Return Loss S11 Smith Chart 0 5 Return Loss[dB] 10 15 20 25 30 35 40 0 1000 2000 3000 4000 5000 S11 617 36.72 960 48.31 1447.9 41.30 2690 45.07 3300 49.95 4200 56.68 4400 55.22 5000 53.71 MHz 2.27 MHz 0.57 MHz -3.75 MHz 1.48 MHz -10.05 MHz 4.97 MHz 4.86 MHz 2.98 Frequency[MHz] All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.1.3a TDK Corporation   TPX255000MT-7090A1 ■ RECOMMENDED LAND PATTERN 04 4 04 04 0 unit : mm 04 ■ EVALUATION BOARD 0 8 8 0 Material & Layer Copper Surface Pattern FR-4 Inner GND FR-4 Copper Bottom GND 0 Thickness 0.035 mm 0.10 mm 0.018 mm 0.30 mm 0.035 mm unit : mm * Line width should be designed to match 50 ohm characteristic impedance depending on PCB material and thickness. ** The position of the throuh hole which have possibility of influence to the prerformance are indicated by dimension line. ■ ENVIRONMENT INFORMATION RoHS Statement RoHS Compliance All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies TDK Corporation ■ RECOMMENDED REFLOW PROFILE 3oC/sec or lower Preheating Temp. T1 T2 Time t1 150°C 200°C 60 to 120sec 6oC/sec or lower Soldering Critical zone (T3 to T4) Peak Temp. Time Temp. Time T3 t2 T4 t3 * 217°C 60 to 120sec 240 to 260°C 30 sec Max * t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. Note: Lead free solder is recommended. Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry) All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.1.3a TDK Corporation   TPX255000MT-7090A1 ■ PACKAGING STYLE Reel Dimensions Carrier Tape Sprocket hole Loading Direction J E K C D A B B H t Dimensions (mm) A B C 2.2 2.7 8.0 +/-0.05 D 3.5 +/-0.05 +0.3/-0.1 +/-0.05 G F E 1.75 F 4.0 G 2.0 H 4.0 J 1.5 +/-0.1 +/-0.1 +/-0.05 +/-0.1 +0.1/-0 K t 1.15 0.25 MAX +/-0.05 STANDARD PACKAGE QUANTITY ( pieces/reel ) 2,000 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this specification sheet are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. Aerospace/Aviation equipment Transportation equipment (cars, electric trains, ships, etc.) Medical equipment Power-generation control equipment Atomic energy-related equipment Seabed equipment Transportation control equipment Public information-processing equipment Military equipment Electric heating apparatus, burning equipment Disaster prevention/crime prevention equipment Safety equipment Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/equipment or providing backup circuits, etc., to ensure higher safety. All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies
TPX255000MT-7090A1 价格&库存
很抱歉,暂时无法提供与“TPX255000MT-7090A1”相匹配的价格&库存,您可以联系我们找货
TPX255000MT-7090A1
    • 1+2.05287
    • 10+1.62864
    • 30+1.44688
    • 100+1.22008
    • 500+1.11910
    • 1000+1.05840
    库存:1939
    TPX255000MT-7090A1
    • 1+4.504521+0.58256
    • 10+3.6719310+0.47488
    • 25+3.3824425+0.43745
    • 50+3.1796350+0.41122
    • 100+2.98974100+0.38666
    • 250+2.75724250+0.35659
    • 500+2.59341500+0.33540
    • 1000+2.439461000+0.31549
    库存:3
    TPX255000MT-7090A1
    • 2000+2.229122000+0.28829
    • 4000+2.096914000+0.27119
    • 6000+2.023206000+0.26166
    • 10000+1.9340010000+0.25012
    • 14000+1.8773814000+0.24280
    • 20000+1.8191320000+0.23527
    库存:3
