TPX255850MT-7025A1
TPX255850MT-7025A1
    TDK(东电化)
    MULTILAYER TRIPLEXER FOR 1447 -
TPX255850MT-7025A1 数据手册
The products in this catalog are not recommended for new design R F C o m p o n e n t s March 2019 Multilayer Triplexer For 1447-2500MHz / 3400-3800MHz / 5150-5850MHz TPX255850MT-7025A1 2.5x2.0mm [EIA 1008]* * Dimensions Code JIS[EIA] The products in this catalog are not recommended for new design RF Components Multilayer Triplexer Conformity to RoHS Directive For 1447-2500MHz / 3400-3800MHz / 5150-5850MHz TPX255850MT-7025A1 SHAPES AND DIMENSIONS 2.50±0.10 0.70±0.10 2.00±0.10 [Top view] 0.90±0.10 1 2 3 8 9 4 7 6 5 0.10±0.10 0.55±0.10 0.30±0.10 0.40±0.10 [Bottom view] 0.10±0.10 Marking 0.40±0.10 Terminal functions 1 High-Band Port 2 GND 3 Middle-Band Port 4 GND 5 Low-Band Port 6 GND 7 Common Port 8 GND 9 GND Dimensions in mm RECOMMENDED LAND PATTERN EVALUATION BOARD 0.30 0.40 0.90 0.55 0.40 0.40 0.30 Thru Hole Resist Metal DUT Dimensions in mm Material, Layer Top resist Copper Surface Pattern FR-4 Copper Inner GND FR-4 Copper Bottom GND Thickness Resist 0.035mm 0.100mm 0.018mm 0.300mm 0.035mm Line width should be designed to match 50Ω characteristic impedance, depending on PCB material and thickness. RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190312 / rf_tpx_tpx255850mt-7025a1_en.fm The products in this catalog are not recommended for new design RF Components TPX255850MT-7025A1 ELECTRICAL CHARACTERISTICS LOW-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Frequency Range (MHz) Min. Typ. Max. 1447 to 1511 2400 to 2500 1447 to 1511 2400 to 2500 1447 to 1511 2400 to 2500 3400 to 3600 3600 to 3800 5150 to 5850 — — — — 10.03 10.03 20 25 30 0.27 0.65 0.33 0.82 20.1 16.1 26.7 30.9 33.6 50 (Nominal) 0.50 0.80 0.60 (–40 to +85°C) 1.00 (–40 to +85°C) — — — — — Frequency Range (MHz) Min. Typ. Max. 3400 to 3600 3600 to 3800 3400 to 3600 3600 to 3800 3400 to 3600 3600 to 3800 1447 to 1511 2400 to 2500 5150 to 5850 — — — — 10.03 10.03 14 13 10 0.73 0.59 0.85 0.95 17.0 20.1 16.8 16.2 14.3 50 (Nominal) 1.00 1.00 1.10 (–40 to +85°C) 1.30 (–40 to +85°C) — — — — — Frequency Range (MHz) Min. Typ. Max. 5150 to 5850 5150 to 5850 5150 to 5850 1447 to 1511 2400 to 2500 3400 to 3600 3600 to 3800 — — 8.01 20 17 17 17 1.02 1.30 13.2 23.8 19.7 19.7 21.3 50 (Nominal) 1.50 1.80 (–40 to +85°C) — — — — — Characteristic Impedance () ・Ta: +25±5°C MIDDLE-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Characteristic Impedance () ・Ta: +25±5°C HIGH-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Characteristic Impedance () ・Ta: +25±5°C • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190312 / rf_tpx_tpx255850mt-7025a1_en.fm The products in this catalog are not recommended for new design RF Components TPX255850MT-7025A1 ELECTRICAL CHARACTERISTICS COMMON Item Frequency Range (MHz) Isolation (dB) 1447 to 1511 2400 to 2500 3400 to 3600 3600 to 3800 1447 to 1511 2400 to 2500 5150 to 5850 3400 to 3600 3600 to 3800 5150 to 5850 Low to Middle Low to High Middle to High Power Handling (W) Characteristic Impedance () Min. Typ. Max. 13 13 20 20 15 15 20 15 15 10 — 16.9 16.9 29.3 30.3 23.2 20.6 31.5 21.0 20.6 12.3 — 50 (Nominal) — — — — — — — — — — 2.0 ・Ta: +25±5°C TEMPERATURE RANGE Operating temperature (°C) –40 to +85 Storage temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190312 / rf_tpx_tpx255850mt-7025a1_en.fm The products in this catalog are not recommended for new design RF Components TPX255850MT-7025A1 FREQUENCY CHARACTERISTICS MIDDLE-BAND Insertion Loss 0.0 0.0 0.5 0.5 1.0 1.0 Insertion Loss(dB) Insertion Loss(dB) LOW-BAND Insertion Loss 1.5 2.0 2.0 2.5 2.5 3.0 500 1000 1500 2000 Frequency (MHz) 2500 3000 3.0 3000 3500 3200 0 10 10 Return Loss(dB) 0 20 30 40 4000 4200 4400 3400 3600 3800 Frequency (MHz) 4000 4200 4400 20 30 1000 1500 2000 Frequency (MHz) 2500 3000 50 3000 3500 3200 Attenuation 0 0 10 10 Attenuation(dB) Attenuation Attenuation(dB) 3600 3800 Frequency (MHz) 40 50 500 20 30 20 30 40 40 50 3400 Return Loss Return Loss Return Loss(dB) 1.5 50 0 1000 2000 3000 4000 5000 Frequency (MHz) 6000 7000 8000 0 1000 2000 3000 4000 5000 Frequency (MHz) 6000 7000 8000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190312 / rf_tpx_tpx255850mt-7025a1_en.fm The products in this catalog are not recommended for new design RF Components TPX255850MT-7025A1 FREQUENCY CHARACTERISTICS HIGH-BAND Insertion Loss 0.0 Insertion Loss(dB) 0.5 1.0 1.5 2.0 2.5 3.0 4400 4600 4800 5000 5200 5400 Frequency (MHz) 5600 5800 6000 4800 5000 5200 5400 Frequency (MHz) 5600 5800 6000 2000 3000 4000 5000 Frequency (MHz) 6000 7000 8000 Return Loss 0 Return Loss(dB) 10 20 30 40 50 4400 4600 Attenuation 0 Attenuation(dB) 10 20 30 40 50 0 1000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190312 / rf_tpx_tpx255850mt-7025a1_en.fm The products in this catalog are not recommended for new design RF Components TPX255850MT-7025A1 FREQUENCY CHARACTERISTICS Isolation (Low-Mid) 0 0 10 10 Isolation (Low-Mid) (dB) Return Loss(dB) COMMON Return Loss 20 30 30 40 40 50 20 50 0 1000 2000 3000 4000 5000 Frequency (MHz) 6000 7000 8000 0 1000 2000 3000 4000 5000 Frequency (MHz) 6000 7000 8000 3000 4000 5000 Frequency (MHz) 6000 7000 8000 3000 4000 5000 Frequency (MHz) 6000 7000 8000 Isolation (Low-High) 0 Isolation (Low-High) (dB) 10 20 30 40 50 0 1000 2000 Isolation (Mid-High) 0 Isolation (Mid-High) (dB) 10 20 30 40 50 0 1000 2000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190312 / rf_tpx_tpx255850mt-7025a1_en.fm The products in this catalog are not recommended for new design RF Components TPX255850MT-7025A1 RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 150°C T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec Peak Temp. T4 240 to 260°C Time t3 30sec max. t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190312 / rf_tpx_tpx255850mt-7025a1_en.fm The products in this catalog are not recommended for new design RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190312 / rf_tpx_tpx255850mt-7025a1_en.fm
TPX255850MT-7025A1 价格&库存
很抱歉,暂时无法提供与“TPX255850MT-7025A1”相匹配的价格&库存,您可以联系我们找货
TPX255850MT-7025A1
  • 2000+2.229092000+0.27895
库存:1935
TPX255850MT-7025A1
  • 1+4.408451+0.55167
  • 10+3.5662510+0.44628
  • 25+3.2838125+0.41094
  • 50+3.0876250+0.38639
  • 100+2.90413100+0.36343
  • 250+2.67846250+0.33518
  • 500+2.51922500+0.31526
  • 1000+2.369701000+0.29655
库存:1935
