Apr. 2021 Ver.1.5
TDK Corporation
Multilayer Triplexer
For JB-MB-HB / 5G-LM / 5GHz Triplexer
TPX Series
P/N:
2.5x2.0mm [EIA 1008] TYPE
TPX255925MT-7062B1
All specifications are subject to change without notice.
TDK Technology - Proprietary and Confidential Information of TDK Group Companies
Apr. 2021 Ver.1.5
TDK Corporation
TPX255925MT-7062B1
■ SHAPES AND DIMENSIONS
Dimensions (mm)
L
W
T
a
b
c
d
e
2.50 2.00 0.65 0.40 0.55 0.30 0.40 0.90
+/-0.15 +/-0.15
Max
+/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.15
Terminal functions
Common Port
(1)
GND
(2)
5GHz
(3)
GND
(4)
5G-LM
(5)
(6)
(7)
(8)
(9)
GND
JB-MB-HB
GND
GND
■ TERMINATION FINISH
Material
Ag
Apr. 2021
Ver.1.5
TDK Corporation
TPX255925MT-7062B1
■ ELECTRICAL CHARACTERISTICS
( Measurement )
Low-Band
Parameter
Insertion Loss (dB)
Insertion Loss (dB)
( –40 to +90 °C )
Return Loss (dB)
( Low-Band Port )
Attenuation (dB)
Characteristic Impedance (ohm)
Ta = +25+/-5°C
Frequency (MHz)
617
1166
1427
1559
1574
1598
1710
1805
1930
2300
2496
617
1166
1427
1559
1574
1598
1710
1805
1930
2300
2496
617
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
960
1186
1511
1563
1576
1606
1785
1885
1990
2496
2690
960
1186
1511
1563
1576
1606
1785
1885
1990
2496
2690
2690
3300 to 3700
3700 to 3800
3800 to 4200
4400 to 5000
5150 to 5925
5925 to 12750
TDK Spec.
Min. Typ. Max.
0.13 0.50
0.14 0.50
0.21 0.50
0.22 0.50
0.22 0.50
0.22 0.50
0.23 0.50
0.23 0.50
0.24 0.50
0.48 0.60
0.79 0.95
0.55
0.55
0.55
0.55
0.55
0.55
0.55
0.55
0.55
0.70
1.05
10
19
22
32
22
32
28
30
26
28
10
18
50 (Nominal)
Apr. 2021 Ver.1.5
TDK Corporation
TPX255925MT-7062B1
( Measurement )
Middle-Band
Parameter
Insertion Loss (dB)
Insertion Loss (dB)
( –40 to +90 °C )
Return Loss (dB)
( Middle-Band Port )
Attenuation (dB)
3300 to
3300 to
TDK Spec.
Min. Typ. Max.
4200
1.29 1.48
4200
1.60
3300 to
4200
Frequency (MHz)
500
1606
2400
2500
2700
4400
4900
5150
6250
6600
8400
9900
13200
10
15.9
to 1606 22
28
to 2400 25
28
to 2500 25
27
to 2690 25
27
to 3150 0.5 2.3
to 4900 1
2.0
to 5150 8
14
to 5925 19
to 6550 15
37
to 8400 15
37
to 9900 20
41
to 12600 20
38
to 16800 20
50 (Nominal)
Ta = +25+/-5°C
High-Band
Parameter
Insertion Loss (dB)
Insertion Loss (dB)
( –40 to +90 °C )
Return Loss (dB)
( High-Band Port )
Attenuation (dB)
5150 to
5150 to
TDK Spec.
Min. Typ. Max.
5925
0.75 0.85
5925
0.95
5150 to
5925
Frequency (MHz)
100
1166
1427
1695
2300
2400
2496
3300
10300
15450
to
960
to 1249
to 1610
to 2200
to 2370
to 2484
to 2690
to 4200
to 11850
to 17775
12
18.0
35 59.0
35 54.0
35 51.0
25 47.0
25 45.0
25 43.0
29 37.0
17 26.0
15 39.0
8
50 (Nominal)
Ta = +25+/-5°C
Apr. 2021 Ver.1.5
TDK Corporation
TPX255925MT-7062B1
( Measurement )
Common
Parameter
Frequency (MHz)
Isolation (dB)
Middle to Low
(JB-MB-HB to 5G-LM)
High to Low
(JB-MB-HB to 5 GHz)
Middle to High
(5G-LM to 5 GHz)
617
1166
1695
1710
2300
3300
5150
617
1166
1695
1710
3300
5150
617
1166
1710
3300
5150
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
960
1606
1710
2200
2690
4200
5925
960
1606
1710
2690
4200
5925
960
1606
2690
4200
5925
TDK Spec.
Min. Typ. Max.
22
28
22
29
25
32
25
34
23
25
17
19
30
47
25
57
25
49
25
49
25
41
22
37
28
29
10
37
10
32
10
22
17
18
17
21
50 (Nominal)
Ta = +25+/-5°C
■ MAXIMUM RATINGS
Parameter
Operating temperature (°C)
Storage temperature (°C)
Power Handling (dBm) Frequency[MHz]
1427 to 2960
*1
TDK Spec
Min. Max.
Conditions
–40 to +90 °C
–40 to +90 °C
30 CW
3300 to 4200
30 CW
5150 to 5925
30 CW
Human Body Model : HBM
@Each Port (V) -1000 1000 100pF / 1500ohm
Machine Model : MM
@Each Port (V) -150
150 200pF / 0ohm
Charged Device Model : CDM @Each Port (V) -500
500 Relative humidity : 60%RH max
*1: Refer to 3GPP TS 38.101-1 V15.2.0
Apr. 2021 Ver.1.5
TDK Corporation
TPX255925MT-7062B1
■ FREQUENCY CHARACTERISTICS
TDK spec.
Apr. 2021 Ver.1.5
TDK Corporation
TPX255925MT-7062B1
TDK spec.
Apr. 2021 Ver.1.5
TDK Corporation
TPX255925MT-7062B1
TDK spec.
Apr. 2021 Ver.1.5
TDK Corporation
TPX255925MT-7062B1
TDK spec.
Apr. 2021 Ver.1.5
TDK Corporation
TPX255925MT-7062B1
■ RECOMMENDED LAND PATTERN
Unit : mm
■ EVALUATION BOARD
Thru Hole
Resist
Surface Pattern
DUT
Direction Mark
Material, Layer
Thickness
Top Resist
Resist
Copper Surface Pattern
0.035mm
FR-4
0.10mm
Copper Inner GND
0.018mm
FR-4
0.30mm
Copper Bottom GND
0.035mm
■ ENVIRONMENT INFORMATION
RoHS Statement
RoHS Compliance
Apr. 2021 Ver.1.5
TDK Corporation
TPX255925MT-7062B1
■ RECOMMENDED REFLOW PROFILE
3oC/sec
or lower
Preheating
Temp.
T1
T2
Time
t1
150°C 200°C 60 to 120sec
6oC/sec
or lower
Soldering
Critical zone (T3 to T4)
Peak
Temp.
Time
Temp.
Time
T3
t2
T4
t3 *
217°C
60 to 120sec 240 to 260°C 30 sec Max
* t3 : Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Note:
Lead free solder is recommended.
Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry)
Apr. 2021 Ver.1.5
TDK Corporation
TPX255925MT-7062B1
■ PACKAGING STYLE
Reel Dimensions
Carrier Tape
Sprocket hole
Loading Direction
J
E
K
C
D
A
B
H
t
G
F
Unit : mm
Dimensions (mm)
A
B
C
2.2 2.7 8.0
+/-0.05
D
3.5
+/-0.05 +0.3/-0.1 +/-0.05
E
1.75
F
4.0
G
2.0
H
4.0
J
1.5
+/-0.1
+/-0.1
+/-0.05
+/-0.1
+0.1/-0
K
t
0.85 0.25
MAX
+/-0.05
STANDARD PACKAGE QUANTITY
( pieces/reel )
2,000
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this specification sheet are intended for use in general electronic equipment
(AV equipment, telecommunications equipment, home appliances, amusement equipment,
computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed
below, whose performance and/or quality require a more stringent level of safety or reliability,
or whose failure, malfunction or trouble could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the
products in any of the applications below or for any other use exceeding the range or
conditions set forth in this specification sheet.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
Aerospace/Aviation equipment
Transportation equipment (cars, electric trains, ships, etc.)
Medical equipment
Power-generation control equipment
Atomic energy-related equipment
Seabed equipment
Transportation control equipment
Public information-processing equipment
Military equipment
Electric heating apparatus, burning equipment
Disaster prevention/crime prevention equipment
Safety equipment
Other applications that are not considered general-purpose applications
When using this product in general-purpose applications, you are kindly requested to take into
consideration securing protection circuit/equipment or providing backup circuits, etc.,
to ensure higher safety.
很抱歉,暂时无法提供与“TPX255925MT-7062B1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.47885
- 10+1.17396
- 30+1.04339
- 100+0.88031
- 500+0.80774
- 1000+0.76421
- 国内价格 香港价格
- 1+4.647521+0.60202
- 10+3.7873010+0.49059
- 25+3.4886225+0.45190
- 50+3.2794850+0.42481
- 100+3.08367100+0.39945
- 250+2.84385250+0.36838
- 500+2.67488500+0.34649
- 1000+2.516111000+0.32593
- 国内价格 香港价格
- 2000+2.300072000+0.29794
- 4000+2.163654000+0.28027
- 6000+2.087596000+0.27042
- 10000+1.9955510000+0.25850
- 14000+1.9371314000+0.25093
- 20000+1.8770320000+0.24314
