C A P A C I T O R S
Ultra high voltage ceramic capacitors
For power circuit breakers
TSF series
FEATURES
Lineup of rated voltage Eac: 20kV
Strong impulse voltage
High capacitance and excellent temperature characteristics
Low loss and low distortion factor
Uses high-reliability mold resin
APPLICATION
Circuit breakers for gas insulation switchgears (available for SF6 gas)
PART NUMBER CONSTRUCTION
607
34
ZT
112
J
4D
A
S
Product category
Internal
code
Temperature
characteristic
Nominal
capacitance
Capacitance
tolerance
Rated
voltage
Voltage
classification
Insulation
structure
Ultra high voltage
ceramic capacitors
ZT
Z5T(+10 to +85°C,
+22,-33%)
401
400pF
112
1080pF
J
K
±5%
±10%
4D
20kV
A
AC voltage
specification
S
Mold type
Please refer to P-2 about the product dimensions.
OPERATING TEMPERATURE RANGE
series
TSF
Operating
temperature(°C)
–30 to +85
Storage
temperature(°C)
–30 to +85
The maximum operating temperature of +85°C includes capacitor self-generated heat of up to 20°C.
PRODUCT APPEARANCE
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/3)
20211006
uhv_tsf_en.fm
C A P A C I T O R S
TSF series
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
Class 2 (Temperature stable)
Temperature characteristic: Z5T (+10 to +85°C, +22,-33%)
Part numbers
Sub part
numbers
60734ZT112J4DAS TSF-40C
60722ZT401K4DAS TSF-30
pC : Pico coulomb
Rated
voltage
Capacitance
Withstanding voltage
(kVAC)
(pF)
1080±5%
400±10%
[1min.in insulating liquid]
(kVAC)
(%) max.
42
0.1
30
0.3
TEMPERATURE CHARACTERISTIC
Insulation
resistance
(M) min.
10,000
10,000
AC corona
starting voltage
[3pC ]
(kVAC) min.
25
25
Lightning impulse
withstanding voltage
(kV) min.
±110
±110
AC VOLTAGE CHARACTERISTIC
1
30
Capacitance change rate(%)
50
Z5T
Dissipation
factor(tan)
10
–10
–1
–2
–3
–30
–4
–50
–50
Temperature(°C)
100
100%=Rated voltage
100
Rated voltage(%)
150
SHAPE & DIMENSIONS
Terminal
ød±0.5
MARKINGS
TSF-40C
112J
AC20kV
TDK
1234
Sub part number
Nominal capacitance and tolerance code
Rated voltage
Manufacturer’s name (TDK or TDK logo mark)
Lot number
29±2
33±1
øD±1
Molded with epoxide resin; alumina filler.
Part numbers
60734ZT112J4DAS
60722ZT401K4DAS
Sub part
numbers
TSF-40C
TSF-30
øD
(mm)
40
30
ød
(mm)
15
10
(2/3)
20211006
uhv_tsf_en.fm
C A P A C I T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
(1) During transportation and storage
• Do not transport or store where the prodcuts will be exposed to high temperature or high humidity.
• Do not expose to poisonous gases such as H2SO4, HCl, or HNO3.
• Avoid excessive impact such as that caused by falling.
(2) During operation
• Avoid contact with electrolytes such as perspiration. Do not touch with bare hands.
• Do not apply solder to stud terminals.
• Do not re-machine the terminals.
(3) Usage
• Make sure that the prodcuts are not exposed to radiant heat from chambers or transformers.
• Please contact us when using in SF6 gas.
(4) Others
The products listed on this catalog are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious
damage to society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set
forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment (excepting Pharmaceutical Affairs Law
classification Class1,2)
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
(3/3)
20211006
uhv_tsf_en.fm
很抱歉,暂时无法提供与“TSF-40C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+455.939831+58.85283
