TSL0709RA-4R7M2R6-PF
    TDK(东电化)
    径向
    固定电感器 Radial, Vertical Cylinder 4.7µH ±20% 2.6A 22mΩ 29MHz 10@7.96MHz
TSL0709RA-4R7M2R6-PF 数据手册
Inductors for Power Circuits Radial lead TSL series Type: TSL0709 TSL0808 TSL1112 TSL1315 Issue date: September 2011 • All specifications are subject to change without notice. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The storage period is less than 12 months. Be sure to follow the storage conditions (Temperature: 5 to 30°C, Humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. (1/8) Inductors for Power Circuits Radial Lead Conformity to RoHS Directive TSL Series TSL0709 FEATURES • The TSL series feature low DC resistance and high current handling capacities, making them ideal for power supply line applications. • These parts are manufactured to a high degree of dimensional accuracy using non-flammable material (UL94V-0). • Available in tape packaging to support automated mounting machines. • It is a product conforming to RoHS directive. PRODUCT IDENTIFICATION TSL 0709 RA- 1R0 M 5R0 - PF (1) (2) (3) (4) (5) (6) (7) (1)Series name (2)Dimensions 0709 ø7.7×9.5mm (lead pitch 5mm) (3)Packaging style APPLICATIONS Televisions, VCRs, personal computers, and other electronic equipment. RA S Taping(Ammo-pack) Bulk (4)Inductance value SPECIFICATIONS Operating temperature range Storage temperature range Terminal tensile strength Flow soldering condition –40 to +85°C [Including self-temperature rise] –40 to +85°C[Unit of products] 9.8N min. 260°C /10 seconds 1R0 100 1µH 10µH (5)Inductance tolerance K M ±10% ±20% (6)Rated current 5R0 R66 5A 0.66A (7)Lead-free compatible product PF Lead-free compatible product PACKAGING STYLE AND QUANTITIES Packaging style Taping (Ammo-pack) Bulk Quantity 1000 pieces/box 500 pieces/10tray • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 001-02 / 20110925 / e532_tsl (2/8) 5±1 9.5±0.1 ø7.7±0.3 SHAPES AND DIMENSIONS ø0.65±0.05 Weight: 1.1g 5+2, –1 Dimensions in mm ELECTRICAL CHARACTERISTICS Rated current(A)∗1max. Test Self-resonant DC Part No. frequency frequency resistance Based on inductance Based on L/Q (Hz) (MHz)min. (Ω)max. change temperature rise 1 ±20% 10 1k/7.96M 70 0.006 6.6 5 TSL0709 ∗2-1R0M5R0-PF 1.5 ±20% 10 1k/7.96M 56 0.008 5.4 4.3 TSL0709 -1R5M4R3-PF 2.2 ±20% 10 1k/7.96M 45 0.011 4 3.7 TSL0709 -2R2M3R7-PF 3.3 ±20% 10 1k/7.96M 36 0.018 3.6 2.9 TSL0709 -3R3M2R9-PF 4.7 ±20% 10 1k/7.96M 29 0.022 3.1 2.6 TSL0709 -4R7M2R6-PF 6.8 ±20% 10 1k/7.96M 24 0.028 2.5 2.3 TSL0709 -6R8M2R3-PF 10 ±10% 20 1k/2.52M 19 0.043 2.1 1.9 TSL0709 -100K1R9-PF 15 ±10% 20 1k/2.52M 15 0.056 1.7 1.6 TSL0709 -150K1R6-PF 22 ±10% 20 1k/2.52M 12 0.086 1.4 1.3 TSL0709 -220K1R3-PF 33 ±10% 20 1k/2.52M 9.4 0.14 1.1 1 TSL0709 -330K1R0-PF 47 ±10% 20 1k/2.52M 7.6 0.17 0.96 0.94 TSL0709 -470KR94-PF 68 ±10% 20 1k/2.52M 6.2 0.28 0.79 0.73 TSL0709 -680KR73-PF 100 ±10% 20 1k/796k 5 0.33 0.66 0.67 TSL0709 -101KR66-PF 150 ±10% 20 1k/796k 4 0.56 0.53 0.52 TSL0709 -151KR52-PF 220 ±10% 20 1k/796k 3.2 0.72 0.44 0.46 TSL0709 -221KR44-PF 330 ±10% 20 1k/796k 2.5 1.1 0.36 0.37 TSL0709 -331KR36-PF 470 ±10% 20 1k/796k 2 1.7 0.3 0.3 TSL0709 -471KR30-PF 680 ±10% 20 1k/796k 1.7 2.3 0.25 0.26 TSL0709 -681KR25-PF 1000 ±10% 70 1k/252k 1.3 4.3 0.2 0.19 TSL0709 -102KR19-PF 1500 ±10% 50 1k/252k 1.3 5 0.17 0.16 TSL0709 -152KR16-PF ∗1 Rated current: Value obtained when current flows and the temperature has risen to 25°C or when DC current flows and the initial value of inductance has fallen by 20%, whichever is smaller. ∗2 : Please specify packaging style, S(Bulk) or RA(Taping). Inductance (µH) Inductance tolerance Q min. Test circuit L=0.1H C=20000µF A DC Specimen 10000 3000 1000µH 1000 YHP model-4275A or equivalent Universal bridge TYPICAL ELECTRICAL CHARACTERISTICS INDUCTANCE CHANGE vs. DC SUPERPOSITION CHARACTERISTICS 330µH Inductance (µH) 300 100µH 100 33µH 30 10µH 10 3.3µH 3 1 1µH 0.3 0.1 0.01 0.03 0.1 0.3 1 DC current (A) 3 10 • All specifications are subject to change without notice. 001-02 / 20110925 / e532_tsl (3/8) Inductors for Power Circuits Radial Lead Conformity to RoHS Directive TSL Series TSL0808 FEATURES • The TSL series feature low DC resistance and high current handling capacities, making them ideal for power supply line applications. • These parts are manufactured to a high degree of dimensional accuracy using non-flammable material (UL94V-0). • Available in tape packaging to support automated mounting machines. • It is a product conforming to RoHS directive. PRODUCT IDENTIFICATION TSL 0808 RA- 3R3 M 3R8 - PF (1) (2) (3) (4) (5) (6) (7) (1)Series name (2)Dimensions 0808 ø8.5×8.3mm (lead pitch 5mm) (3)Packaging style APPLICATIONS Televisions, VCRs, personal computers, and other electronic equipment. RA S Taping(Ammo-pack) Bulk (4)Inductance value SPECIFICATIONS Operating temperature range Storage temperature range Terminal tensile strength Flow soldering condition –40 to +85°C [Including self-temperature rise] –40 to +85°C[Unit of products] 9.8N min. 260°C /10 seconds 3R3 100 3.3µH 10µH (5)Inductance tolerance K M ±10% ±20% (6)Rated current 3R8 R67 3.8A 0.67A (7)Lead-free compatible product PF Lead-free compatible product PACKAGING STYLE AND QUANTITIES Packaging style Taping (Ammo-pack) Bulk Quantity 1000 pieces/box 500 pieces/10tray • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 001-02 / 20110925 / e532_tsl (4/8) ø0.62±0.05 5±1 8.3±0.5 ø8.5±0.3 SHAPES AND DIMENSIONS Weight: 1.5g 5+0.8, –0.5 Dimensions in mm ELECTRICAL CHARACTERISTICS Inductance (µH) Inductance tolerance Q min. 2.2 3.3 4.7 6.8 10 15 22 33 47 68 100 150 220 330 470 680 1000 1500 2200 3300 4700 ±20% ±20% ±20% ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±5% 10 10 10 10 20 20 20 20 20 20 20 20 15 15 15 15 30 30 50 50 50 Test frequency L/Q (Hz) 1k/7.96M 1k/7.96M 1k/7.96M 1k/7.96M 1k/2.52M 1k/2.52M 1k/2.52M 1k/2.52M 1k/2.52M 1k/2.52M 1k/796k 1k/796k 1k/796k 1k/796k 1k/796k 1k/796k 1k/252k 1k/252k 1k/252k 1k/252k 1k/252k Self-resonant frequency (MHz)min. 45 34 27 22 17 13 10 8 6.5 5.4 4.4 3.6 2.9 2.4 2 1.6 1.3 1.1 0.88 0.71 0.68 DC resistance (Ω )max. 0.015 0.017 0.021 0.025 0.031 0.042 0.07 0.092 0.13 0.16 0.25 0.4 0.53 0.78 1 1.5 2.2 3.5 6.4 8.5 12.2 Rated current (A)∗1max. Based on inductance Based on change temperature rise 5.6 3.9 4.5 3.8 3.8 3.5 3.2 3.1 2.6 2.7 2.1 2.4 1.7 1.9 1.4 1.5 1.2 1.3 1 1.1 0.8 0.94 0.67 0.73 0.54 0.64 0.45 0.52 0.38 0.46 0.32 0.37 0.26 0.3 0.21 0.25 0.17 0.21 0.14 0.16 0.15 0.13 Part No. TSL0808 TSL0808 TSL0808 TSL0808 TSL0808 TSL0808 TSL0808 TSL0808 TSL0808 TSL0808 TSL0808 TSL0808 TSL0808 TSL0808 TSL0808 TSL0808 TSL0808 TSL0808 TSL0808 TSL0808 TSL0808 ∗2-2R2M3R9-PF -3R3M3R8-PF -4R7M3R5-PF -6R8M3R1-PF -100K2R6-PF -150K2R1-PF -220K1R7-PF -330K1R4-PF -470K1R2-PF -680K1R0-PF -101KR80-PF -151KR67-PF -221KR54-PF -331KR45-PF -471KR38-PF -681KR32-PF -102KR26-PF -152KR21-PF -222KR17-PF -332KR14-PF -472JR13-PF ∗1 Rated current: Value obtained when current flows and the temperature has risen to 25°C or when DC current flows and the initial value of inductance has fallen by 10%, whichever is smaller. ∗2 : Please specify packaging style, S(Bulk) or RA(Taping). 300 Inductance(µH) YHP model-4275A or equivalent 100 10000 68µH 47µH 33µH 22µH 15µH 10µH 30 10 3 1 Test circuit L=0.1H C=20000µF A DC Specimen 3000 1000 Inductance(µH) Test circuit L=0.1H C=20000µF A DC Specimen Universal bridge 1000 1000µH YHP model-4275A or equivalent Universal bridge TYPICAL ELECTRICAL CHARACTERISTICS INDUCTANCE CHANGE vs. DC SUPERPOSITION CHARACTERISTICS 680µH 470µH 330µH 220µH 150µH 100µH 300 100 30 0.01 0.03 0.1 0.3 1 DC current(A) 3 10 10 0.01 0.03 0.1 0.3 1 DC current(A) 3 10 • All specifications are subject to change without notice. 001-02 / 20110925 / e532_tsl (5/8) Inductors for Power Circuits Radial Lead Conformity to RoHS Directive TSL Series TSL1112 FEATURES • The TSL series feature low DC resistance and high current handling capacities, making them ideal for power supply line applications. • These parts are manufactured to a high degree of dimensional accuracy using non-flammable material (UL94V-0). • Available in tape packaging to support automated mounting machines. • It is a product conforming to RoHS directive. PRODUCT IDENTIFICATION TSL 1112 RA- 3R3 M 5R9 - PF (1) (2) (3) (4) (5) (6) (7) (1)Series name (2)Dimensions 1112 ø11.2×12.2mm (lead pitch 5mm) (3)Packaging style APPLICATIONS Televisions, VCRs, personal computers, and other electronic equipment. RA S Taping(Ammo-pack) Bulk (4)Inductance value SPECIFICATIONS Operating temperature range Storage temperature range Terminal tensile strength Flow soldering condition –40 to +85°C [Including self-temperature rise] –40 to +85°C[Unit of products] 9.8N min. 260°C /10 seconds 3R3 100 3.3µH 10µH (5)Inductance tolerance J K M ±5% ±10% ±20% (6)Rated current 5R9 R56 5.9A 0.56A (7)Lead-free compatible product PF Lead-free compatible product PACKAGING STYLE AND QUANTITIES Packaging style Taping (Ammo-pack) Bulk Quantity 500 pieces/box 400 pieces/8tray • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 001-02 / 20110925 / e532_tsl (6/8) 5±1 12.2±0.3 ø11.2±0.3 SHAPES AND DIMENSIONS ø0.65±0.05 5+1, –0.5 Weight: 3.3g Dimensions in mm ELECTRICAL CHARACTERISTICS Inductance (µH) Inductance tolerance Q min. 1.0 2.2 3.3 4.7 6.8 10 15 22 33 47 68 100 150 220 330 470 680 1000 1500 2200 3300 4700 6800 10000 15000 ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% 15 15 10 10 10 20 20 20 30 30 20 20 20 20 20 10 10 20 30 20 30 30 30 30 50 Test frequency L/Q (Hz) 1k/7.96M 1k/7.96M 1k/7.96M 1k/7.96M 1k/7.96M 1k/2.52M 1k/2.52M 1k/2.52M 1k/2.52M 1k/2.52M 1k/2.52M 1k/796k 1k/796k 1k/796k 1k/796k 1k/796k 1k/796k 1k/252k 1k/252k 1k/252k 1k/252k 1k/252k 1k/252k 1k/79.6k 1k/79.6k Self-resonant frequency (MHz)min. 144 70 36 28 18 16 12 9.5 7 5.8 4.7 3.8 3.1 2.5 2 1.6 1.3 1.1 0.82 0.76 0.64 0.54 0.45 0.38 0.29 DC resistance (Ω)max. 0.058 0.073 0.01 0.015 0.016 0.025 0.029 0.04 0.062 0.075 0.13 0.16 0.26 0.33 0.52 0.66 1.1 1.4 2.4 3.2 4.9 7.6 9.8 18 24 Rated current (A)∗1max. Based on inductance Based on change temperature rise 14 7.7 10 6.7 8.8 5.9 7.2 4.8 6.1 4.6 5 3.7 4.2 3.4 3.4 2.9 2.8 2.3 2.3 2.1 1.9 1.6 1.6 1.4 1.3 1.1 1.1 1 0.88 0.82 0.75 0.72 0.61 0.56 0.51 0.5 0.43 0.38 0.35 0.33 0.28 0.26 0.24 0.21 0.2 0.18 0.17 0.14 0.13 0.12 Part No. TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 TSL1112 ∗2-1R0M7R7-PF -2R2M6R7-PF -3R3M5R9-PF -4R7M4R8-PF -6R8M4R6-PF -100M3R7-PF -150M3R4-PF -220K2R9-PF -330K2R3-PF -470K2R1-PF -680K1R6-PF -101K1R4-PF -151K1R1-PF -221K1R0-PF -331KR82-PF -471KR72-PF -681KR56-PF -102JR50-PF -152JR38-PF -222JR33-PF -332JR26-PF -472JR21-PF -682JR18-PF -103JR14-PF -153JR12-PF ∗1 Rated current: Value obtained when current flows and the temperature has risen to 25°C or when DC current flows and the initial value of inductance has fallen by 10%, whichever is smaller. ∗2 : Please specify packaging style, S(Bulk) or RA(Taping). TYPICAL ELECTRICAL CHARACTERISTICS INDUCTANCE CHANGE vs. DC SUPERPOSITION CHARACTERISTICS 10000µH 10000 3300µH 3000 1000µH Inductance (µH) 1000 Test circuit Universal bridge C=20000µF L=0.1H A DC Specimen YHP model-4255A or equivalent 330µH 300 100µH 100 33µH 30 10µH 10 3.3µH 3 1 0.01 0.03 0.1 0.3 1 DC current (A) 3 10 • All specifications are subject to change without notice. 001-02 / 20110925 / e532_tsl (7/8) Inductors for Power Circuits Radial Lead Conformity to RoHS Directive TSL Series TSL1315 FEATURES • The TSL series feature low DC resistance and high current handling capacities, making them ideal for power supply line applications. • These parts are manufactured to a high degree of dimensional accuracy using non-flammable material (UL94V-0). • Available in tape packaging to support automated mounting machines. • It is a product conforming to RoHS directive. PRODUCT IDENTIFICATION TSL 1315 RA- 100 K 5R1 - PF (1) (2) (3) (4) (5) (6) (7) (1)Series name (2)Dimensions 1315 ø14×17mm (lead pitch 7.5mm) (3)Packaging style APPLICATIONS Televisions, VCRs, personal computers, and other electronic equipment. RA S Taping(Ammo-pack) Bulk (4)Inductance value SPECIFICATIONS Operating temperature range Storage temperature range Terminal tensile strength Flow soldering condition –40 to +85°C [Including self-temperature rise] –40 to +85°C[Unit of products] 9.8N min. 260°C /10 seconds 100 102 10µH 1000µH (5)Inductance tolerance J K ±5% ±10% (6)Rated current 5R1 R99 5.1A 0.99A (7)Lead-free compatible product PF Lead-free compatible product PACKAGING STYLE AND QUANTITIES Packaging style Taping (Ammo-pack) Bulk Quantity 200 pieces/box 50 pieces/pack • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 001-02 / 20110925 / e532_tsl (8/8) 5±0.5 17max. ø14max. SHAPES AND DIMENSIONS ø0.8±0.05 7.5±0.5 Weight: 7.5g Dimensions in mm ELECTRICAL CHARACTERISTICS Inductance (µH) Inductance tolerance Q typ. 10 15 22 33 47 68 100 150 220 330 470 680 1000 1500 2200 3300 4700 6800 10000 ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±5% ±5% ±5% ±5% ±5% ±5% ±5% 70 70 60 50 50 40 50 50 40 30 30 30 30 40 40 40 40 30 70 Test frequency L/Q (Hz) 1k/2.52M 1k/2.52M 1k/2.52M 1k/2.52M 1k/2.52M 1k/2.52M 1k/796k 1k/796k 1k/796k 1k/796k 1k/796k 1k/796k 1k/252k 1k/252k 1k/252k 1k/252k 1k/252k 1k/252k 1k/79.6k Self-resonant frequency (MHz)min. 19 12 7.6 6.9 5.6 4.4 3.3 2.6 2.2 1.8 1.5 1.2 1 0.83 0.7 0.6 0.43 0.38 0.3 DC resistance (Ω )max. 0.023 0.028 0.035 0.043 0.052 0.068 0.097 0.14 0.2 0.3 0.43 0.61 1 1.3 2 3.1 4.4 6.5 10 Rated current (A)∗1max. Based on inductance Based on change temperature rise 12 5.1 9.5 4.5 8.2 4.2 6.8 3.7 5.7 3.4 4.8 3 3.9 2.5 3.2 2.1 2.7 1.7 2.1 1.4 1.8 1.1 1.5 0.99 1.2 0.78 1 0.68 0.83 0.55 0.69 0.44 0.58 0.37 0.46 0.3 0.4 0.24 Part No. TSL1315 TSL1315 TSL1315 TSL1315 TSL1315 TSL1315 TSL1315 TSL1315 TSL1315 TSL1315 TSL1315 TSL1315 TSL1315 TSL1315 TSL1315 TSL1315 TSL1315 TSL1315 TSL1315 ∗2-100K5R1-PF -150K4R5-PF -220K4R2-PF -330K3R7-PF -470K3R4-PF -680K3R0-PF -101K2R5-PF -151K2R1-PF -221K1R7-PF -331K1R4-PF -471K1R1-PF -681KR99-PF -102JR78-PF -152JR68-PF -222JR55-PF -332JR44-PF -472JR37-PF -682JR30-PF -103JR24-PF ∗1 Rated current: Value obtained when current flows and the temperature has risen to 25°C or when DC current flows and the initial value of inductance has fallen by 10%, whichever is smaller. ∗2 : Please specify packaging style, S(Bulk) or RA(Taping). 100000 Test circuit L=0.1H C=20000µF A DC Specimen 30000 10000µH 10000 YHP model-4275A or equivalent 3300µH 3000 Inductance (µH) LCR meter TYPICAL ELECTRICAL CHARACTERISTICS INDUCTANCE CHANGE vs. DC SUPERPOSITION CHARACTERISTICS 1000µH 1000 330µH 220µH 150µH 100µH 68µH 47µH 33µH 22µH 300 100 30 15µH 10 10µH 5 0.01 0.03 0.1 0.3 1 DC current (A) 3 10 • All specifications are subject to change without notice. 001-02 / 20110925 / e532_tsl
- 物料型号:TSL系列包括TSL0709、TSL0808、TSL1112和TSL1315型号。 - 器件简介:TSL系列电感器具有低直流电阻和高电流承载能力,适合用于电源线路应用。它们使用非易燃材料(UL94V-0)制造,具有高精度的尺寸,并支持自动化装配机的胶带包装。 - 引脚分配:文档提供了不同型号的电感器的尺寸和引脚间距。 - 参数特性:包括工作温度范围、存储温度范围、端子拉伸强度和波峰焊接条件。 - 功能详解:电感器符合RoHS指令,不包含铅、镉、汞、六价铬和特定的溴基阻燃剂PBB和PBDE。 - 应用信息:适用于电视、录像机、个人电脑等电子设备。 - 封装信息:提供了不同型号的封装风格和数量,例如TSL0709有带状(Ammo-pack)和散装两种包装方式。
TSL0709RA-4R7M2R6-PF 价格&库存
很抱歉,暂时无法提供与“TSL0709RA-4R7M2R6-PF”相匹配的价格&库存,您可以联系我们找货
