Common Mode Choke Coils
For general signal line
UF series
Type:
Compact and two sections bobbin type
UF1717VB/HB
Issue date:
September 2011
• All specifications are subject to change without notice.
• Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific
bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications.
(1/6)
For Signal Line
UF Series
TDK’s compact type common mode choke coils are suitable for
protecting telephone circuitry from interference such as radio
broadcasts or noise conducted from the DC side of an AC adapter.
FEATURES
• Compact size and lightweight.
• High reduction over a wide range of frequencies.
PRODUCT IDENTIFICATION
UF
(1)
(2)
V - B
(3) (4)
Y
(5)
R
(6)
- 01
(7)
(1) Core shape
UF: U-type core
(2) Dimensional code
Width×Depth
(3) External shape code
V: Vertical type H: Horizontal type
(4) High µ material
(5) Inductance value
Example) 153:15mH
(6) Rated current value
Example) 0R3:0.3A
(7) Product management number
SELECTION CHART
Series
Configuration
Type
Inductance value
min.
Rated current
(A)
Handling power∗
L×I2(mH×A2)
Weight
(g)typ.
UF
Two sections bobbin types
UF1717VB
UF1717HB
7, 15mH
7, 15mH
0.15 to 0.3
0.15 to 0.3
0.3
0.3
4
4
Minimum
package quantity
(pieces/box)
640
480
∗ Handling power=(Inductance value)×(Current)2. It is possible to design within the range below this value.
[Example] The coil for 2A can make even the inductance of 2.5mH or less a product for handling power 10.
001-02 / 20110921 / e9_uf
(2/6)
Compact and Separable Bobbin Type UF Series
TYPICAL ELECTRICAL CHARACTERISTICS
IMPEDANCE vs. FREQUENCY CHARACTERISTICS
1000
15.5max.
11max.
UF1717VB/UF1717HB TYPES
SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM
UF1717VB
UF1717HB
17.5max.
17.5max.
2
4
1
L1
4
2
L2
3
4
8±0.5
1
702
Inductance
(mH)min.
15
7
15
7
1
Recommended hole diameter: ø1.1
Dimensions in mm
0.1
0.01
0.1
1
Frequency (MHz)
10
100
RATINGS
DC resistance
(Ω )max.
5
2.5
5
2.5
• Measuring equipment of inductance value:
LCR meter(HP4261A, HP4263B or equivalent)[f=1kHz]
PACKAGING QUANTITIES
UF1717VB
UF1717HB
10
Weight: 4g typ.
(STANDARD LINE UP)
UF1717VB-153YR15-01
UF1717VB-702Y0R3-01
UF1717HB-153YR15-01
UF1717HB-702Y0R3-01
153
2
3
3
Part No.
Impedance (kΩ)
12.5max.
ø0.6
7±0.5
8±0.5
1
7±0.5
ø0.6
4±1
4±1
17max.
100
Rated current
Iac(A)max.
0.15
0.3
0.15
0.3
Item
Rated voltage(V)
Insulation resistance
(MΩ )
Temperature rise(°C)
Operating temperature
range(°C)
Storage temperature
range(°C)
Resistance to
soldering temperature∗
Standard value
50
100min.
45max.
–20 to +105
Conditions
DC
Between each winding for
DC.500V
With line resistance
Including self-temperature
rise
–20 to +60
260±5°C, 10±1sec Solder bath method
350±5°C, 5sec max. Soldering iron method
Pb free solder(Sn-3Ag-0.5Cu)
640pieces/box
480pieces/box
UF1717VB-153YR15-01 价格&库存
很抱歉,暂时无法提供与“UF1717VB-153YR15-01”相匹配的价格&库存,您可以联系我们找货
