VAF201610FA-441-1
VAF201610FA-441-1
    TDK(东电化)
    0806 (2016 Metric)
    NOISE SUPPRESSION FILTER FOR AUD
VAF201610FA-441-1 数据手册
I N D U C T O R S Noise suppression filter For audio lines (Class-D amplifier noise suppression) VAF-FA series RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free VAF201610FA-1 type FEATURES A compact noise suppression component for audio lines that accommodates high currents. Distortions are greatly reduced during insertion with the adoption of newly-developed low distortion ferrite materials. Small reductions in volume due to its low resistance, and optimal for devices that require high sound quality as the generating of sound distortions is controlled. High efficacy is put for high frequency noise suppression of class-D amplifier harmonics in 100MHz because of high damping property. Operating temperature range: –40 to +105°C (including self-temperature rise) APPLICATION AI speakers, Bluetooth speakers, TV speakers Application guides: Smart phones/tablets PART NUMBER CONSTRUCTION VAF 201610 F A Series name L×W×H dimensions 2.0×1.6×1.0 mm Characteristics Internal code - 131 - Impedance () at 100MHz 1 Marking CHARACTERISTICS SPECIFICATION TABLE Impedance DC resistance [100MHz] ( )typ. 130 280 440 840 ( )max. 0.040 0.050 0.076 0.079 Rated current ( )typ. 0.032 0.042 0.063 0.066 (A)max. 3.08 2.69 2.19 2.14 Part No. (A)typ. 3.62 3.16 2.58 2.52 VAF201610FA-131-1 VAF201610FA-281-1 VAF201610FA-441-1 VAF201610FA-841-1 Measurement equipment Measurement item Product No. Impedance 4294A DC resistance 34420A * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies Hewlett-Packard Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20180906 suppression-filter_commercial_vaf201610fa-1_en.fm I N D U C T O R S VAF201610FA-1 type Z FREQUENCY CHARACTERISTICS 2000 841 1500 Impedance (Ω) 441 1000 281 131 500 0 1 10 100 1000 Frequency (MHz) INSERTION LOSS VS. FREQUENCY CHARACTERISTICS 0 131 Insertion loss (dB) 5 281 10 441 15 841 20 1 10 100 1000 Frequency (MHz) Measurement equipment Product No. Manufacturer 4294A Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/4) 20180906 suppression-filter_commercial_vaf201610fa-1_en.fm I N D U C T O R S VAF201610FA-1 type SHAPE & DIMENSIONS PACKAGING STYLE REEL DIMENSIONS 1.6±0.2 2.0±0.5 (0.65) (0.7) (0.65) 1.0max. ø60+1/–0 2.0±0.2 Dimensions in mm ø13±0.2 9.0±0.3 ø21±0.8 13±1.4 ø180+0/–3 Dimensions in mm 4.0±0.1 B 1.6 0.7 2.0±0.05 A K 0.65 1.5 +0.1 –0 3.5±0.05 Sprocket hole 0.25±0.05 8.0±0.2 RECOMMENDED LAND PATTERN 1.75±0.1 TAPE DIMENSIONS 0.65 Cavity 4.0±0.1 2.0 Dimensions in mm Dimensions in mm Type VAF201610FA-1 A 1.9±0.1 Package quantity Soldering Natural cooling Peak 260°C Temperature 230°C K 1.10±0.05 PACKAGE QUANTITY RECOMMENDED REFLOW PROFILE Preheating B 2.3±0.1 230°C 2000 pcs/reel TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating Storage Individual temperature range temperature range weight –40 to +105 °C –40 to +105 °C 15 mg  Operating temperature range includes self-temperature rise.  The storage temperature range is for after the assembly. 180°C 10s 150°C 60 to 120s 30s Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20180906 suppression-filter_commercial_vaf201610fa-1_en.fm I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is less than 12 months. Be sure to follow the storage conditions (temperature: 5 to 30°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20180906 suppression-filter_commercial_vaf201610fa-1_en.fm
VAF201610FA-441-1 价格&库存
很抱歉,暂时无法提供与“VAF201610FA-441-1”相匹配的价格&库存,您可以联系我们找货
VAF201610FA-441-1
    • 1+0.68159
    • 200+0.27206
    • 500+0.26288
    • 1000+0.25845
    VAF201610FA-441-1
    • 1+4.607651+0.59898
    • 10+3.2520210+0.42276
    • 25+2.8119525+0.36555
    • 50+2.5092550+0.32620
    • 100+2.10416100+0.27354
    • 250+1.78704250+0.23231
    • 500+1.56694500+0.20370
    • 1000+1.388961000+0.18056
    库存:1393
    VAF201610FA-441-1
    • 2000+1.138192000+0.14796
    • 4000+1.134764000+0.14752
    库存:1393
