T R A N S F O R M E R S
SMD transformers for automotive grade
Transformers for IGBT/FET
RoHS
REACH
SVHC-Free
Cl
Br
Pb
Halogen
Free
Lead
Free
VGT series
FEATURES
A power transformer for the IPM drive of the motor inverter.
High flux density cores have been adopted to achieve miniaturization.
The dielectric strength voltage is 2.6 kV.
Operating temperature range: –40 to +130°C (including self-temperature rise)
APPLICATION
For Intelligent Power Module drive power supply of an inverter motor
PART NUMBER CONSTRUCTION
VGT
10SEE
Series name
Core shape
200
S2A5
Internal code
Type name
PRODUCT LINEUP
Inductance
NP
(µH)
Tolerance
Leakage inductance
NP(NS all shorted)
(µH)max.
Withstanding voltage
NP, NF-NS
Coil-Core
Sense: 1mA
Sense: 1mA
Turn ratio
±25%
0.5
2.6kVrms/1min
1.3kVrms/1min
NP:NF:NS1:NS2
=1:1:1:1
10
±20%
0.2
2.6kVrms/1min
1.3kVrms/1min
NP:NF:NS
=1:1.6:2.9
8.0
±20%
0.2
2.6kVrms/1min
1.3kVrms/1min
NP:NF:NS1:NS2:NS3
=1:2.8:2.8:2.8:2.8
10
±20%
0.2
2.6kVrms/1min
1.3kVrms/1min
NP:NF:NS
=1:1.8:3.3
2.6
±20%
0.2
2.6kVrms/1min
1.3kVrms/1min
NP:NF:NS1:NS2:NS3:NS4
=1:3:3:3:3:3
2.5
±15%
0.3
2.6kVrms/1min
1.3kVrms/1min
NP:NS1-P:NS1-N:NS2-P:NS2-N:
NS3-P:NS3-N:NS4-P:NS4-N
=1:1.2:0.7:1.2:0.7:1.2:0.7:1.2:0.7
VGT10SEE-200S2A5
13.3x17.9x10.8(mm)max.
VGT12EEM-200S1A4
13.9x15.3x10.0(mm)max.
VGT15EFD-200S3A6
20.3x24.5x10.2(mm)max.
VGT15SEFD-200S1A4
15.9x19.9x10.0(mm)max.
VGT15SEFD-250S4A7
23.3x22.4x12.0(mm)max.
VGT22EPC-200S6A12
33.5x27.8x13.7(mm)max.
Measuring conditions: 100kHz/1V
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/9)
20200109
trans_gate-drive_vgt_en.fm
VGT10SEE-200S2A5
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
Part No.
Inductance
NP
(µH)
Tolerance
Leakage inductance
NP(NS all shorted)
(µH)max.
NP, NF-NS
Coil-Core
Sense: 1mA
Sense: 1mA
Turn ratio
VGT10SEE-200S2A5
2.6kVrms/1min
NP:NF:NS1:NS2
=1:1:1:1
±25%
1.3kVrms/1min
SHAPE & DIMENSIONS
10
7.5
5
0.6±0.1
2.5
6
9.6
(3.9)
17.4±0.5
12.0
(3.9)
9
1
5
0.3±0.1
2.5
13.0
5
7.5
10.8max.
10
The unspecified dimensional tolerance is ±0.3.
Dimensions in mm
0.13
RECOMMENDED LAND PATTERN
2.5
5.0
CIRCUIT DIAGRAM
2.5
Pattern
shorted
1
9
NP2
NS2
8
4.9
2
NP1
3
8.6
18.4
4
1.6
7
NF
5
NS1
6
2.5 2.5 2.5 2.5
Dimensions in mm
(2/9)
20200109
VGT12EEM-200S1A4
Part No.
Inductance
NP
(µH)
Tolerance
Leakage inductance
NP(NS all shorted)
(µH)max.
NP, NF-NS
Coil-Core
Sense: 1mA
Sense: 1mA
Turn ratio
VGT12EEM-200S1A4
10
0.2
2.6kVrms/1min
NP:NF:NS
=1:1.6:2.9
±20%
1.3kVrms/1min
SHAPE & DIMENSIONS
9
6
0.7±0.1
3
5
8.4
(3.2)
14.8±0.5
17.3max.
10.8
(3.2)
8
1
13.6
4
0.4±0.1
3
6
10max.
9
Dimensions in mm
0.13
3
3
3
CIRCUIT DIAGRAM
1
8
NP2
NP1
4.2
2
7
NS1
7.4
1.7
3
3
15.8
3
6
NF
4
5
3
Dimensions in mm
(3/9)
20200109
VGT15EFD-200S3A6
Part No.
Inductance
NP
(µH)
Tolerance
Leakage inductance
NP(NS all shorted)
(µH)max.
NP, NF-NS
Coil-Core
Sense: 1mA
Sense: 1mA
Turn ratio
VGT15EFD-200S3A6
8.0
0.2
2.6kVrms/1min
NP:NF:NS1:NS2:NS3
=1:2.8:2.8:2.8:2.8
±20%
1.3kVrms/1min
SHAPE & DIMENSIONS
16.5
14.0
9.5
7.0
0.7±0.1
2.5
7
+0.5
15.2
(4.4)
18
24 –0.3
(4.4)
12
1
2.5
0.4±0.1
6
9.5
10.2max.
13
16.5
0.13
Dimensions in mm
CIRCUIT DIAGRAM
2.5 4.5 2.5 4.5 2.5
12
1
NF
11
5.4
2
25.4
14.6
NS3
Pattern
shorted
3
10
NS2
9
4
NP2
1.7
Pattern
shorted
5
8
NP1
6
NS1
7
2.5 3.5 3.5 3.5 3.5
Dimensions in mm
(4/9)
20200109
VGT15SEFD-200S1A4
Part No.
Inductance
NP
(µH)
Tolerance
Leakage inductance
NP(NS all shorted)
(µH)max.
NP, NF-NS
Coil-Core
Sense: 1mA
Sense: 1mA
Turn ratio
VGT15SEFD-200S1A4
10
0.2
2.6kVrms/1min
NP:NF:NS
=1:1.8:3.3
±20%
1.3kVrms/1min
SHAPE & DIMENSIONS
12
9
6
0.7±0.1
3
6
13
(3.2)
19.4±0.5
22max.
15.4
(3.2)
10
1
5
15.6
0.4±0.1
3
6
9
10max.
12
Dimensions in mm
0.13
3
3
3
3
CIRCUIT DIAGRAM
10
1
4.2
NP2
NP1
9
2
NS1
12
20.4
3
1.7
3
3
7
4
NF
5
3
8
6
3
Dimensions in mm
(5/9)
20200109
VGT15SEFD-250S4A7
Part No.
Inductance
NP
(µH)
Tolerance
Leakage inductance
NP(NS all shorted)
(µH)max.
NP, NF-NS
Coil-Core
Sense: 1mA
Sense: 1mA
Turn ratio
VGT15SEFD-250S4A7
2.6
0.2
2.6kVrms/1min
=1:3:3:3:3:3
±20%
1.3kVrms/1min
SHAPE & DIMENSIONS
19.7
17.2
11.1
8.6
5.55
0.7±0.1
2.5
8
13.0
12.6
2-ø1.4
(4.4)
21.4±1
15.4
(4.4)
13
1
7
2.5
0.4±0.1
5.8
9.1
12.4
15.45
18.5
21
12max.
23.0
0.15
Dimensions in mm
2.5 6.1
CIRCUIT DIAGRAM
3.3 3.3 3.3 2.5
1
13
NF
NS3
5.4
2
12
4.95
22.8
11.6
4.3
13.0
1.7
3
NP2
Pattern
shorted
11
NS2
4
NP1
10
5
9
2-ø2.0
2.5 6.1
1.25
6.1 2.5
1.25
NS1
6
NS4
8
7
Dimensions in mm
(6/9)
20200109
VGT22EPC-200S6A12
Part No.
Inductance
NP
(µH)
Tolerance
Leakage inductance
NP(NS all shorted)
(µH)max.
NP, NF-NS
Coil-Core
Sense: 1mA
Sense: 1mA
Turn ratio
VGT22EPC-200S6A12
2.5
0.3
2.6kVrms/1min
±15%
1.3kVrms/1min
SHAPE & DIMENSIONS
29.2
26.7
24.2
17.1
14.6
12.1
18±0.5
9
0.4±0.1
3
(4.4)
33±0.5
6
13.1
16.1
20.2
23.2
26.2
29.2
13.7max.
1
2.5
26.8±1
10
24.8±0.5
18
5
(4.4)
0.7±0.1
0.15
Dimensions in mm
CIRCUIT DIAGRAM
2.52.5 7.1 2.52.5 7.1 2.52.5
5.4
1
18
NS4-P
NS1-P
NS4-N
NS1-N
2
17
28.2
17.4
3
1.7
Pattern
shorted
16
15
4
NP1
NS2-P
NP2
NS2-N
14
5
6
3 3
7.1
1.5
4.1 3 3 3
1.5
Dimensions in mm
Pattern
shorted
13
7
12
NS3-P
11
8
NS3-N
9
10
(7/9)
20200109
VGT series
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
Natural
cooling
Peak
T: Temperature
245°C
230°C
230°C
180°C
10s max.
150°C
60 to 120s
Temperature range
Individual
weight
Part No.
Operating
Storage
temperature
temperature
(°C)
(°C)
VGT10SEE-200S2A5
–40 to +130
–40 to +130
VGT12EEM-200S1A4
–40 to +130
–40 to +130
VGT15EFD-200S3A6
–40 to +130
–40 to +130
VGT15SEFD-200S1A4
–40 to +130
–40 to +130
VGT15SEFD-250S4A7
–40 to +130
–40 to +130
VGT22EPC-200S6A12
–40 to +130
–40 to +130
Operating temperature range includes self-temperature rise.
The storage temperature range is for after the assembly.
(g)
1.9
1.9
4.1
3.9
4.6
10.8
30s max.
t: Time
*When mounting the product, use our recommended reflow profile
described above.
PACKAGING STYLE
REEL DIMENSIONS, PACKAGE QUANTITY
2
Part No.
W1
VGT10SEE-200S2A5
VGT12EEM-200S1A4
VGT15EFD-200S3A6
VGT15SEFD-200S1A4
VGT15SEFD-250S4A7
VGT22EPC-200S6A12
36.9
36.9
48.2
48.2
48.2
48.2
Package quantity
(pcs/reel)
250
250
180
200
150
60
Package quantity
(pcs/box)
500
500
360
400
300
120
・These values are typical values.
ø330±2
W1
Dimensions in mm
TAPE DIMENSIONS
W
P1
Part No.
VGT10SEE-200S2A5
VGT12EEM-200S1A4
VGT15EFD-200S3A6
VGT15SEFD-200S1A4
VGT15SEFD-250S4A7
VGT22EPC-200S6A12
P1
20±0.1
20±0.1
28±0.1
24±0.1
28±0.1
44±0.15
W
32±0.3
32±0.3
44±0.3
44±0.3
44±0.3
44±0.3
Dimensions in mm
(8/9)
20200109
Attentions for use
Please read this specifications before using this product by all means.
Attentions for safety
For use of this product, please carefully read this caution and design the application safely.
Attention on designing
On designing a PCB layout, please refer to the land pattern of this catalogue.
As leakage magnetics flux generates, please pay attention to the affection by the flux.
It may be concerned as the cause of a malfunction.
Attention on handling
Please do not use a product which was dropped.
Since the top of the soldered pins are sharpened, please handle with care.
When keeping the products, please avoid any dust, mist, water and sunlight .
In the environment which is exposed by any gas corrosion, i.e. natrium, acid and alkaline atmosphere, please do not use or store.
When assembling, do not apply excess stress to the product by metal base tool.
Attention
This product's structure and number of turns (magnetic design) are designed by consideration of the condition of power voltage and circuit drive (drive
frequency and Max. on-duty).
Do not operate under the out of the range of the designed condition.
It may be any causes of a damage or a burnout.
The range of the operating temperature and humidity, by its consideration of the characteristics of component parts and its self temperature rise.
Do not exceed this range for the operation.
It may be any causes of damage or burnout.
Do not use this product under the condition which is possible contamination of any dust or wrong parts.
It may be any causes of burnout.
The products listed in this specification are intended for use of any general electronic equipment and transportation equipment (AV equipment,
telecommunication applicants, home appliances, amusement equipment, computers, mobile equipment, office machines, measurement equipment,
industrial robots, cars, electric trains, ships and etc.) under a normal operation and condition.
This is not a product which warrants any quality, compatibility or performance to the following uses (hereafter called Special cases of uses) which
malfunction, error or defect in those appliances which are required high level of safeness or reliability, may cause the enormous social impact or the risk
to human life, heath of body, assets or else.
About any damages which are caused by an use which is out of range or beyond the conditions of our specification, or an use in these special cases
below, we are not able to take any responsibilities of the damages.
If your purpose of this product will be an use beyond the scope or conditions of this specification, or for special cases listed below, please contact with
one of our contact windows, in advance.
In order to meet with an application of our customer, we would like to discuss its specification which will be different to this specification.
(1) Aerospace/Aviation
(2) Medical
(3) Power-generation control
(4) Nuclear power generation
(5) Equipment on the sea bed
(6) Transportation control
(7) Public information-processing
(8) Military
(9) Electric heating, burning equipment
(10) Disaster prevention/crime prevention equipment
(11) Safety equipment
(12) Other applications that are not considered as general purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device
or providing backup circuits in your equipment.
(9/9)
20200109
