VLB10050HT-R12M
VLB10050HT-R12M
    TDK(东电化)
    SMD,10.4x7.2mm
    固定电感器 Nonstandard 120nH ±20% 31A 0.35mΩ
VLB10050HT-R12M 数据手册
I N D U C T O R S Inductors for power circuits Wound ferrite VLB series RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free VLB10050 type FEATURES High-current SMD inductor. Low-profile design. High output processing capacity: Minimal copper loss High saturation current and low DC resistance. High operating frequency: Up to 2MHz Operating temperature range: –40 to +125°C (including self-temperature rise) APPLICATION Personal computers, servers (Voltage Regulator Modules, etc.) Amusement equipment, AV equipment, etc. PART NUMBER CONSTRUCTION VLB 10050 H T - Series name L×W×H dimensions 10.2×7.0×5.0 mm max. Characteristics Packaging style R12 M Inductance (nH) Inductance tolerance CHARACTERISTICS SPECIFICATION TABLE L Measuring frequency DC resistance Rated current Isat (nH) Tolerance (MHz) (m ) Tolerance(%) (A)typ. 120 ±20% 1 0.35 ±6 68 150 ±20% 1 0.35 ±6 52 200 ±20% 1 0.35 ±6 37 300 ±30% 1 0.35 ±6 21  Rated current: smaller value of either Isat or Itemp. Isat: When based on the inductance change rate (20% below the nominal value) Itemp: When based on the temperature increase (temperature increase of 40°C by self heating) Part No. Itemp (A)typ. 31 31 31 31 VLB10050HT-R12M VLB10050HT-R15M VLB10050HT-R20M VLB10050HT-R30N Measurement equipment Measurement item Product No. L 4194A DC resistance 3541 Rated current Isat 3260+3265B * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies HIOKI Wayne Kerr Electronics Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20180802 inductor_commercial_power_vlb10050_en.fm I N D U C T O R S VLB10050 type L FREQUENCY CHARACTERISTICS 400 360 320 R30M Inductance(nH) 280 240 200 R20M 160 R15M 120 R12M 80 40 0 100 1000 10000 100000 Frequency(kHz) Measurement equipment Product No. Manufacturer 4294A Keysight Technologies * Equivalent measurement equipment may be used. INDUCTANCE VS. DC BIAS CHARACTERISTICS 400 R30M Inductance(nH) 300 R20M 200 R15M R12M 100 0 0 10 20 30 40 DC current (A) 50 60 70 80 Measurement equipment Product No. Manufacturer 3260B+3265B Wayne Kerr Electronics * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/4) 20180802 inductor_commercial_power_vlb10050_en.fm I N D U C T O R S VLB10050 type SHAPE & DIMENSIONS PACKAGING STYLE REEL DIMENSIONS 2.5±0.1 6.7±0.3 4.8±0.2 2 6.8±0.3 ø100 9.2±0.3 2.0±0.5 9.8±0.4 Dimensions in mm (1.0) ø13.0±0.5 25.5 ø21.0±0.8 30.4 ø330 Dimensions in mm 6.4 2.0 1.5 +0.1 –1 2.0±0.1 4.0±0.1 Sprocket hole 24.0±0.3 B 3.0 3.0 0.5 11.5±0.1 2.0 1.75±0.1 TAPE DIMENSIONS RECOMMENDED LAND PATTERN Dimensions in mm Cavity K A 12.0±0.1 Dimensions in mm Type VLB10050 RECOMMENDED REFLOW PROFILE Preheating Soldering Natural cooling Peak Temperature B 10.4 K 5.2 PACKAGE QUANTITY Package quantity 500 pcs/reel TEMPERATURE RANGE, INDIVIDUAL WEIGHT 250°C 230°C A 7.2 230°C Operating Storage Individual temperature range temperature range weight –40 to +125 °C –40 to +125°C 1.40 g  Operating temperature range includes self-temperature rise.  The storage temperature range is for after the assembly. 180°C 5s 150°C 60 to 120s 30s Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20180802 inductor_commercial_power_vlb10050_en.fm I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is less than 6 months. Be sure to follow the storage conditions (temperature: 5 to 30°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20180802 inductor_commercial_power_vlb10050_en.fm
VLB10050HT-R12M 价格&库存
很抱歉,暂时无法提供与“VLB10050HT-R12M”相匹配的价格&库存,您可以联系我们找货
VLB10050HT-R12M
  • 500+15.00407500+1.95017
  • 1000+14.150331000+1.83920
  • 1500+13.674271500+1.77732
  • 2500+13.122092500+1.70556
库存:1899
VLB10050HT-R12M
  • 1+25.932881+3.37064
  • 10+21.3212810+2.77125
  • 100+17.53291100+2.27885
库存:1899
