I N D U C T O R S
Inductors for power circuits
Wound ferrite
VLBU series
VLBU10060120 type
■ FEATURES
◯ Large current and lower DCR were achieved by the connecting wire-less structure.
◯ This is a narrow inductor for multiphase operation, such as Vcore regulators, Voltage Regulator Modules (VRMs), Point-of-Load, and
memory power applications.
◯ Support in PMIC Evaluation Kits.
◯ VLBU series is satisfied high efficiency requirements for VR13 and VR14 applications.
◯ Operating temperature range: –40 to +125°C (including self-temperature rise)
■ APPLICATION
◯ Servers, BTS, VRM, others
■ PART NUMBER CONSTRUCTION
VLBU
10060120
T
Series name
L×W×H dimensions
10.0×6.0×12.0mm max.
Packaging
style
R10
L
Inductance
(µH)
Inductance
tolerance
■ CHARACTERISTICS SPECIFICATION TABLE
L
Measuring
frequency
DC resistance
Rated current*
Isat
Part No.
Itemp
(μH)
Tolerance
(kHz)
(mΩ)typ.
Tolerance
(A)typ.
(A)typ.
0.10
0.12
0.15
0.47
±15%
±15%
±15%
±15%
100
100
100
100
0.12
0.12
0.12
0.12
±10%
±10%
±10%
±10%
137
114
92
24
83
83
83
83
VLBU10060120T-R10L
VLBU10060120T-R12L
VLBU10060120T-R15L
VLBU10060120T-R47L
* Rated current: smaller value of either Isat or Itemp.
Isat: When based on the inductance change rate (20% below the nominal value, under an environment of 20°C)
Itemp: When based on the temperature increase (temperature increase of 40°C by self heating)
□ Measurement equipment
Measurement item
Product No.
L
IM3536
DC resistance
RM3545
Rated current Isat
3260+3265B
* Equivalent measurement equipment may be used.
Manufacturer
HIOKI
HIOKI
Wayne Kerr Electronics
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/4)
20221117
inductor_commercial_power_vlbu10060120_en.xml
I N D U C T O R S
VLBU10060120 type
■ L FREQUENCY CHARACTERISTICS
1000
R47L
R12L
Inductance (nH)
R15L
100
R10L
10
1
0.01
0.1
1
Frequency (MHz)
10
100
Product No.
Manufacturer
4294A
Keysight Technologies
■ INDUCTANCE VS. DC BIAS CHARACTERISTICS
600
500
Inductance(nH)
R47L
400
300
200
R15L
R12L
100
R10L
60
80
DC current (A)
100
120
140
160
Product No.
Manufacturer
3260B+3265B
(2/4)
20221117
I N D U C T O R S
VLBU10060120 type
■ SHAPE & DIMENSIONS
6.0max.
■ PACKAGING STYLE
(2.5)
12.0max.
□ REEL DIMENSIONS
2
ø100
(3.45)
10.0 max.
2.0±0.5
(1.0)
■ RECOMMENDED LAND PATTERN
3.2
3.9
ø13.0±0.5
3.2
24.4
ø21.0±0.8
30.4
3.3
□ TAPE DIMENSIONS
1.5 +0.1
–1
Preheating
Soldering
4.0±0.1
Sprocket
hole
B
■ RECOMMENDED REFLOW PROFILE
2.0±0.1
24.0±0.3
0.5
Natural
cooling
Cavity
K
Peak
A
12.0±0.1
Dimensions in mm
250°C
Temperature
230°C
1.75±0.1
Dimensions in mm
11.5±0.1
3.3
ø330
230°C
Type
A
B
K
VLBU10060120
(6.1)
(10.1)
(12.2)
□ PACKAGE QUANTITY
180°C
Package quantity
300 pcs/reel
5s
150°C
60 to 120s
30s
Time
■ TEMPERATURE RANGE, INDIVIDUAL WEIGHT
Operating
temperature range *
Storage
temperature range **
Individual
weight
-40 to +125 °C
-40 to +125 °C
3.1 g
* Operating temperature range includes self-temperature rise.
** The storage temperature range is for after the assembly.
(3/4)
20221117
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products
REMINDERS
○ The storage period is within 6 months. Be sure to follow the storage conditions (temperature: 5 to 30°C, humidity: 10 to 75% RH or less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
○ Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
○ Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
○ Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
○ When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the
overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
○ Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
○ Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
○ Use a wrist band to discharge static electricity in your body through the grounding wire.
○ Do not expose the products to magnets or magnetic fields.
○ Do not use for a purpose outside of the contents regulated in the delivery specifications.
○ The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
(4/4)
20221117
很抱歉,暂时无法提供与“VLBU10060120T-R12L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+19.409921+2.52383
- 10+15.9898210+2.07912
- 100+13.15096100+1.70999
- 国内价格
- 300+12.10310
- 600+11.58318
- 900+11.16000
- 3600+10.64009
- 10800+10.30154
- 国内价格 香港价格
- 300+11.75040300+1.52788
- 600+11.08088600+1.44082
- 900+10.70725900+1.39224
- 1500+10.254981500+1.33343
- 2100+9.967822100+1.29609
- 3000+9.672553000+1.25770
