VLBU805080T-R10L
VLBU805080T-R10L
    TDK(东电化)
    固定电感器 Nonstandard 100nH ±15% 65A 0.2mΩ
VLBU805080T-R10L 数据手册
I N D U C T O R S Inductors for power circuits Wound ferrite VLBU series RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free VLBU805080 type FEATURES Large current and lower DCR were achieved by the connecting wire-less structure. This is a narrow inductor for multiphase applications. Operating temperature range: –40 to +125°C (including self-temperature rise) APPLICATION Servers, BTS, VRM, others PART NUMBER CONSTRUCTION VLBU 805080 T - Series name L×W×H dimensions 8.0x5.0x8.0mm max. Packaging style R10 L Inductance (µH) Inductance tolerance CHARACTERISTICS SPECIFICATION TABLE L Measuring frequency DC resistance Rated current Part No. Isat Itemp (µH) Tolerance (kHz) (m )typ. Tolerance (A)typ. (A)typ. 0.10 ±15% 100 0.20 75 65 VLBU805080T-R10L ±7% 0.12 ±15% 100 0.20 61 65 VLBU805080T-R12L ±7% 0.18 ±15% 100 0.20 34 65 VLBU805080T-R18L ±7%  Rated current: smaller value of either Isat or Itemp. Isat: When based on the inductance change rate (20% below the nominal value, under an environment of 20°C) Itemp: When based on the temperature increase (temperature increase of 40°C by self heating) Measurement equipment Measurement item Product No. L IM3536 DC resistance RM3545 Rated current Isat 3260+3265B * Equivalent measurement equipment may be used. Manufacturer HIOKI HIOKI Wayne Kerr Electronics Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20190717 inductor_commercial_power_vlbu805080_en.fm I N D U C T O R S VLBU805080 type L FREQUENCY CHARACTERISTICS Inductance (µH) 0.3 0.2 R18L R12L 0.1 R10L 0 0.1 1 10 100 Frequency (MHz) Measurement equipment Product No. Manufacturer 4294A Keysight Technologies * Equivalent measurement equipment may be used. INDUCTANCE VS. DC BIAS CHARACTERISTICS 250 200 Inductance(nH) R18L 150 R12L 100 R10L 50 0 0 10 20 30 40 DC current (A) 50 60 70 80 Measurement equipment Product No. Manufacturer 3260B+3265B Wayne Kerr Electronics * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/4) 20190717 inductor_commercial_power_vlbu805080_en.fm I N D U C T O R S VLBU805080 type SHAPE & DIMENSIONS 8.0max. PACKAGING STYLE (1.8) 8.0max. REEL DIMENSIONS (1.8) 2 (1.9) 5.0max. 2.0±0.5 (4.2) ø100 Dimensions in mm (1.0) ø13.0±0.5 24.4 ø21.0±0.8 30.4 ø330 Dimensions in mm 2.2 1.5 +0.1 –0 2.0±0.1 4.0±0.1 Sprocket hole 24.0±0.3 2.5 0.5 11.5±0.1 2.2 1.75±0.1 TAPE DIMENSIONS RECOMMENDED LAND PATTERN B 8.5 Dimensions in mm Cavity K A 12.0±0.1 Dimensions in mm Type VLBU805080 RECOMMENDED REFLOW PROFILE Preheating Soldering Natural cooling Peak Temperature B (8.1) K (8.1) PACKAGE QUANTITY Package quantity 600 pcs/reel TEMPERATURE RANGE, INDIVIDUAL WEIGHT 250°C 230°C A (5.1) 230°C Operating Storage Individual temperature range temperature range weight –40 to +125 °C –40 to +125°C 1.28 g  Operating temperature range includes self-temperature rise.  The storage temperature range is for after the assembly. 180°C 5s 150°C 60 to 120s 30s Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20190717 inductor_commercial_power_vlbu805080_en.fm I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is within 6 months. Be sure to follow the storage conditions (temperature: 5 to 30°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20190717 inductor_commercial_power_vlbu805080_en.fm
VLBU805080T-R10L 价格&库存
很抱歉,暂时无法提供与“VLBU805080T-R10L”相匹配的价格&库存,您可以联系我们找货
VLBU805080T-R10L
  • 1+16.342131+2.11688
  • 10+13.4614310+1.74373
  • 100+11.07099100+1.43408
