I N D U C T O R S
Inductors for power circuits
Wound ferrite
VLCF series
RoHS
REACH
SVHC-Free
Cl
Br
Pb
Halogen
Free
Lead
Free
VLCF4028-2 type
FEATURES
Magnetic shield type wound inductor for power circuits.
Low-profile product.
Magnetic shield construction with ferrite core.
Operating temperature range: –40 to +105°C (including self-temperature rise)
APPLICATION
Power source inductor for mobile devices such as HDDs, DVCs, and DSCs
LCDs, other DC to DC converters
PART NUMBER CONSTRUCTION
VLCF
4028
T
Series name
L×W×H dimensions
4.0×4.0×2.8 mm
Packaging style
1R2
N
2R7
Inductance
(µH)
Inductance
tolerance
Rated current
(A)
2
Internal code
CHARACTERISTICS SPECIFICATION TABLE
L
Measuring
frequency
DC resistance
Rated current
Isat
(µH)
Tolerance
(kHz)
( )max.
( )typ.
(A)max.
1.2
±30%
100
0.032
0.027
2.71
1.6
±30%
100
0.038
0.032
2.31
2.2
±30%
100
0.043
0.037
1.94
2.7
±30%
100
0.049
0.043
1.89
4.7
±30%
100
0.062
0.054
1.57
6.8
±30%
100
0.1
0.09
1.36
10
±20%
100
0.14
0.12
1.06
15
±20%
100
0.17
0.15
0.88
22
±20%
100
0.24
0.21
0.72
33
±20%
100
0.35
0.3
0.61
47
±20%
100
0.49
0.42
0.48
100
±20%
100
1
0.87
0.33
470
±20%
100
4.58
3.98
0.14
Rated current: smaller value of either Isat or Itemp.
Isat: When based on the inductance change rate (30% below the initial value)
Itemp: When based on the temperature increase (temperature increase of 40°C by self heating)
Part No.
Itemp
(A)typ.
3.11
2.85
2.63
2.46
2.18
1.69
1.45
1.05
0.9
0.74
0.68
0.55
0.25
VLCF4028T-1R2N2R7-2
VLCF4028T-1R6N2R3-2
VLCF4028T-2R2N1R9-2
VLCF4028T-2R7N1R8-2
VLCF4028T-4R7N1R5-2
VLCF4028T-6R8N1R3-2
VLCF4028T-100M1R0-2
VLCF4028T-150MR88-2
VLCF4028T-220MR72-2
VLCF4028T-330MR61-2
VLCF4028T-470MR48-2
VLCF4028T-101MR33-2
VLCF4028T-471MR14-2
Measurement equipment
Measurement item
Product No.
L
4194A
DC resistance
VP-2941A
Rated current Isat
4285A+42841A+42842C
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
Panasonic
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/5)
20180831
inductor_commercial_power_vlcf4028-2_en.fm
I N D U C T O R S
VLCF4028-2 type
L FREQUENCY CHARACTERISTICS
10000
471M
1000
101M
470M
330M
100
220M
150M
Inductance(µH)
100M
6R8N
10
4R7N
2R7N
2R2N
1R6N
1
1R2N
0.1
0.01
0.01
0.1
1
Frequency(MHz)
10
100
Product No.
Manufacturer
4294A
(2/5)
20180831
I N D U C T O R S
VLCF4028-2 type
INDUCTANCE VS. DC BIAS CHARACTERISTICS
100
101M
470M
330M
220M
150M
10
100M
Inductance(µH)
6R8N
4R7N
2R7N
2R2N
1R6N
1R2N
1
0.1
0.0
1.0
2.0
3.0
4.0
5.0
DCcurrent (A)
Product No.
Manufacturer
4285A+42841A+42842C
(3/5)
20180831
I N D U C T O R S
VLCF4028-2 type
SHAPE & DIMENSIONS
PACKAGING STYLE
REEL DIMENSIONS
4.0±0.1
0.5
1.3
ø60
1.35
4.0±0.1
4R7
4.3max.
1.35
2.0±0.5
2.8max.
2
(1.0)
Dimensions in mm
ø13.0±0.5
13
ø21.0±0.8
17
ø180
Dimensions in mm
0.4
1.55±0.05
2.00±0.05 4.0±0.1
Sprocket
hole
4.5
1.3
B
1.6
12.0±0.2
45°
5.5±0.1
RECOMMENDED LAND PATTERN
1.75±0.1
TAPE DIMENSIONS
K
Cavity
A
1.6
8.0±0.1
Dimensions in mm
2.5
3.9
Type
VLCF4028-2
Dimensions in mm
Package quantity
Soldering
Natural
cooling
Peak
260°C
Temperature
200°C
B
4.4
K
3
PACKAGE QUANTITY
RECOMMENDED REFLOW PROFILE
Preheating
A
4.4
200°C
500 pcs/reel
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
Operating
Storage
Individual
temperature range
temperature range
weight
–40 to 105 °C
–40 to 105 °C
159 mg
Operating temperature range includes self-temperature rise.
The storage temperature range is for after the assembly.
150°C
5s
130°C
110s
90s
Time
(4/5)
20180831
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is less than 6 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(5/5)
20180831
VLCF4028T-101MR33-2 价格&库存
很抱歉,暂时无法提供与“VLCF4028T-101MR33-2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+3.15136500+0.40889
- 1000+2.971401000+0.38554
- 1500+2.870971500+0.37251
- 2500+2.749442500+0.35674
- 3500+2.672233500+0.34672
- 5000+2.592855000+0.33642
- 国内价格 香港价格
- 1+5.477891+0.71076
- 10+4.4773510+0.58094
- 100+3.68396100+0.47799
- 国内价格
- 1+1.72220
- 10+1.41260
- 30+1.23500
- 100+1.09690
- 500+1.02600
- 1000+0.98280
