VLCF5020T-101MR27
VLCF5020T-101MR27
    TDK(东电化)
    SMD,5x5mm
    固定电感器 Nonstandard 100µH ±20% 270mA 1.581Ω
VLCF5020T-101MR27 数据手册
(1/1) SMD Inductors(Coils) For Power Line(Wound, Magnetic Shielded) VLCF Series VLCF5020 FEATURES • Miniature size Mount area: 5× 5mm Height: 2.0mm max. • Generic use for portable DC to DC converter line • High magnetic shield construction should actualize high resolution for EMC protection. • Available for automatic mounting in tape and real package. • The products do not contain lead and support lead-free soldering. APPLICATIONS DC to DC converters for DVC, DSC, PDA, MD, LCD displays, HDDs, etc. SHAPES AND DIMENSIONS 5.0±0.2 Conformity to RoHS Directive 4R7 2.0max. 5.3max. (Include solder) Dimensions in mm 1.2 Dimensions in mm RECOMMENDED PC BOARD PATTERN 45˚ 2.1 2.1 1.3 3.0 4.9 ELECTRICAL CHARACTERISTICS Part No. VLCF5020T-1R8N2R0 VLCF5020T-2R7N2R7 VLCF5020T-3R3N1R6 VLCF5020T-4R7N1R4 VLCF5020T-6R8N1R1 VLCF5020T-100MR87 VLCF5020T-150MR71 VLCF5020T-220MR58 VLCF5020T-330MR48 VLCF5020T-470MR40 VLCF5020T-101MR27 ∗ 5.0±0.2 Inductance (µH) 1.8 2.7 3.3 4.7 6.8 10 15 22 33 47 100 Inductance tolerance ±30% ±30% ±30% ±30% ±30% ±20% ±20% ±20% ±20% ±20% ±20% Test frequency (kHz) 100 100 100 100 100 100 100 100 100 100 100 DC resistance(Ω) max. 0.059 0.071 0.083 0.096 0.122 0.182 0.256 0.373 0.522 0.748 1.581 typ. 0.049 0.058 0.069 0.079 0.102 0.151 0.214 0.311 0.435 0.623 1.375 Rated current(A)∗ Based on inductance change max. 2.07 1.76 1.6 1.4 1.11 0.87 0.71 0.58 0.48 0.40 0.27 Based on temperature rise typ. 2.75 2.51 2.31 2.15 1.9 1.56 1.3 1.1 0.92 0.77 0.52 Rated current: Value obtained when current flows and the temperature has risen to 40°C or when DC current flows and the nominal value of inductance has fallen by 30%, whichever is smaller. • Operating temperature range: –40 to +105°C (Including self-temperature rise) • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 001-08 / 20070710 / e531_vlcf5020.fm
VLCF5020T-101MR27 价格&库存
很抱歉,暂时无法提供与“VLCF5020T-101MR27”相匹配的价格&库存,您可以联系我们找货
VLCF5020T-101MR27
    • 1+3.88800
    • 10+3.14280
    • 30+2.77560
    • 100+2.40840
    • 500+2.19240
    库存:478
    VLCF5020T-101MR27
    • 1+4.770041+0.61701
    • 10+3.9003310+0.50451
    • 100+3.20436100+0.41449
    VLCF5020T-101MR27
    • 1+4.595131+0.59438
    • 10+3.9574110+0.51189
    • 25+3.6167025+0.46782
    • 50+3.3720950+0.43618
    • 100+3.14496100+0.40680
    • 250+2.87414250+0.37177
    • 500+2.84794500+0.36838
    库存:245
