VLCF5020T-220MR58
VLCF5020T-220MR58
    TDK(东电化)
    SMD,5x5mm
    固定电感器 Nonstandard 22µH ±20% 580mA 373mΩ
VLCF5020T-220MR58 数据手册
(1/1) SMD Inductors(Coils) For Power Line(Wound, Magnetic Shielded) VLCF Series VLCF5020 FEATURES • Miniature size Mount area: 5× 5mm Height: 2.0mm max. • Generic use for portable DC to DC converter line • High magnetic shield construction should actualize high resolution for EMC protection. • Available for automatic mounting in tape and real package. • The products do not contain lead and support lead-free soldering. APPLICATIONS DC to DC converters for DVC, DSC, PDA, MD, LCD displays, HDDs, etc. SHAPES AND DIMENSIONS 5.0±0.2 Conformity to RoHS Directive 4R7 2.0max. 5.3max. (Include solder) Dimensions in mm 1.2 Dimensions in mm RECOMMENDED PC BOARD PATTERN 45˚ 2.1 2.1 1.3 3.0 4.9 ELECTRICAL CHARACTERISTICS Part No. VLCF5020T-1R8N2R0 VLCF5020T-2R7N2R7 VLCF5020T-3R3N1R6 VLCF5020T-4R7N1R4 VLCF5020T-6R8N1R1 VLCF5020T-100MR87 VLCF5020T-150MR71 VLCF5020T-220MR58 VLCF5020T-330MR48 VLCF5020T-470MR40 VLCF5020T-101MR27 ∗ 5.0±0.2 Inductance (µH) 1.8 2.7 3.3 4.7 6.8 10 15 22 33 47 100 Inductance tolerance ±30% ±30% ±30% ±30% ±30% ±20% ±20% ±20% ±20% ±20% ±20% Test frequency (kHz) 100 100 100 100 100 100 100 100 100 100 100 DC resistance(Ω) max. 0.059 0.071 0.083 0.096 0.122 0.182 0.256 0.373 0.522 0.748 1.581 typ. 0.049 0.058 0.069 0.079 0.102 0.151 0.214 0.311 0.435 0.623 1.375 Rated current(A)∗ Based on inductance change max. 2.07 1.76 1.6 1.4 1.11 0.87 0.71 0.58 0.48 0.40 0.27 Based on temperature rise typ. 2.75 2.51 2.31 2.15 1.9 1.56 1.3 1.1 0.92 0.77 0.52 Rated current: Value obtained when current flows and the temperature has risen to 40°C or when DC current flows and the nominal value of inductance has fallen by 30%, whichever is smaller. • Operating temperature range: –40 to +105°C (Including self-temperature rise) • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 001-08 / 20070710 / e531_vlcf5020.fm
VLCF5020T-220MR58
物料型号: - VLCF5020T-1R8N2R0 - VLCF5020T-2R7N2R7 - VLCF5020T-3R3N1R6 - VLCF5020T-4R7N1R4 - VLCF5020T-100MR87 - VLCF5020T-6R8N1R1 - VLCF5020T-150MR71 - VLCF5020T-220MR58 - VLCF5020T-330MR48 - VLCF5020T-470MR40 - VLCF5020T-101MR27
器件简介: - 该系列电感器具有微型尺寸,安装面积为5×5mm,最大高度为2.0mm。 - 适用于便携式DC-DC转换器线路。 - 高磁屏蔽结构有助于实现EMC保护的高分辨率。 - 支持自动卷带和实包装安装。 - 产品无铅,支持无铅焊接。
引脚分配: - 由于是SMD电感器,引脚通过焊盘实现,具体分配需参考PCB布局图。
参数特性: - 直流电阻(Ω)和额定电流(A)根据不同型号有所不同,例如VLCF5020T-1R8N2R0型号的直流电阻最大值为0.059Ω,典型值为0.049Ω,额定电流为100A。 - 电感值、公差和测试频率也因型号而异。
功能详解: - 适用于DVC、DSC、PDA、MD、LCD显示器、硬盘驱动器等的DC-DC转换器。
应用信息: - 适用于多种电子设备的DC-DC转换器,如数字摄像机、数字相机、个人数字助理、音乐播放器、液晶显示器和硬盘驱动器等。
封装信息: - 封装尺寸和形状在文档中有详细图纸说明,具体尺寸以毫米为单位标注。
VLCF5020T-220MR58 价格&库存
很抱歉,暂时无法提供与“VLCF5020T-220MR58”相匹配的价格&库存,您可以联系我们找货
VLCF5020T-220MR58
  • 1+3.03043
  • 25+2.70583
  • 50+2.55730
  • 100+2.52017
库存:46
VLCF5020T-220MR58
  • 500+2.74305500+0.35591
  • 1000+2.586401000+0.33559
  • 1500+2.498981500+0.32424
  • 2500+2.393162500+0.31051
  • 3500+2.325963500+0.30179
  • 5000+2.256825000+0.29282
库存:7175
