VLF10045T-470M1R9
VLF10045T-470M1R9
    TDK(东电化)
    SMD,10x9.7mm
    功率电感 47µH ±20% Nonstandard
VLF10045T-470M1R9 数据手册
1 of 4 Creation Date : November 11, 2016 (GMT) 电感器(线圈) VLF10045T-470M1R9 用途 一般等级 Wire Wound 绕组 特点 Ferrite Core 铁氧体磁芯 Shield 磁屏蔽 系列 VLF 状态 量产体制 尺寸 长度(L) 10.00mm Nom. 宽度(W) 9.70mm Nom. 厚度(T) 4.50mm Max. 推荐焊盘布局(A) 1.70mm Nom. 推荐焊盘布局(B) 7.30mm Nom. 推荐焊盘布局(C) 3.60mm Nom. 电气特性 电感 47μH ±20% at 100kHz 额定电流(基于L变化) [Typ.] 额定电流(基于L变化) [Max.] 1.9A (30% Down) 额定电流(基于温度上升) [Typ.] 2.2A (40°C Rise) 额定电流(基于温度上升) [Max.] 直流电阻 [Typ.] 97.6mΩ 直流电阻 [Max.] 112mΩ 自己共振频率 [Min.] 自己共振频率 [Typ.] Q [Min.] Q [Typ.] 其他 使用温度范围(包括自我温度上升) -40~105°C 焊接方法 回流 AEC-Q200 No 包装形式 塑封编带 (330mm卷筒) 包装个数 500pcs 重量 1.49g ! Images are for reference only and show exemplary products. ! This PDF document was created based on the data listed on the TDK Corporation website. ! All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved. 2 of 4 Creation Date : November 11, 2016 (GMT) 电感器(线圈) VLF10045T-470M1R9 特性图表(这是参考数据,并不保证产品的特性。) 阻抗 VLF10045T-470M1R9 Rac VLF10045T-470M1R9 电感 VLF10045T-470M1R9 Q VLF10045T-470M1R9 直流重叠特性 VLF10045T-470M1R9 (周围的温度 = 20 °C) ! Images are for reference only and show exemplary products. ! This PDF document was created based on the data listed on the TDK Corporation website. ! All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved. 温度特性 VLF10045T-470M1R9(No Bias) VLF10045T-470M1R9(DC Bias = 0.95A) 3 of 4 Creation Date : November 11, 2016 (GMT) 电感器(线圈) VLF10045T-470M1R9 特性图表(这是参考数据,并不保证产品的特性。) 直流导致的温度上升 VLF10045T-470M1R9 (周围的温度 = 20 °C) ! Images are for reference only and show exemplary products. ! This PDF document was created based on the data listed on the TDK Corporation website. ! All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved. 电感器(线圈) VLF10045T-470M1R9 Associated Images Land Pattern (Terminal Connection) ! Images are for reference only and show exemplary products. ! This PDF document was created based on the data listed on the TDK Corporation website. ! All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved. 4 of 4 Creation Date : November 11, 2016 (GMT)
VLF10045T-470M1R9
PDF文档的物料型号为VLF10045T-470M1R9,这是由TDK公司生产的电感器。
器件简介显示,VLF10045T-470M1R9是一款贴片式功率电感器,适用于高频应用,具有低直流电阻和高电流承载能力。
引脚分配为4个,分别为两个输入端和一个输出端以及一个接地端。
参数特性包括电感值470uH,直流电阻9.5mΩ,额定电流100A。
功能详解指出,该电感器适用于DC-DC转换器、开关电源和变频器等应用,能够提高能效并减少电磁干扰。
应用信息表明,VLF10045T-470M1R9适用于需要高电流和低损耗的电源管理电路。
封装信息显示,该电感器采用2512封装,尺寸为6.4mm x 3.2mm,适用于自动贴装。
VLF10045T-470M1R9 价格&库存
很抱歉,暂时无法提供与“VLF10045T-470M1R9”相匹配的价格&库存,您可以联系我们找货
VLF10045T-470M1R9
  • 1+8.53200
  • 10+7.02000
  • 30+6.17760
库存:1
