VLF3012AT-100MR49
VLF3012AT-100MR49
    TDK(东电化)
    SMD,2.8x2.6mm
    3012 10uH ±20% DCR=410mΩ 490mA
VLF3012AT-100MR49 数据手册
1 of 4 Creation Date : November 11, 2016 (GMT) 电感器(线圈) VLF3012AT-100MR49 用途 一般等级 Wire Wound 绕组 特点 Ferrite Core 铁氧体磁芯 Shield 磁屏蔽 系列 VLF 状态 量产体制 尺寸 长度(L) 2.80mm Nom. 宽度(W) 2.60mm Nom. 厚度(T) 1.20mm Max. 推荐焊盘布局(A) 0.65mm Nom. 推荐焊盘布局(B) 2.10mm Nom. 推荐焊盘布局(C) 1.20mm Nom. 电气特性 电感 10μH ±20% at 100kHz 额定电流(基于L变化) [Typ.] 额定电流(基于L变化) [Max.] 490mA (30% Down) 额定电流(基于温度上升) [Typ.] 670mA (40°C Rise) 额定电流(基于温度上升) [Max.] 直流电阻 [Typ.] 360mΩ 直流电阻 [Max.] 410mΩ 自己共振频率 [Min.] 自己共振频率 [Typ.] Q [Min.] Q [Typ.] 其他 使用温度范围(包括自我温度上升) -40~105°C 焊接方法 回流 AEC-Q200 No 包装形式 塑封编带 (180mm卷筒) 包装个数 2000pcs 重量 0.027g ! Images are for reference only and show exemplary products. ! This PDF document was created based on the data listed on the TDK Corporation website. ! All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved. 2 of 4 Creation Date : November 11, 2016 (GMT) 电感器(线圈) VLF3012AT-100MR49 特性图表(这是参考数据,并不保证产品的特性。) 阻抗 VLF3012AT-100MR49 Rac VLF3012AT-100MR49 电感 VLF3012AT-100MR49 Q VLF3012AT-100MR49 直流重叠特性 VLF3012AT-100MR49 (周围的温度 = 20 °C) ! Images are for reference only and show exemplary products. ! This PDF document was created based on the data listed on the TDK Corporation website. ! All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved. 温度特性 VLF3012AT-100MR49(No Bias) VLF3012AT-100MR49(DC Bias = 0.25A) 3 of 4 Creation Date : November 11, 2016 (GMT) 电感器(线圈) VLF3012AT-100MR49 特性图表(这是参考数据,并不保证产品的特性。) 直流导致的温度上升 VLF3012AT-100MR49 (周围的温度 = 20 °C) ! Images are for reference only and show exemplary products. ! This PDF document was created based on the data listed on the TDK Corporation website. ! All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved. 电感器(线圈) VLF3012AT-100MR49 Associated Images Land Pattern (Terminal Connection) ! Images are for reference only and show exemplary products. ! This PDF document was created based on the data listed on the TDK Corporation website. ! All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved. 4 of 4 Creation Date : November 11, 2016 (GMT)
VLF3012AT-100MR49 价格&库存
很抱歉,暂时无法提供与“VLF3012AT-100MR49”相匹配的价格&库存,您可以联系我们找货
VLF3012AT-100MR49
    • 1+19.135471+2.47872
    • 10+14.3039510+1.85287
    • 30+10.8398430+1.40414
    • 50+10.1519950+1.31504
    • 100+9.62989100+1.24741
    • 300+9.28182300+1.20232
    • 500+9.21552500+1.19374
    库存:1961
