VLF302515MT-1R0N-CA
VLF302515MT-1R0N-CA
    TDK(东电化)
    IND-2P_2.5X3MM_SM
    VLF302515MT-1R0N-CA
VLF302515MT-1R0N-CA 数据手册
1 of 3 Creation Date :January 11 2016 VLF302515MT-1R0N-CA Applications Automotive Grade Feature Wire Wound Magnetic Shield Ferrite Core Series VLF-M Series / VLF302515MT-CA Type Status Production Size Length(L) 3.00mm +/-0.20mm Width(W) 2.50mm +/-0.20mm Thickness(T) 1.50mm Max. Recommended Land Pattern (A) 0.90mm Nom. Recommended Land Pattern (B) 0.80mm Nom. Recommended Land Pattern (C) 1.45mm Nom. Electrical Characteristics Inductance 1uH +/-30% at 1MHz Rated Current (L Change) [Typ.] 2.15A (30% Down) Rated Current (L Change) [Max.] 1.94A (30% Down) Rated Current (Temperature Rise) [Typ.] 3.31A (40degC Rise) DC Resistance [Nom.] 25mΩ DC Resistance [Max.] 30mΩ Other Operating Temp. Range (Including Self-Temp. Rise) -40 to 105degC Soldering Method Reflow AEC Q200 No Packing Blister (Plastic)Taping [180mm Reel] Package Quantity 2000Pcs Min. Weight 0.041g •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved 2 of 3 Creation Date :January 11 2016 VLF302515MT-1R0N-CA VLF302515MT-1R0N-CA VLF302515MT-1R0N-CA VLF302515MT-1R0N-CA VLF302515MT-1R0N-CA •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved 3 of 3 Creation Date :January 11 2016 VLF302515MT-1R0N-CA VLF302515MT-1R0N-CA(Amb. Temp. = 20degc) VLF302515MT-1R0N-CA(Amb. Temp. = 20degc) •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved VLF302515MT-1R0N-CA(DC = 0A) VLF302515MT-1R0N-CA(DC = 0.97A)
VLF302515MT-1R0N-CA
物料型号为VLF302515MT-1R0N-CA。
以下是该物料的详细分析:
器件简介: - 该物料是TDK公司生产的线圈电感器,属于VLF-M系列。
- 电感器采用线绕制造工艺,具有磁屏蔽功能。
- 电感器采用铁氧体核心,适用于汽车级应用。
引脚分配: - 电感器的引脚分配信息在文档中未明确提及,但通常线圈电感器会有至少两个引脚,用于连接电路。
参数特性: - 电感值:1uH,公差为±30%。
- 额定电流(L变化):典型值为2.15A(电感下降30%),最大值为1.94A(电感下降30%)。
- 额定电流(温升):典型值为3.31A(温升40°C)。
- 直流电阻:典型值为25mΩ,最大值为30mΩ。
- 工作温度范围:-40至105°C。
功能详解: - 电感器具有线绕结构,可用于滤波、储能和信号处理等应用。
- 磁屏蔽功能有助于减少电磁干扰。
应用信息: - 该电感器符合RoHS标准,不含铅和卤素,符合REACH法规。
- 适用于汽车级应用。
封装信息: - 电感器的尺寸为3.00mm(长度)× 2.50mm(宽度)× 1.50mm(厚度)。
- 推荐的焊盘图案尺寸为A(0.90mm)、B(0.80mm)和C(1.45mm)。
- 封装方式为塑料泡罩包装,每卷180mm。
这些信息基于TDK公司网站上列出的数据,所有规格可能会在不通知的情况下更改。
VLF302515MT-1R0N-CA 价格&库存
很抱歉,暂时无法提供与“VLF302515MT-1R0N-CA”相匹配的价格&库存,您可以联系我们找货
