VLF403215MT-1R0N-CA
VLF403215MT-1R0N-CA
    TDK(东电化)
    非标准
    固定电感器 Nonstandard 1µH ±30% 3.56A 31mΩ
VLF403215MT-1R0N-CA 数据手册
1 of 3 Creation Date :June 18 2014 VLF403215MT-1R0N-CA Applications Automotive Grade Feature Wire Wound Magnetic Shield Ferrite Core AEC-Q200 Series VLF-M Series / VLF403215MT-CA Type Status PROD Size Length(L) 4.00mm +/-0.20mm Width(W) 3.20mm +/-0.20mm Thickness(T) 1.50mm Max. Recommended Land Pattern (A) 1.10mm Nom. Recommended Land Pattern (B) 1.30mm Nom. Recommended Land Pattern (C) 1.80mm Nom. Electrical Characteristics Inductance 1uH +/-30% at 1MHz Rated Current (L Change) [Typ.] 3.34A (30% Down) Rated Current (L Change) [Max.] 3.01A (30% Down) Rated Current (Temperature Rise) [Typ.] 3.56A (40degC Rise) DC Resistance [Nom.] 26mΩ DC Resistance [Max.] 31mΩ Other Operating Temp. Range (Including Self-Temp. Rise) -40 to 105degC Soldering Method Reflow AEC Q200 Yes Packing Blister (Plastic)Taping [180mm Reel] Package Quantity 1000Pcs Min. Weight 0.072g •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved 2 of 3 Creation Date :June 18 2014 VLF403215MT-1R0N-CA VLF403215MT-1R0N-CA VLF403215MT-1R0N-CA VLF403215MT-1R0N-CA VLF403215MT-1R0N-CA •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved 3 of 3 Creation Date :June 18 2014 VLF403215MT-1R0N-CA VLF403215MT-1R0N-CA(Amb. Temp. = 20degc) VLF403215MT-1R0N-CA(Amb. Temp. = 20degc) •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved VLF403215MT-1R0N-CA(DC = 0A) VLF403215MT-1R0N-CA(DC = 1.505A)
VLF403215MT-1R0N-CA 价格&库存
很抱歉,暂时无法提供与“VLF403215MT-1R0N-CA”相匹配的价格&库存,您可以联系我们找货
