1 of 3
Creation Date :July 06 2014
VLM10555T-3R3M7R2-2
Applications
Commercial Grade
Feature
Wire Wound
Magnetic Shield
Ferrite Core
Series
VLM Series / VLM10555-2 Type
Status
PROD
Size
Length(L)
10.30mm +0.20mm
Width(W)
10.60mm +/-0.20mm
Thickness(T)
5.40mm +/-0.20mm
Recommended Land Pattern (A)
2.60mm Nom.
Recommended Land Pattern (B)
3.40mm Nom.
Recommended Land Pattern (C)
3.00mm Nom.
Recommended Land Pattern (D)
6.10mm Nom.
Recommended Land Pattern (E)
1.90mm Nom.
Recommended Land Pattern (F)
1.80mm Nom.
Electrical Characteristics
Inductance
3.3uH +/-20% at 100kHz
Rated Current (L Change) [Max.]
12A (25% Down)
Rated Current (Temperature Rise) [Typ.]
7.2A (40degC Rise)
Rated Current (Temperature Rise) [Max.]
DC Resistance [Nom.]
8.3mΩ
DC Resistance [Max.]
9.55mΩ
Other
Operating Temp. Range (Including Self-Temp. Rise)
-40 to 125degC
Soldering Method
Reflow, Iron Soldering
AEC Q200
No
Packing
Blister (Plastic)Taping [330mm Reel]
Package Quantity
500Pcs Min.
Weight
1.7g
•This PDF document was created based on the data listed on the TDK Corporation website.
•All specifications are subject to change without notice.
Copyright(c) TDK Corporation. All rights reserved
2 of 3
VLM10555T-3R3M7R2-2
VLM10555T-3R3M7R2-2
VLM10555T-3R3M7R2-2
VLM10555T-3R3M7R2-2
VLM10555T-3R3M7R2-2
3 of 3
VLM10555T-3R3M7R2-2
DC Bias Characteristic
Temperature Characteristic
no data available
no data available
VLM10555T-3R3M7R2-2(Amb. Temp. = 20degc)
VLM10555T-3R3M7R2-2 价格&库存
很抱歉,暂时无法提供与“VLM10555T-3R3M7R2-2”相匹配的价格&库存,您可以联系我们找货
