VLM10555T-R56M120-3
VLM10555T-R56M120-3
    TDK(东电化)
    固定电感器 Nonstandard 560nH ±20% 12A 2.5mΩ
VLM10555T-R56M120-3 数据手册
1 of 3 Creation Date :July 03 2014 VLM10555T-R56M120-3 Applications Commercial Grade Feature Wire Wound Magnetic Shield Ferrite Core Series VLM Series / VLM10555-3 Type Status PROD Size Length(L) 10.30mm +0.20mm Width(W) 10.60mm +/-0.20mm Thickness(T) 5.40mm +/-0.20mm Recommended Land Pattern (A) 2.60mm Nom. Recommended Land Pattern (B) 3.40mm Nom. Recommended Land Pattern (C) 3.00mm Nom. Recommended Land Pattern (D) 6.10mm Nom. Recommended Land Pattern (E) 1.90mm Nom. Recommended Land Pattern (F) 1.80mm Nom. Electrical Characteristics Inductance 560nH +/-20% at 100kHz Rated Current (L Change) [Max.] 34A (25% Down) Rated Current (Temperature Rise) [Typ.] 12A (40degC Rise) Rated Current (Temperature Rise) [Max.] DC Resistance [Nom.] 2.1mΩ DC Resistance [Max.] 2.5mΩ Other Operating Temp. Range (Including Self-Temp. Rise) -40 to 125degC Soldering Method Reflow, Iron Soldering AEC Q200 No Packing Blister (Plastic)Taping [330mm Reel] Package Quantity 500Pcs Min. Weight 1.7g •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved 2 of 3 Creation Date :July 03 2014 VLM10555T-R56M120-3 VLM10555T-R56M120-3 VLM10555T-R56M120-3 VLM10555T-R56M120-3 VLM10555T-R56M120-3 •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved 3 of 3 Creation Date :July 03 2014 VLM10555T-R56M120-3 VLM10555T-R56M120-3(Amb. Temp. = 20degc) VLM10555T-R56M120-3(Amb. Temp. = 20degc) •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved VLM10555T-R56M120-3(DC = 0A) VLM10555T-R56M120-3(DC = 6A)
VLM10555T-R56M120-3
物料型号:VLM10555T-R56M120-3
器件简介: - 电感器类型:线圈(Wire Wound) - 核心材料:铁氧体(Ferrite Core) - 系列:VLM系列 / VLM10555-3型 - 状态:生产中(PROD) - 符合REACH法规和RoHS指令
引脚分配:文档中未提供引脚分配信息。
参数特性: - 尺寸:长度10.30mm±0.20mm,宽度10.60mm±0.20mm,厚度5.40mm±0.20mm - 推荐焊盘图案尺寸:A 2.60mm,B 3.40mm,C 3.00mm,D 6.10mm,E 1.90mm,F 1.80mm - 电感值:560nH±20%(在100kHz时) - 额定电流(L变化):最大34A(下降25%) - 额定电流(温度上升):典型12A(上升40°C) - 直流电阻:典型2.1mΩ,最大2.5mΩ
功能详解: - 工作温度范围:-40至125°C - 焊接方法:回流焊、烙铁焊接 - AECQ200认证:无 - 包装:吸塑(塑料)胶带(330mm卷) - 包装数量:最小500件 - 重量:1.7g
应用信息:适用于商业级应用。
封装信息:文档中提供了尺寸信息和推荐焊盘图案,但未提供封装类型。
VLM10555T-R56M120-3 价格&库存
很抱歉,暂时无法提供与“VLM10555T-R56M120-3”相匹配的价格&库存,您可以联系我们找货
VLM10555T-R56M120-3
  • 1+27.531741+3.56108
  • 10+22.6528610+2.93002
  • 100+18.62618100+2.40919
库存:347
