(1/1)
SMD Inductors(Coils)
For Power Line(Wound)
Conformity to RoHS Directive
VLP Series VLP4612
SHAPES AND DIMENSIONS
On the side at which the winding starts
3.0±0.20
Inductance marking
4.6±0.20
1.2max.
FEATURES
• This is an SMD power inductor for power supplies that has an
open magnetic path construction based on a low-height drum
core (upright).
• User terminals are contact-formed on the bottom of the drum
core using copper (finished with tin plating).
• It uses crosswise windings and supports large currents.
• It is lead-free compatible.
• With several variations in drum core height, users can choose
the perfect product for their application.
APPLICATIONS
• LCD modules
• Cellular phones
• Hard disk drives
Dimensions in mm
RECOMMENDED PC BOARD PATTERN
ø3
.5
1.2
Dimensions in mm
ELECTRICAL CHARACTERISTICS
Part No.
Inductance
(µH)
VLP4612T-1R0M1R5
VLP4612T-1R8M1R3
VLP4612T-2R5M1R1
VLP4612T-3R3MR85
VLP4612T-4R7MR72
VLP4612T-6R8MR67
VLP4612T-100MR52
VLP4612T-150MR42
VLP4612T-220MR34
1.0
1.8
2.5
3.3
4.7
6.8
10.0
15.0
22.0
Inductance
tolerance
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
Test
frequency
(kHz)
100
100
100
100
100
100
100
100
100
DC resistance
(Ω)max.
0.11
0.14
0.17
0.26
0.28
0.38
0.62
0.96
1.42
Rated current(A)∗
Based on inductance
change
2.30 max.
1.70 max.
1.40 max.
0.90 max.
0.88 max.
0.77 max.
0.59 max.
0.45 max.
0.39 max.
Based on temperature
rise
1.50 typ.
1.30 typ.
1.10 typ.
0.85 typ.
0.72 typ.
0.67 typ.
0.52 typ.
0.42 typ.
0.34 typ.
Rated current:The rated current is the smaller of the values given based on the rate of inductance change (10% decrease from the initial value) or the
temperature rise (temperature rise of 40°C caused by the heat generated by the product itself). Please note that the current applied must be
DC.
TYPICAL ELECTRICAL CHARACTERISTICS
INDUCTANCE vs. DC SUPERPOSITION CHARACTERISTICS
Inductance (µH)
100
220MR34
150MR42
100MR52
6R8MR67
10
4R7MR72
3R3MR85
1
0.1
1
1.5
Idc (A)
• Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific
bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications.
• All specifications are subject to change without notice.
001-04 / 20080822 / e531_vlp46.fm
很抱歉,暂时无法提供与“VLP4612T-4R7MR72”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+3.642833000+0.47266
- 6000+3.435656000+0.44578
- 9000+3.320099000+0.43078
- 国内价格 香港价格
- 1+7.154361+0.92828
- 10+5.9071510+0.76645
- 100+4.86112100+0.63073
- 1000+3.997841000+0.51872
