(1/2)
001-02 / 20030811 / e531_vlp56.fm
VLP Series VLP56 Type
Inductors(Coil)
For Power Supply
SMD
FEATURES
• This is an SMD power inductor for power supplies that has an
open magnetic path construction based on a low-height drum
core (upright).
• User terminals are contact-formed on the bottom of the drum
core using copper (finished with tin plating).
• It uses crosswise windings and supports large currents.
• It is lead-free compatible.
• With several variations in drum core height, users can choose
the perfect product for their application.
APPLICATIONS
• LCD modules
• Cell phones
• Hard drives
SHAPES AND DIMENSIONS
Polarity marking
(on the side at which the winding starts)
5.0±0.2
1.5±0.1
5.6max.
7.
4m
ax
Inductance marking
5.6±0.2
1.5
4.0
1.0max.
0.23
5.8max.
Dimensions in mm
ELECTRICAL CHARACTERISTICS
Part No.
Inductance
(µH)
VLP5610T-2R7M1R0
VLP5610T-4R7MR90
VLP5610T-6R8MR80
VLP5610T-100MR65
VLP5610T-150MR52
VLP5610T-220MR45
VLP5610T-330MR36
VLP5610T-470MR29
2.7
4.7
6.8
10.0
15.0
22.0
33.0
47.0
Inductance
tolerance
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
Test
frequency
(kHz)
100
100
100
100
100
100
100
100
DC resistance
(Ω)max.
0.17
0.24
0.30
0.45
0.71
0.96
1.47
1.93
Rated current(A)∗
Based on inductance
change
1.26 max.
1.08 max.
0.90 max.
0.72 max.
0.63 max.
0.50 max.
0.41 max.
0.36 max.
Based on temperature
rise
1.05 typ.
0.90 typ.
0.80 typ.
0.65 typ.
0.52 typ.
0.45 typ.
0.36 typ.
0.29 typ.
Rated current:The rated current is the smaller of the values given based on the rate of inductance change (10% decrease from the initial value) or the
temperature rise (temperature rise of 40°C caused by the heat generated by the product itself). Please note that the current applied must be
DC.
• All specifications are subject to change without notice.
(2/2)
Inductors(Coil)
For Power Supply
SMD
TYPICAL ELECTRICAL CHARACTERISTICS
INDUCTANCE vs. DC SUPERPOSITION CHARACTERISTICS
100
Inductance (µH)
470MR29
330MR36
220MR45
150MR52
100MR65
10
6R8MR80
4R7MR90
2R7M1R0
1
1
Idc (A)
1.5
2
TEMPERATURE RISE CHARACTERISTICS
60
Temperature rise (˚C)
50
100MR65
2R7M1R0
40
30
4R7MR90
6R8MR80
10
1
Idc (A)
1.5
2
很抱歉,暂时无法提供与“VLP5610T-100MR65”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 233+3.92958
- 1042+3.84494
- 2084+3.65149
