VLP6045LT-470M
VLP6045LT-470M
    TDK(东电化)
    SMD,6.8x6.8mm
    VLP6045LT-470M
VLP6045LT-470M 数据手册
I N D U C T O R S June 2017 Inductors for Power Circuits Wound Ferrite VLP Series VLP6045L Type VLP6045L Caution The products in this catalog will be or have been stopped production Discontinue Issue Date May 18, 2017 Last Purchase Order Date Mar. 29, 2019 Last Shipment Date Sep. 30, 2019 Please refer to our Web site about replacement information. (2/9) I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The storage period is less than 6 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. Th e (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 20170612 / inductor_commercial_power_vlp6045l_en.fm (3/9) I N D U C T O R S Product compatible with RoHS directive Halogen-free Compatible with lead-free solders Inductors for Power Circuits Wound Ferrite pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en Overview of VLP6045L Type FEATURES Magnetic shield type wound inductor for power circuits. Magnetic shield construction with ferrite resin material. APPLICATION Thin-screen TVs, printers, laptop computers, other PART NUMBER CONSTRUCTION VLP Series name 6045 L×W×H Dimensions (mm max.) 6045 6.8×6.8×4.5 L T internal code Packaging style T - Taping 1R0 N Inductance (µH) 1R0 1.0 100 10 101 100 Inductance tolerance M ±20% N ±30% OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT Temperature range Package quantity Individual weight (mg) 536 Th e Operating Storage Type temperature temperature (pieces/reel) (°C) (°C) VLP6045L –40 to +105 –40 to +105 1000 Operating temperature range includes self-temperature rise. The Storage temperature range is for after the circuit board is mounted. RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20170612 / inductor_commercial_power_vlp6045l_en.fm (4/9) I N D U C T O R S VLP6045L Type RECOMMENDED REFLOW PROFILE Soldering Natural cooling pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en Preheating Peak T: Temperature T4 T3 T2 T1 t1 T3 t3 t2 t: Time Time t1 60 to 120s Soldering Temp. Time T3 t2 220°C 40s Peak Temp. T4 260°C Time t3 5s Th e Preheating Temp. T1 T2 150°C 180°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20170612 / inductor_commercial_power_vlp6045l_en.fm (5/9) I N D U C T O R S VLP6045L Type SHAPE & DIMENSIONS 1.6 2.2 6.0±0.2 100 6.8max. 2.2 pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en 2.0 6.0±0.3 4.5max. 6.8max. Dimensions in mm 6.6 RECOMMENDED LAND PATTERN 2.55 1.4 2.55 Th e Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20170612 / inductor_commercial_power_vlp6045l_en.fm (6/9) I N D U C T O R S VLP6045L Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE (µH) 1.0 1.5 2.2 3.3 4.7 6.8 10 15 22 33 47 68 100  Measuring frequency DC resistance (kHz) 100 100 100 100 100 100 100 100 100 100 100 100 100 ( )max. 0.017 0.024 0.026 0.033 0.038 0.057 0.072 0.112 0.140 0.202 0.299 0.455 0.663 Rated current Part No. pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en L Tolerance ±30% ±30% ±30% ±30% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ( )typ. 0.013 0.018 0.020 0.025 0.029 0.044 0.055 0.086 0.108 0.155 0.230 0.350 0.510 Idc1 (A)max. 8.6 7.2 6.4 5.2 4.4 3.8 3.2 2.5 2.1 1.6 1.4 1.1 0.9 Idc2 (A)typ. 6.5 5.4 5.1 4.6 4.1 3.3 3.0 2.3 2.0 1.5 1.4 1.0 0.8 VLP6045LT-1R0N VLP6045LT-1R5N VLP6045LT-2R2N VLP6045LT-3R3N VLP6045LT-4R7M VLP6045LT-6R8M VLP6045LT-100M VLP6045LT-150M VLP6045LT-220M VLP6045LT-330M VLP6045LT-470M VLP6045LT-680M VLP6045LT-101M Rated current: smaller value of either Idc1 or Idc2. Idc1: When based on the inductance change rate (30% below the nominal value) Idc2: When based on the temperature increase (Temperature increase of 40°C by self heating) Manufacturer Keysight Technologies Panasonic Keysight Technologies Th e ○ Measurement equipment Measurement item Product No. L 4194A DC resistance VP-2941A Rated current Idc1 4285A+42841A+42842C * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20170612 / inductor_commercial_power_vlp6045l_en.fm (7/9) I N D U C T O R S VLP6045L Type ELECTRICAL CHARACTERISTICS 1000 pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en L FREQUENCY CHARACTERISTICS GRAPH 101M 680M 470M 330M 100 220M 150M 100M Inductance(µH) 6R8M 4R7M 3R3N 10 2R2N 1 0.1 1 Frequency(MHz) 1R0N 10 100 Th e 0.1 0.01 1R5N ○ Measurement equipment Product No. Manufacturer 4294A Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20170612 / inductor_commercial_power_vlp6045l_en.fm (8/9) I N D U C T O R S VLP6045L Type ELECTRICAL CHARACTERISTICS 1000 100 pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en INDUCTANCE VS. DC BIAS CHARACTERISTICS GRAPH 101M 680M 470M Inductance(µH) 330M 220M 10 150M 100M 6R8M 4R7M 3R3N 2R2N 1R5N 1 1R0N 2.0 4.0 6.0 DC current(A) 8.0 10.0 12.0 Th e 0.1 0.0 ○ Measurement equipment Product No. Manufacturer 4285A+42841A+42842C Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20170612 / inductor_commercial_power_vlp6045l_en.fm (9/9) I N D U C T O R S VLP6045L Type PACKAGING STYLE pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en REEL DIMENSIONS 2.0±0.5 E Type VLP6045L A ø330 W1 16.4 W2 22.4 N ø100 E 2 N * These values are typical values. (1.0) ø13.0±0.5 W1 ø21.0±0.8 W2 A Dimensions in mm TAPE DIMENSIONS P2 P0 K P1 t A B 6.8 øD0 1.5+0.1/-0 E 1.75±0.1 F 7.5±0.1 Dimensions in mm P0 P1 P2 W 4.0±0.1 10.0±0.1 2.0±0.1 16.0±0.3 K 4.8 t 0.4 Th e Type A VLP6045L 6.8 B W F E øD0 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20170612 / inductor_commercial_power_vlp6045l_en.fm
VLP6045LT-470M 价格&库存
很抱歉,暂时无法提供与“VLP6045LT-470M”相匹配的价格&库存,您可以联系我们找货
