VLS201610CX-6R8M-1
VLS201610CX-6R8M-1
    TDK(东电化)
    IND-2P_2X1.6MM_SM
    固定电感器 ±20% 6.8μH 2.00 x 1.60mm 650mA 非标准
VLS201610CX-6R8M-1 数据手册
I N D U C T O R S Inductors for power circuits Wound ferrite VLS-CX-1 series REACH SVHC-Free RoHS Cl Br Pb Halogen Free Lead Free VLS201610CX-1 type FEATURES Magnetic shield type wound inductor for power circuits using a ferrite magnetic material. High magnetic shield construction and compatible with high-density mounting. Larger current and lower Rdc were achieved by optimizing the ferrite core figure. APPLICATION Smart phones, tablet terminals, HDDs, SSDs, DVCs, DSCs, mobile display panels, portable game devices, compact power supply modules, other Application guides: Smart phones/tablets PART NUMBER CONSTRUCTION VLS 201610 C X - Series name L×W×H dimensions 2.0×1.6×1.0 mm Internal code 1 Internal code 2 R24 M - Inductance (µH) Inductance tolerance 1 Marking CHARACTERISTICS SPECIFICATION TABLE L L measuring frequency Rated current DC resistance Isat Itemp Isat (µH) Tolerance (MHz) ( )max. ( )typ. (A)max. (A)max. (A)typ. 0.24 ±20% 1 0.040 0.032 3.91 3.08 4.35 0.47 ±20% 1 0.050 0.042 3.15 2.69 3.50 0.68 ±20% 1 0.076 0.063 2.52 2.19 2.81 1.0 ±20% 1 0.079 0.066 1.76 2.14 1.95 1.5 ±20% 1 0.126 0.105 1.58 1.74 1.75 2.2 ±20% 1 0.163 0.136 1.31 1.53 1.45 3.3 ±20% 1 0.253 0.211 1.01 1.20 1.12 4.7 ±20% 1 0.365 0.304 0.82 1.00 0.92 6.8 ±20% 1 0.582 0.485 0.65 0.79 0.73 10 ±20% 1 0.732 0.61 0.55 0.71 0.62 15 ±20% 1 1.258 1.048 0.44 0.54 0.49 22 ±20% 1 1.582 1.318 0.38 0.48 0.42  Rated current: smaller value of either Isat or Itemp. Isat: When based on the inductance change rate (30% below the initial L value) Itemp: When based on the temperature increase (temperature increase of 40°C by self heating) Part No. Itemp (A)typ. 3.62 3.16 2.58 2.52 2.05 1.80 1.41 1.18 0.93 0.83 0.63 0.56 VLS201610CX-R24M-1 VLS201610CX-R47M-1 VLS201610CX-R68M-1 VLS201610CX-1R0M-1 VLS201610CX-1R5M-1 VLS201610CX-2R2M-1 VLS201610CX-3R3M-1 VLS201610CX-4R7M-1 VLS201610CX-6R8M-1 VLS201610CX-100M-1 VLS201610CX-150M-1 VLS201610CX-220M-1 Measurement equipment Measurement item Product No. L 4194A DC resistance VP-2941A Rated current Isat 4285A+42841A+42842C * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies Panasonic Keysight Technologies TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating temperature range Storage temperature range –40 to 105 °C –40 to 105 °C  Operating temperature range includes self-temperature rise.  The storage temperature range is for after the assembly. Individual weight 15 mg Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20180710 inductor_commercial_power_vls201610cx-1_en.fm I N D U C T O R S VLS201610CX-1 type L FREQUENCY CHARACTERISTICS 100 220M 150M 100M Inductance(µH) 10 6R8M 4R7M 3R3M 2R2M 1R5M 1 1R0M R68M R47M R24M 0.1 0.1 1 10 100 Frequency(MHz) Measurement equipment Product No. Manufacturer 4294A Keysight Technologies * Equivalent measurement equipment may be used. INDUCTANCE VS. DC BIAS CHARACTERISTICS 100 220M 150M Inductance(µH) 10 100M 6R8M 4R7M 3R3M 2R2M 1R5M 1 1R0M R68M R47M R24M 0 0 1 2 3 4 5 DC current(A) Measurement equipment Product No. Manufacturer 4285A+42841A+42842C Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/4) 20180710 inductor_commercial_power_vls201610cx-1_en.fm I N D U C T O R S VLS201610CX-1 type SHAPE & DIMENSIONS PACKAGING STYLE REEL DIMENSIONS 1.6±0.2 2.0±0.5 (0.65) (0.7) (0.65) 1.0max. ø60+1/–0 2.0±0.2 Dimensions in mm ø13±0.2 9.0±0.3 ø21±0.8 13±1.4 ø180+0/–3 Dimensions in mm 0.7 2.0±0.05 4.0±0.1 B 1.6 K 0.65 1.5 +0.1 –0 3.5±0.05 Sprocket hole 0.25±0.05 8.0±0.2 RECOMMENDED LAND PATTERN 1.75±0.1 TAPE DIMENSIONS A 0.65 Cavity 4.0±0.1 2.0 Dimensions in mm Dimensions in mm Type VLS201610CX-1 Package quantity Soldering B 2.3±0.1 K 1.10±0.05 PACKAGE QUANTITY RECOMMENDED REFLOW PROFILE Preheating A 1.9±0.1 2000pcs/reel Natural cooling Peak 260°C Temperature 230°C 230°C 180°C 10s 150°C 60 to 120s 30s Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20180710 inductor_commercial_power_vls201610cx-1_en.fm I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is less than 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20180710 inductor_commercial_power_vls201610cx-1_en.fm
VLS201610CX-6R8M-1
物料型号:VLS201610CX-1型
器件简介:使用铁氧体磁性材料的磁屏蔽型绕线电感,具有高磁屏蔽结构,兼容高密度安装。
引脚分配:文档中未提供具体引脚分配信息。
参数特性:提供了不同电感值的电感器的直流电阻(Rdc)、额定电流(Isat或Itemp)、电感公差、测量频率等参数。
功能详解:优化了铁氧体核心形状,实现了更大的电流和更低的直流电阻。
应用信息:适用于智能手机、平板电脑、硬盘驱动器、固态硬盘、数码相机、便携式电源模块等。
封装信息:提供了产品的尺寸、重量、包装样式、卷轴尺寸和推荐的回流焊接曲线。
VLS201610CX-6R8M-1 价格&库存
很抱歉,暂时无法提供与“VLS201610CX-6R8M-1”相匹配的价格&库存,您可以联系我们找货
VLS201610CX-6R8M-1
  • 2000+1.259112000+0.16254
  • 4000+1.187224000+0.15326
  • 6000+1.147146000+0.14809
  • 10000+1.0986110000+0.14182
  • 14000+1.0677814000+0.13785
  • 20000+1.0360820000+0.13375
库存:2487
VLS201610CX-6R8M-1
  • 1+2.483861+0.32065
  • 10+2.0095710+0.25942
  • 100+1.65573100+0.21374
  • 1000+1.361591000+0.17577
库存:2487
VLS201610CX-6R8M-1
    • 10+0.49248
    • 100+0.39161
    • 300+0.34118
    库存:960
