VLS201610HBX-4R7M-1
VLS201610HBX-4R7M-1
    TDK(东电化)
    功率电感 4.7µH ±20% 2016 1.00mm 2.00 x 1.60mm 308mΩ 810mA
VLS201610HBX-4R7M-1 数据手册
I N D U C T O R S Inductors for power circuits Wound metal VLS-HBX-1 series REACH SVHC-Free RoHS Cl Br Pb Halogen Free Lead Free VLS201610HBX-1 type FEATURES Magnetic shield type wound inductor for power circuits using a metallic magnetic material. High magnetic shield construction and compatible with high-density mounting. Larger current was achieved by the metallic magnetic material. APPLICATION Smart phones, tablet terminals, HDDs, SSDs, DVCs, DSCs, mobile display panels, portable game devices, compact power supply modules, other Application guides: Smart phones/tablets PART NUMBER CONSTRUCTION VLS 201610 HB X - Series name L×W×H dimensions 2.0×1.6×1.0 mm Internal code 1 Internal code 2 R24 M - Inductance (µH) Inductance tolerance 1 Marking CHARACTERISTICS SPECIFICATION TABLE L L measuring frequency Rated current DC resistance Part No. Isat Itemp Isat (µH) Tolerance (MHz) ( )max. ( )typ. (A)max. (A)max. (A)typ. 0.24 ±20% 1 0.030 0.023 4.81 3.74 5.15 0.33 ±20% 1 0.039 0.031 4.42 2.85 4.79 0.47 ±20% 1 0.041 0.034 3.50 2.81 4.00 0.68 ±20% 1 0.053 0.044 3.10 2.47 3.53 1.0 ±20% 1 0.072 0.060 2.50 2.13 2.90 1.5 ±20% 1 0.116 0.097 2.00 1.63 2.20 2.2 ±20% 1 0.170 0.142 1.70 1.45 1.90 3.3 ±20% 1 0.252 0.210 1.20 1.02 1.35 4.7 ±20% 1 0.370 0.308 1.10 0.81 1.20 6.8 ±20% 1 0.558 0.465 0.88 0.70 0.98 10 ±20% 1 0.768 0.640 0.65 0.61 0.75  Rated current: smaller value of either Isat or Itemp. Isat: When based on the inductance change rate (30% below the initial L value) Itemp: When based on the temperature increase (temperature increase of 40°C by self heating) Itemp (A)typ. 4.40 3.35 3.30 2.90 2.50 1.92 1.70 1.20 0.95 0.82 0.72 VLS201610HBX-R24M-1 VLS201610HBX-R33M-1 VLS201610HBX-R47M-1 VLS201610HBX-R68M-1 VLS201610HBX-1R0M-1 VLS201610HBX-1R5M-1 VLS201610HBX-2R2M-1 VLS201610HBX-3R3M-1 VLS201610HBX-4R7M-1 VLS201610HBX-6R8M-1 VLS201610HBX-100M-1 Measurement equipment Measurement item Product No. L 4194A DC resistance VP-2941A Rated current Isat 4285A+42841A+42842C * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies Panasonic Keysight Technologies TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating temperature range Storage temperature range –40 to 105 °C –40 to 105 °C  Operating temperature range includes self-temperature rise.  The storage temperature range is for after the assembly. Individual weight 16 mg Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20180709 inductor_commercial_power_vls201610hbx-1_en.fm I N D U C T O R S VLS201610HBX-1 type L FREQUENCY CHARACTERISTICS 100 100M Inductance(µH) 10 6R8M 4R7M 3R3M 2R2M 1R5M 1 1R0M R68M R47M R33M R24M 0.1 0.1 1 10 100 Frequency(MHz) Measurement equipment Product No. Manufacturer 4294A Keysight Technologies * Equivalent measurement equipment may be used. INDUCTANCE VS. DC BIAS CHARACTERISTICS 100 Inductance(µH) 10 100M 6R8M 4R7M 3R3M 2R2M 1R5M 1 1R0M R68M R47M R33M R24M 0 0 1 2 3 DC current(A) 4 5 6 Measurement equipment Product No. Manufacturer 4285A+42841A+42842C Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/4) 20180709 inductor_commercial_power_vls201610hbx-1_en.fm I N D U C T O R S VLS201610HBX-1 type SHAPE & DIMENSIONS PACKAGING STYLE REEL DIMENSIONS 1.6±0.2 2.0±0.5 (0.5) (1.0) (0.5) 1.0max. ø60+1/–0 2.0±0.2 Dimensions in mm ø13±0.2 9.0±0.3 ø21±0.8 13±1.4 ø180+0/–3 Dimensions in mm 1.6 1.0 2.0±0.05 4.0±0.1 B A K 0.5 1.5 +0.1 –0 3.5±0.05 Sprocket hole 0.25±0.05 8.0±0.2 RECOMMENDED LAND PATTERN 1.75±0.1 TAPE DIMENSIONS 0.5 4.0±0.1 Cavity 2.0 Dimensions in mm Dimensions in mm Type VLS201610HBX-1 A 1.9±0.1 Package quantity Soldering K 1.10±0.05 PACKAGE QUANTITY RECOMMENDED REFLOW PROFILE Preheating B 2.3±0.1 2000pcs/reel Natural cooling Peak 260°C Temperature 230°C 230°C 180°C 10s 150°C 60 to 120s 30s Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20180709 inductor_commercial_power_vls201610hbx-1_en.fm I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is less than 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20180709 inductor_commercial_power_vls201610hbx-1_en.fm
VLS201610HBX-4R7M-1
1. 物料型号:VLS201610HBX-1型,包括不同额定电流的型号,如VLS201610HBX-R24M-1至VLS201610HBX-100M-1。 2. 器件简介:该系列电感器是用于电源电路的金属屏蔽型绕线电感器,使用金属磁性材料制成,具有高磁屏蔽结构,兼容高密度安装,并通过金属磁性材料实现了更大的电流承载能力。 3. 引脚分配:文档中没有明确提供引脚分配信息,但提到了电感器的尺寸和推荐焊盘图案。 4. 参数特性:提供了详细的电感值、公差、直流电阻、额定电流等参数,以及不同型号的特定参数。 5. 功能详解:文档中提到了电感器的频率特性和直流偏置特性,但没有提供深入的功能详解。 6. 应用信息:适用于智能手机、平板电脑、硬盘驱动器、固态硬盘、数字摄像机、数字照相机、移动显示屏、便携式游戏设备、紧凑型电源模块等。 7. 封装信息:提供了电感器的外形尺寸、推荐的回流焊曲线、包装风格、卷轴尺寸、胶带尺寸和包装数量。
VLS201610HBX-4R7M-1 价格&库存
很抱歉,暂时无法提供与“VLS201610HBX-4R7M-1”相匹配的价格&库存,您可以联系我们找货
VLS201610HBX-4R7M-1
  • 1+0.37180
  • 50+0.21890
  • 2000+0.19690
库存:2520
VLS201610HBX-4R7M-1
  • 10+0.38580
  • 100+0.31500
  • 500+0.26620
  • 2000+0.24010
  • 4000+0.21870
  • 10000+0.21060
库存:94000
VLS201610HBX-4R7M-1
  • 10+0.86300
  • 100+0.51470
  • 500+0.36030
  • 2000+0.25740
  • 4000+0.24450
  • 20000+0.22640
库存:2520
VLS201610HBX-4R7M-1
  • 10+0.36584
  • 100+0.29269
  • 300+0.25612
库存:381
