I N D U C T O R S
Inductors for power circuits
Wound metal
VLS-HBX series
RoHS
REACH
SVHC-Free
Cl
Br
Pb
Halogen
Free
Lead
Free
VLS3012HBX type
FEATURES
Magnetic shield type wound inductor for power circuits using a metallic magnetic material.
High magnetic shield construction and compatible with high-density mounting.
Larger current was achieved by the metallic magnetic material.
APPLICATION
HDD, SSD, DVC, DSC, mobile display panels, smart phones, tablet terminal, portable game devices, compact power supply modules,
other
Application guides: Smart phones/tablets
PART NUMBER CONSTRUCTION
VLS
3012
HB
X
Series name
L×W×H dimensions
3.0×3.0×1.2 mm
Internal code 1
Internal code 2
R33
N
Inductance
(µH)
Inductance
tolerance
CHARACTERISTICS SPECIFICATION TABLE
L
L measuring
frequency
Rated current
DC resistance
Isat
Itemp
Isat
(µH)
Tolerance
(MHz)
( )max.
( )typ.
(A)max.
(A)max.
(A)typ.
0.33
±30%
1
0.030
0.023
9.11
6.10
10.12
0.47
±20%
1
0.035
0.027
7.46
5.32
8.29
0.68
±20%
1
0.038
0.032
5.95
5.09
6.75
1.0
±20%
1
0.047
0.039
5.50
4.62
6.11
1.5
±20%
1
0.067
0.056
4.41
3.77
4.90
2.2
±20%
1
0.106
0.088
3.35
2.84
3.76
3.3
±20%
1
0.150
0.130
2.82
2.37
3.22
4.7
±20%
1
0.201
0.175
2.51
2.01
2.79
6.8
±20%
1
0.285
0.248
1.98
1.66
2.24
10
±20%
1
0.415
0.361
1.70
1.33
1.89
15
±20%
1
0.636
0.553
1.37
1.11
1.52
22
±20%
1
0.761
0.662
1.09
1.01
1.21
Rated current: smaller value of either Isat or Itemp.
Isat: When based on the inductance change rate (30% below the initial L value)
Itemp: When based on the temperature increase (temperature increase of 40°C by self heating)
Part No.
Itemp
(A)typ.
6.78
5.91
5.66
5.13
4.19
3.15
2.63
2.23
1.84
1.48
1.23
1.12
VLS3012HBX-R33N
VLS3012HBX-R47M
VLS3012HBX-R68M
VLS3012HBX-1R0M
VLS3012HBX-1R5M
VLS3012HBX-2R2M
VLS3012HBX-3R3M
VLS3012HBX-4R7M
VLS3012HBX-6R8M
VLS3012HBX-100M
VLS3012HBX-150M
VLS3012HBX-220M
Measurement equipment
Measurement item
Product No.
L
4294A
DC resistance
34420A
Rated current Isat
4285A+42841A+42842C
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
Hewlett-Packard
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
Operating temperature range
Storage temperature range
–40 to 105 °C
–40 to 105 °C
Operating temperature range includes self-temperature rise.
The storage temperature range is for after the assembly.
Individual weight
53 mg
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/4)
20180709
inductor_commercial_power_vls3012hbx_en.fm
I N D U C T O R S
VLS3012HBX type
L FREQUENCY CHARACTERISTICS
1000
220M
Inductance(µH)
100
150M
100M
6R8M
4R7M
10
3R3M
2R2M
1R5M
1R0M
1
R68M
R47M
R33N
0.1
0.1
1
10
100
Frequency(MHz)
Product No.
Manufacturer
4294A
INDUCTANCE VS. DC BIAS CHARACTERISTICS
100
220M
150M
Inductance(µH)
10
100M
6R8M
4R7M
3R3M
2R2M
1R5M
1
1R0M
R68M
R47M
R33N
0.1
2
3
4
5
DC current(A)
6
7
8
9
10
Product No.
Manufacturer
4285A+42841A+42842C
(2/4)
20180709
I N D U C T O R S
VLS3012HBX type
SHAPE & DIMENSIONS
PACKAGING STYLE
REEL DIMENSIONS
ø60+1/–0
(2.63)
3.0±0.1
2.0±0.5
(1.19)
(0.9)
(1.2)
(0.9)
1.2max.
3.0±0.1
Dimensions in mm
ø13±0.2
9.0±0.3
ø21±0.8
13±1.4
ø180+0/–3
Dimensions in mm
1.5 +0.1
–0
2.0±0.05
4.0±0.1
3.5±0.05
Sprocket
hole
3.4
B
0.25±0.05
8.0±0.2
RECOMMENDED LAND PATTERN
1.75±0.1
TAPE DIMENSIONS
4.0±0.1
A
K
Cavity
Dimensions in mm
1.0
1.1
1.0
Dimensions in mm
Type
VLS3012HBX
A
3.20±0.05
Package quantity
Soldering
K
1.35±0.1
PACKAGE QUANTITY
RECOMMENDED REFLOW PROFILE
Preheating
B
3.20±0.05
2000pcs/reel
Natural
cooling
Peak
260°C
Temperature
230°C
230°C
180°C
10s
150°C
60 to 120s
30s
Time
(3/4)
20180709
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is less than 12 months. Be sure to follow the storage conditions (temperature: 5 to 30°C, humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(4/4)
20180709
很抱歉,暂时无法提供与“VLS3012HBX-220M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.06537
- 100+0.99435
- 300+0.92333
- 500+0.85230
- 2000+0.81679
- 5000+0.79548
