VLS3015CX-680M-H
VLS3015CX-680M-H
    TDK(东电化)
    SMD,3x3mm
    固定电感器 ±20% 68µH 240mA 3.00 x 3.00mm 非标准
VLS3015CX-680M-H 数据手册
I N D U C T O R S Inductors for power circuits Wound ferrite VLS-CX-H series REACH SVHC-Free RoHS Cl Br Pb Halogen Free Lead Free AEC-Q200 VLS3015CX-H type FEATURES Magnetic shield type wound inductor for power circuits using a ferrite magnetic material. High magnetic shield construction and compatible with high-density mounting. Larger current and lower Rdc were achieved by optimizing the ferrite core figure. Operating temperature range: –40 to +125°C (including self-temperature rise) Compliant with AEC-Q200 APPLICATION ADAS ECU, in-Vehicle camera (view camera, sensing camera), airbags, radar, meter cluster, automotive communication module, other power supply circuit uses PART NUMBER CONSTRUCTION VLS 3015 C X Series name L×W×H dimensions 3.0×3.0×1.5 mm Internal code 1 Internal code 2 - 101 M - Inductance (µH) Inductance tolerance H Marking CHARACTERISTICS SPECIFICATION TABLE L Measuring frequency DC resistance Rated current Isat Isat Itemp (µH) Tolerance (MHz) ( )max. ( )typ. (A)max. (A)typ. (A)max. 1.0 ±20% 1 0.038 0.032 2.30 2.87 2.96 1.5 ±20% 1 0.054 0.045 1.73 2.16 2.40 2.2 ±20% 1 0.060 0.050 1.48 1.85 2.14 3.3 ±20% 1 0.101 0.084 1.29 1.52 1.79 4.7 ±20% 1 0.120 0.100 1.15 1.35 1.70 6.8 ±20% 1 0.192 0.160 0.95 1.12 1.08 10 ±20% 1 0.286 0.238 0.67 0.79 0.9 15 ±20% 1 0.428 0.357 0.57 0.67 0.84 22 ±20% 1 0.660 0.550 0.45 0.53 0.73 33 ±20% 1 0.888 0.740 0.35 0.41 0.58 47 ±20% 1 1.392 1.160 0.29 0.34 0.48 68 ±20% 1 2.256 1.880 0.24 0.27 0.36 100 ±20% 1 2.544 2.120 0.23 0.26 0.30  Rated current: smaller value of either Isat or Itemp. Isat: When based on the inductance change rate (30% below the initial L value) Itemp: When based on the temperature increase (temperature increase of 40°C by self heating) Part No. Itemp (A)typ. 3.70 3.00 2.67 2.24 2.13 1.35 1.13 1.05 0.91 0.73 0.60 0.45 0.33 VLS3015CX-1R0M-H VLS3015CX-1R5M-H VLS3015CX-2R2M-H VLS3015CX-3R3M-H VLS3015CX-4R7M-H VLS3015CX-6R8M-H VLS3015CX-100M-H VLS3015CX-150M-H VLS3015CX-220M-H VLS3015CX-330M-H VLS3015CX-470M-H VLS3015CX-680M-H VLS3015CX-101M-H Measurement equipment Measurement item Product No. L 4294A DC resistance 34420A Rated current Isat 4285A+42841A+42842C * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies Hewlett-Packard Keysight Technologies Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20211202 inductor_automotive_power_vls3015cx-h_en.fm I N D U C T O R S VLS3015CX-H type L FREQUENCY CHARACTERISTICS 1000 101M 680M 470M Inductance(µH) 100 330M 220M 150M 100M 6R8M 10 4R7M 3R3M 2R2M 1R5M 1 1R0M 0.1 0.1 1 10 Frequency(MHz) 100 1000 Measurement equipment Product No. Manufacturer 4294A Keysight Technologies * Equivalent measurement equipment may be used. INDUCTANCE VS. DC BIAS CHARACTERISTICS 1000 Inductance(µH) 100 101M 680M 470M 330M 220M 150M 10 100M 6R8M 4R7M 3R3M 2R2M 1R5M 1 1R0M 0.1 0.0 0.5 1.0 1.5 2.0 DC current(A) 2.5 3.0 3.5 4.0 Measurement equipment Product No. Manufacturer 4285A+42841A+42842C Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/4) 20211202 inductor_automotive_power_vls3015cx-h_en.fm I N D U C T O R S VLS3015CX-H type SHAPE & DIMENSIONS Winding direction PACKAGING STYLE REEL DIMENSIONS Polarity Mark (1.0) (1.0) (1.0) 1.5max. 3.0±0.2 ø60+1/–0 3.0±0.2 2.0±0.5 ø13±0.2 9 ø21±0.8 Dimensions in mm 13 ø180 Dimensions in mm 1.5 +0.1 –0 2.0±0.05 4.0±0.1 3.5±0.05 Sprocket hole 3.0 B 0.25 8.0±0.2 RECOMMENDED LAND PATTERN 1.75±0.1 TAPE DIMENSIONS A K Cavity 4.0±0.1 Dimensions in mm 1.6 0.8 1.6 Dimensions in mm Type VLS3015CX-H Package quantity Soldering Natural cooling Peak 260°C Temperature 230°C B 3.35 K 1.65 PACKAGE QUANTITY RECOMMENDED REFLOW PROFILE Preheating A 3.35 230°C 2000 pcs/reel TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating Storage Individual temperature range temperature range weight –40 to 125 °C –40 to 125 °C 0.057 g  Operating temperature range includes self-temperature rise.  The storage temperature range is for after the assembly. 180°C 10s 150°C 60 to 120s 30s Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20211202 inductor_automotive_power_vls3015cx-h_en.fm I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is within 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products described in this catalog are intended to be installed in automobiles or automotive electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) and to be used in automobiles (including the case where the said automotive product is mounted in a vehicle) or standard applications as general electronic equipment in automotive applications or standard applications as general electronic equipment in automotive applications in accordance with the scope and conditions described in this specification, while the said automotive or general electronic equipment including the said product is intended to be used in the usual operation and usage methods, respectively. Other than automotive or automotive products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality requires a more stringent level of safety or reliability, or whose failure, malfunction or defect could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in this specification, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20211202 inductor_automotive_power_vls3015cx-h_en.fm
VLS3015CX-680M-H 价格&库存
很抱歉,暂时无法提供与“VLS3015CX-680M-H”相匹配的价格&库存,您可以联系我们找货
VLS3015CX-680M-H
  • 5+2.25435
  • 50+1.63737
  • 250+1.58991
  • 500+1.55432
  • 1000+1.50686
  • 2000+1.44753
库存:559
VLS3015CX-680M-H
  • 5+2.25435
  • 50+1.63737
  • 250+1.58991
  • 500+1.55432
  • 1000+1.50686
  • 2000+1.44753
库存:559
VLS3015CX-680M-H
  • 1+1.09120
  • 50+0.83930
  • 2000+0.77330
库存:2000
VLS3015CX-680M-H
  • 1+2.379791+0.30944
VLS3015CX-680M-H
  • 1+2.378871+0.30932
  • 10+1.9937710+0.25925
  • 25+1.8454925+0.23997
  • 50+1.7396750+0.22621
  • 100+1.63908100+0.21313
  • 250+1.51659250+0.19720
  • 500+1.42980500+0.18592
  • 1000+1.348121000+0.17530
库存:2935
