I N D U C T O R S
Inductors for power circuits
Wound ferrite
VLS-EX-D series(for automotive)
VLS5030EX-D type
■ FEATURES
◯ Magnetic shield type wound inductor for power circuits.
◯ High magnetic shield construction achieved by a magnetic material and compatible with high-density mounting.
◯ Larger current and lower Rdc were achieved by optimizing the ferrite core figure.
◯ Operating temperature range: –40 to +150 °C (including self-temperature rise)
■ APPLICATION
◯ Automotive-related equipment (PoC, headlights, airbags, short-range radar, electric power steering, various electronic control units,
etc.)
■ PART NUMBER CONSTRUCTION
VLS
5030
EX
Series name
L×W×H dimensions
5.0×5.3×3.0 mm
Internal code
4R7
M
Inductance
(µH)
Inductance
tolerance
D
Internal code
■ CHARACTERISTICS SPECIFICATION TABLE
L
Measuring
frequency
DC resistance Rated
current*
Part No.
Isat
Itemp
(μH)
Tolerance
(kHz)
(Ω)±20%
(A)max.
(A)typ.
(A)typ.
1.0
1.5
2.4
3.0
4.7
6.8
10
15
22
33
47
68
100
150
±30%
±30%
±30%
±30%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
100
100
100
100
100
100
100
100
100
100
100
100
100
100
0.012
0.014
0.021
0.026
0.040
0.056
0.080
0.12
0.18
0.27
0.35
0.55
0.80
1.16
6.5
5.4
4.4
4.2
3.3
2.7
2.1
1.6
1.5
1.1
0.99
0.82
0.65
0.54
7.3
6.1
4.9
4.7
3.7
3.0
2.4
1.8
1.7
1.3
1.1
0.92
0.73
0.61
6.5
6.1
5.1
4.4
3.4
2.8
2.4
1.9
1.6
1.3
1.1
0.91
0.75
0.63
VLS5030EX-1R0N-D
VLS5030EX-1R5N-D
VLS5030EX-2R4N-D
VLS5030EX-3R0N-D
VLS5030EX-4R7M-D
VLS5030EX-6R8M-D
VLS5030EX-100M-D
VLS5030EX-150M-D
VLS5030EX-220M-D
VLS5030EX-330M-D
VLS5030EX-470M-D
VLS5030EX-680M-D
VLS5030EX-101M-D
VLS5030EX-151M-D
* Rated current: smaller value of either Isat or Itemp.
Isat: When based on the inductance change rate (30% below the initial L value)
Itemp: When based on the temperature increase (temperature increase of 40°C by self heating)
* Itemp changes depending on the usage environment (board specifications, mounting density, etc.).
□ Measurement equipment
Measurement item
Product No.
L
4294A
DC resistance
34420A
Rated current Isat
4284A+42841A+42842A
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies, Inc. (formerly Hewlett-Packard)
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/4)
20221117
inductor_automotive_power_vls5030ex-d_en.xml
I N D U C T O R S
VLS5030EX-D type
■ L FREQUENCY CHARACTERISTICS
10000
151M
1000
101M
680M
Inductance(µH)
470M
330M
220M
150M
100
100M
6R8M
4R7M
10
3R0N
1R5N
2R4N
1
1R0N
0.1
0.01
0.1
1
Frequency(MHz)
10
100
Product No.
Manufacturer
4294A
■ INDUCTANCE VS. DC BIAS CHARACTERISTICS
1000
151M
Inductance(µH)
100
101M
680M
470M
330M
220M
150M
10
100M
6R8M
4R7M
3R0N
2R4N
1R5N
1
1R0N
0.1
2
3
4
5
DC current(A)
6
7
8
9
Product No.
Manufacturer
4284A+42841A+42842A
(2/4)
20221117
I N D U C T O R S
VLS5030EX-D type
■ SHAPE & DIMENSIONS
■ PACKAGING STYLE
3.0max.
1.75±0.2
(1.8)
1.75±0.2
□ REEL DIMENSIONS
(2)
3.7±0.2
ø100
5.0±0.2
4R7
2261
2±0.5
5.3±0.2
ø13±0.5
■ RECOMMENDED LAND PATTERN
(13)
ø330
1.5 +0.1
–0
2.0±0.1
4.0±0.1
Sprocket
hole
12.0±0.3
0.4
2.6
1.75±0.1
1.2
B
2.6
□ TAPE DIMENSIONS
5.5±0.05
4.0
Dimensions in mm
K
8.0±0.1
■ RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Cavity
A
Dimensions in mm
Natural
cooling
Peak
Type
A
B
K
VLS5030EX-D
5.35
5.65
3.2
250°C
□ PACKAGE QUANTITY
Temperature
220°C
220°C
5s
60 to 120s
2000 pcs/reel
■ TEMPERATURE RANGE, INDIVIDUAL WEIGHT
180°C
150°C
Package quantity
40s
Operating
temperature range *
Storage
temperature range **
Individual
weight
-40 to +150 °C
-40 to +150 °C
0.3 g
* Operating temperature range includes self-temperature rise.
** The storage temperature range is for after the assembly.
Time
(3/4)
20221117
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products
REMINDERS
○ The storage period is within 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 0 to 75% RH or less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
○ Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
○ Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
○ Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
○ When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the
overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
○ Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
○ Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
○ Use a wrist band to discharge static electricity in your body through the grounding wire.
○ Do not expose the products to magnets or magnetic fields.
○ Do not use for a purpose outside of the contents regulated in the delivery specifications.
○ The products described in this catalog are intended to be installed in automobiles or automotive electronic equipment (AV equipment,
telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment,
measurement equipment, industrial robots) and to be used in automobiles (including the case where the said automotive product is
mounted in a vehicle) or standard applications as general electronic equipment in automotive applications or standard applications as
general electronic equipment in automotive applications in accordance with the scope and conditions described in this specification,
while the said automotive or general electronic equipment including the said product is intended to be used in the usual operation and
usage methods, respectively. Other than automotive or automotive products are not designed or warranted to meet the requirements of
the applications listed below, whose performance and/or quality requires a more stringent level of safety or reliability, or whose failure,
malfunction or defect could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this specification sheet.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in this specification, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
(4/4)
20221117
很抱歉,暂时无法提供与“VLS5030EX-4R7M-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4.824781+0.58264
- 10+4.0595710+0.49024
- 25+4.0198925+0.48544
- 50+3.8691250+0.46724
- 100+3.48822100+0.42124
- 250+3.45987250+0.41782
- 500+2.93387500+0.35430
- 国内价格
- 10+3.14695
- 25+3.11620
- 50+2.99932
- 100+2.70404
- 250+2.68207
- 500+2.27431
