VLS5045EX-100M
VLS5045EX-100M
    TDK(东电化)
    SMD,5x5mm
    功率电感 10µH ±20% 5045 4.50mm 5.00 x 5.00mm 61mΩ 2.5A -
VLS5045EX-100M 数据手册
VLS-EX Series Consumer Grade Wire-Wound Power Inductors The TDK VLS-EX Series inductors are magnetically shielded, wire-wound inductors designed for power circuits. The exterior of the product is covered with a magnetic material to prevent leakage of magnetic flux generated inside the product, as well as to protect it from external effects. The ferrite magnetic material of the core exhibits higher permeability as compared to products with a metallic magnetic material core. This ferrite core results in a small eddy current loss and allows VLS-EX series power inductors to be used at relatively higher frequencies. Wire Wound Features  Magnetically shielded, wire-wound inductors  High magnetic shield construction achieved by a ferrite magnetic material  Larger current and lower Rdc have been achieved by optimizing the ferrite core figure  Compatible with high-density mounting  Operating temperature of –40°C to +105°C  Storage temperature of –40°C to +105°C after PC board mounting Power Consumer VLS5045-EX Series VLS6045-EX Series Applications  TVs  STBs  Game Devices  Other audiovisual equipment VLS-EX Series Includes: Case Size: 5045 & 6045 Inductance Range: 0.47-220µH (varies with case size) DC Resistance: 0.010– 1.15Ω Rated Current: 13.5-0.45mA max. 1,500 Pieces per Reel
VLS5045EX-100M 价格&库存
很抱歉,暂时无法提供与“VLS5045EX-100M”相匹配的价格&库存,您可以联系我们找货
VLS5045EX-100M
  • 1500+1.534251500+0.19822
  • 3000+1.446683000+0.18690
  • 4500+1.397824500+0.18059
  • 7500+1.338697500+0.17295
  • 10500+1.3011310500+0.16810
  • 15000+1.2624915000+0.16311
库存:16192
VLS5045EX-100M
    • 1+0.88025
    • 100+0.73354
    • 500+0.66686
    • 1000+0.61180
    • 1500+0.57446
    库存:1200
    VLS5045EX-100M
    • 5+0.84868
    • 50+0.67855
    • 300+0.59349
    • 600+0.58459
    • 1500+0.52969
    库存:918
    VLS5045EX-100M
    • 1+2.907271+0.37560
    • 10+2.3950310+0.30942
    • 100+1.96917100+0.25440
    库存:16192
    VLS5045EX-100M
