I N D U C T O R S
Inductors for power circuits
Wound ferrite
VLS-AF series
RoHS
REACH
SVHC-Free
Cl
Br
Pb
Halogen
Free
Lead
Free
VLS6045AF type
FEATURES
Magnetic shield type wound inductor for power circuits.
High magnetic shield construction achieved by a ferrite magnetic material and compatible with high-density mounting.
Optimization of THD+N (Total Harmonic Distortion + Noise) characteristics based on VLS6045EX coils
Operating temperature range: –40 to +105°C (Including self-temperature rise)
APPLICATION
Class-D amplifier (AI speakers, Bluetooth speakers, TV speakers)
RELATED PRODUCT INFORMATION
Solution guide to the use of noise suppression filters in audio lines
PART NUMBER CONSTRUCTION
VLS
6045
AF
Series name
L×W×H dimensions
6.0×6.0×4.5 mm
Internal code
3R3
N
Inductance
(µH)
Inductance
tolerance
CHARACTERISTICS SPECIFICATION TABLE
L
Measuring frequency
DC resistance
Rated current
Isat
(A)max.
5.0
4.3
3.5
3.2
3.0
2.5
2.1
1.6
1.0
(µH)
Tolerance
(kHz)
( )±30%
3.3
±30%
100
0.022
4.7
±20%
100
0.026
6.8
±20%
100
0.037
8.2
±20%
100
0.042
10
±20%
100
0.054
15
±20%
100
0.077
22
±20%
100
0.108
33
±20%
100
0.164
100
±20%
100
0.527
Rated current: smaller value of either Isat or Itemp.
Isat: When based on the inductance change rate (30% below the initial L value)
Itemp: When based on the temperature increase (temperature increase of 40°C by self heating)
Part No.
Itemp
(A)typ.
5.0
4.7
3.9
3.7
3.4
2.8
2.3
1.8
1.0
VLS6045AF-3R3N
VLS6045AF-4R7M
VLS6045AF-6R8M
VLS6045AF-8R2M
VLS6045AF-100M
VLS6045AF-150M
VLS6045AF-220M
VLS6045AF-330M
VLS6045AF-101M
Measurement equipment
Measurement item
Product No.
L
4294A
DC resistance
34420A
Rated current Isat
4284A+42841A+42842A
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies, Inc. (formerly Hewlett-Packard)
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/5)
20200805
inductor_commercial_power_vls6045af_en.fm
I N D U C T O R S
VLS6045AF type
TOTAL HARMONIC DISTORTION (TYPICAL CHARACTERISTICS)
THD+N measurement
THD+N v.s. Output power (f=1kHz, RL=8)
L=10µH C=0.68µF
Inductor
Speaker_+
1
Class-D
Amp
Speaker_
THD+N (%)
Inductor
0.1
VLS6045EX-100M
short
VLS6045AF-100M
0.01
0.0001
0.001
0.01
0.1
Output power (W)
1
10
1
10
THD+N v.s. Output power (f=1kHz, RL=4)
L=10µH C=0.68µF
Inductor
Speaker_+
1
Class-D
Amp
Speaker_
THD+N (%)
Inductor
0.1
VLS6045EX-100M
VLS6045AF-100M
0.01
0.0001
0.001
0.01
short
0.1
Output power (W)
(2/5)
20200805
I N D U C T O R S
VLS6045AF type
L FREQUENCY CHARACTERISTICS
1000
101M
330M
220M
150M
Inductance(µH)
100
100M
8R2M
6R8M
4R7M
3R3N
10
1
0.1
0.01
0.1
1
Frequency(MHz)
10
100
Product No.
Manufacturer
4294A
INDUCTANCE VS. DC BIAS CHARACTERISTICS
101M
100
Inductance(µH)
330M
220M
150M
10
100M
8R2M
6R8M
4R7M
3R3N
1
0.1
2
3
DC current(A)
4
5
6
Product No.
Manufacturer
4284A+42841A+42842A
(3/5)
20200805
I N D U C T O R S
VLS6045AF type
SHAPE & DIMENSIONS
PACKAGING STYLE
2.5±0.1
2.2
4.8±0.2
6.0±0.3
6.0±0.3
4.5max.
(2.6)
1.7±0.2
1.7±0.2
ø100
100
REEL DIMENSIONS
Dimensions in mm
ø13.2±0.5
13
ø330
Dimensions in mm
1.5 +0.1
–0
K
1.9
2.3
4.0±0.1
Sprocket
hole
12.0±0.3
2.0±0.1
B
5.1
0.4
5.5±0.05
RECOMMENDED LAND PATTERN
1.75±0.1
TAPE DIMENSIONS
Cavity
A
1.9
8.0±0.1
Dimensions in mm
Dimensions in mm
Type
VLS6045AF
A
6.3
B
6.3
K
4.7
PACKAGE QUANTITY
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Package quantity
Natural
cooling
Peak
250°C
Temperature
220°C
220°C
1500 pcs/reel
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
Storage temperature
Individual
range
range
weight
–40 to 105 °C
–40 to 105 °C
0.6 g
Operating temperature range includes self-temperature rise.
The storage temperature range is for after the assembly.
180°C
5s
150°C
60 to 120s
40s
Time
(4/5)
20200805
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is less than 6 months. Be sure to follow the storage conditions (temperature: 5 to 30°C, humidity: 0 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(5/5)
20200805
很抱歉,暂时无法提供与“VLS6045AF-220M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.446391+0.44785
- 10+2.8414110+0.36924
- 100+2.33299100+0.30317
- 国内价格
- 1+1.33413
- 10+1.05905
- 30+0.94122
- 100+0.79424
- 500+0.72879
- 1500+0.68948
- 国内价格 香港价格
- 1500+1.817831500+0.23622
- 3000+1.714093000+0.22274
- 4500+1.656214500+0.21522
- 7500+1.586157500+0.20612
- 10500+1.5416710500+0.20034
- 15000+1.4959315000+0.19439
