VLS6045EX-4R7M-H
VLS6045EX-4R7M-H
    TDK(东电化)
    SMD,6x6mm
    功率电感 4.7µH ±20% 27mΩ IND_6.3X6MM_SM
VLS6045EX-4R7M-H 数据手册
I N D U C T O R S Inductors for power circuits Wound ferrite VLS-EX-H series (for automotive) RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free AEC-Q200 VLS6045EX-H type FEATURES Magnetic shield type wound inductor for power circuits. High magnetic shield construction achieved by a ferrite magnetic material and compatible with high-density mounting. Larger current and lower Rdc were achieved by optimizing the ferrite core figure. Compliant with AEC-Q200 APPLICATION Automotive-related equipment (ECM, airbags, headlights, electronic power steering, meters, ABS, other) PART NUMBER CONSTRUCTION VLS 6045 EX - Series name L×W×H dimensions 6.0×6.3×4.5 mm Internal code 1R0 N - Inductance (µH) Inductance tolerance H Internal code CHARACTERISTICS SPECIFICATION TABLE L Measuring frequency DC resistance Rated current Isat (A)max. 12.0 8.2 7.5 6.5 5.8 4.7 3.9 3.1 2.4 1.9 1.8 1.4 1.1 0.9 0.8 (µH) Tolerance (kHz) ( )±30% 1.0 ±30% 100 0.012 1.5 ±30% 100 0.017 2.2 ±30% 100 0.019 3.3 ±30% 100 0.023 4.7 ±20% 100 0.027 6.8 ±20% 100 0.036 10 ±20% 100 0.047 15 ±20% 100 0.075 22 ±20% 100 0.105 33 ±20% 100 0.175 47 ±20% 100 0.23 68 ±20% 100 0.31 100 ±20% 100 0.47 150 ±20% 100 0.76 220 ±20% 100 1.15  Rated current: smaller value of either Isat or Itemp. Isat: When based on the inductance change rate (30% below the initial L value) Itemp: When based on the temperature increase (temperature increase of 40°C by self heating) Part No. Itemp (A)typ. 6.0 5.3 5.1 4.95 4.2 3.6 3.4 2.5 1.9 1.5 1.3 1.0 0.9 0.7 0.5 VLS6045EX-1R0N-H VLS6045EX-1R5N-H VLS6045EX-2R2N-H VLS6045EX-3R3N-H VLS6045EX-4R7M-H VLS6045EX-6R8M-H VLS6045EX-100M-H VLS6045EX-150M-H VLS6045EX-220M-H VLS6045EX-330M-H VLS6045EX-470M-H VLS6045EX-680M-H VLS6045EX-101M-H VLS6045EX-151M-H VLS6045EX-221M-H Measurement equipment Measurement item Product No. L 4294A DC resistance 34420A Rated current Isat 4284A+42841A+42842A * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies, Inc. (formerly Hewlett-Packard) Keysight Technologies, Inc. (formerly Hewlett-Packard) Keysight Technologies, Inc. (formerly Hewlett-Packard) TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating temperature range Storage temperature range –40 to 125 °C –40 to 125 °C  Operating temperature range includes self-temperature rise.  The storage temperature range is for after the assembly. Individual weight 0.6 g Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20200805 inductor_automotive_power_vls6045ex-h_en.fm I N D U C T O R S VLS6045EX-H type L FREQUENCY CHARACTERISTICS 10000 221 151 1000 101 Inductance(µH) 680 470 330 220 100 150 100 6R8 4R7 3R3 10 2R2 1R5 1R0 1 0.1 0.01 0.1 1 Frequency(MHz) 10 100 Measurement equipment Product No. Manufacturer 4294A Keysight Technologies, Inc. (formerly Hewlett-Packard) * Equivalent measurement equipment may be used. INDUCTANCE VS. DC BIAS CHARACTERISTICS 1000 221 151 100 101 Inductance(µH) 680 470 330 220 150 10 100 6R8 4R7 3R3 2R2 1R5 1 1R0 0.1 0 2 4 6 8 DC current(A) 10 12 14 16 Measurement equipment Product No. Manufacturer 4284A+42841A+42842A Keysight Technologies, Inc. (formerly Hewlett-Packard) * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/4) 20200805 inductor_automotive_power_vls6045ex-h_en.fm I N D U C T O R S VLS6045EX-H type SHAPE & DIMENSIONS PACKAGING STYLE 100 8301 REEL DIMENSIONS 2.5±0.1 6.0±0.3 4.8±0.2 2.2 4.5max. (2.6) 1.85±0.2 1.85±0.2 ø100 6.3±0.3 Dimensions in mm ø13.2±0.5 13 ø330 Dimensions in mm 1.5 +0.1 –0 4.0±0.1 Sprocket hole 12.0±0.3 2.0±0.1 B 5.1 0.4 5.5±0.05 RECOMMENDED LAND PATTERN 1.75±0.1 TAPE DIMENSIONS A A 2.3 A Solder fillet required 2.4 Solder fillet not required 2.1 K Cavity A 8.0±0.1 Dimensions in mm Dimensions in mm Type VLS6045EX-H A 6.35 B 6.65 K 4.7 PACKAGE QUANTITY RECOMMENDED REFLOW PROFILE Preheating Soldering Package quantity 1500 pcs/reel Natural cooling Peak 250°C Temperature 220°C 220°C 180°C 5s 150°C 60 to 120s 40s Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20200805 inductor_automotive_power_vls6045ex-h_en.fm I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is within 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 0 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products described in this catalog are intended to be installed in automobiles or automotive electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) and to be used in automobiles (including the case where the said automotive product is mounted in a vehicle) or standard applications as general electronic equipment in automotive applications or standard applications as general electronic equipment in automotive applications in accordance with the scope and conditions described in this specification, while the said automotive or general electronic equipment including the said product is intended to be used in the usual operation and usage methods, respectively. Other than automotive or automotive products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality requires a more stringent level of safety or reliability, or whose failure, malfunction or defect could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in this specification, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20200805 inductor_automotive_power_vls6045ex-h_en.fm
VLS6045EX-4R7M-H 价格&库存
很抱歉,暂时无法提供与“VLS6045EX-4R7M-H”相匹配的价格&库存,您可以联系我们找货
VLS6045EX-4R7M-H
  • 1+3.703951+0.47532
  • 10+3.0805810+0.39533
  • 100+2.53353100+0.32513
库存:2577
VLS6045EX-4R7M-H
    VLS6045EX-4R7M-H
    • 5+1.25110
    • 50+1.01310
    • 150+0.85150
    • 500+0.76590
    • 1500+0.68760
    • 4500+0.66960
    库存:4022
    VLS6045EX-4R7M-H
    • 1+1.02411
    • 30+0.98561
    • 100+0.94711
    • 500+0.87011
    • 1000+0.83161
    • 2000+0.80851
