VLS6045EX-6R8N
VLS6045EX-6R8N
    TDK(东电化)
    SMD,6x6mm
    固定电感器 Nonstandard 6.8µH ±30% 3.6A 36mΩ
VLS6045EX-6R8N 数据手册
I N D U C T O R S Inductors for power circuits Wound ferrite VLS-EX series RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free VLS6045EX type FEATURES Magnetic shield type wound inductor for power circuits. High magnetic shield construction achieved by a ferrite magnetic material and compatible with high-density mounting. Larger current and lower Rdc were achieved by optimizing the ferrite core figure. Operating temperature range: –40 to +105°C (including self-temperature rise) APPLICATION TV, STB, gaming equipment, other AV equipment PART NUMBER CONSTRUCTION VLS 6045 EX - Series name L×W×H dimensions 6.0×6.0×4.5 mm Internal code R47 N Inductance (µH) Inductance tolerance CHARACTERISTICS SPECIFICATION TABLE L Measuring frequency DC resistance Rated current Isat (µH) Tolerance (kHz) ( )±30% (A)max. 0.47 ±30% 100 0.010 13.5 1.0 ±30% 100 0.012 12.0 1.5 ±30% 100 0.017 8.2 2.2 ±30% 100 0.019 7.5 3.3 ±30% 100 0.023 6.5 4.7 ±20% 100 0.027 5.8 6.8 ±20% 100 0.036 4.7 10 ±20% 100 0.047 3.9 15 ±20% 100 0.075 3.1 22 ±20% 100 0.105 2.4 33 ±20% 100 0.175 1.9 47 ±20% 100 0.23 1.8 68 ±20% 100 0.31 1.4 100 ±20% 100 0.47 1.1 150 ±20% 100 0.76 0.9 220 ±20% 100 1.15 0.8 330 100 1.44 0.5 ±20% 470 100 2.14 0.4 ±20% 680 100 2.95 0.3 ±20%  Rated current: smaller value of either Isat or Itemp. Isat: When based on the inductance change rate (30% below the initial L value) Itemp: When based on the temperature increase (temperature increase of 40°C by self heating) Part No. Itemp (A)typ. 7.0 6.0 5.3 5.1 4.95 4.2 3.6 3.4 2.5 1.9 1.5 1.3 1.0 0.9 0.7 0.5 0.47 0.42 0.32 VLS6045EX-R47N VLS6045EX-1R0N VLS6045EX-1R5N VLS6045EX-2R2N VLS6045EX-3R3N VLS6045EX-4R7M VLS6045EX-6R8M VLS6045EX-100M VLS6045EX-150M VLS6045EX-220M VLS6045EX-330M VLS6045EX-470M VLS6045EX-680M VLS6045EX-101M VLS6045EX-151M VLS6045EX-221M VLS6045EX-331M VLS6045EX-471M VLS6045EX-681M Measurement equipment Measurement item Product No. L 4194A DC resistance VP-2941A Rated current Isat 4284A+42841A+42842A * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies, Inc. (formerly Hewlett-Packard) Panasonic (formerly Matsushita Electric Industrial) Keysight Technologies, Inc. (formerly Hewlett-Packard) Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/5) 20200805 inductor_commercial_power_vls6045ex_en.fm I N D U C T O R S VLS6045EX type L FREQUENCY CHARACTERISTICS 681M 471M 331M 221M 151M 1000 101M 680M 470M 330M 220M Inductance(µH) 150M 100M 6R8M 4R7M 3R3N 10 2R2N 1R5N 1R0N R47N 0.1 0.01 0.1 1 Frequency(MHz) 10 100 Measurement equipment Product No. Manufacturer 4294A Keysight Technologies, Inc. (formerly Hewlett-Packard) * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/5) 20200805 inductor_commercial_power_vls6045ex_en.fm I N D U C T O R S VLS6045EX type INDUCTANCE VS. DC BIAS CHARACTERISTICS 1000 681M 471M 331M 221M 100 151M 101M 680M 470M Inductance(µH) 330M 220M 10 150M 100M 6R8M 4R7M 3R3N 2R2N 1R5N 1 1R0N R47N 0.1 0 2 4 6 8 10 DC current(A) 12 14 16 18 Measurement equipment Product No. Manufacturer 4284A+42841A+42842A Keysight Technologies, Inc. (formerly Hewlett-Packard) * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/5) 20200805 inductor_commercial_power_vls6045ex_en.fm I N D U C T O R S VLS6045EX type SHAPE & DIMENSIONS PACKAGING STYLE 2.5±0.1 2.2 4.8±0.2 6.0±0.3 6.0±0.3 4.5max. (2.6) 1.7±0.2 1.7±0.2 ø100 100 REEL DIMENSIONS Dimensions in mm ø13.2±0.5 13 ø330 Dimensions in mm 1.5 +0.1 –0 K 1.9 2.3 4.0±0.1 Sprocket hole 12.0±0.3 2.0±0.1 B 5.1 0.4 5.5±0.05 RECOMMENDED LAND PATTERN 1.75±0.1 TAPE DIMENSIONS Cavity A 1.9 8.0±0.1 Dimensions in mm Dimensions in mm Type VLS6045EX A 6.3 B 6.3 K 4.7 PACKAGE QUANTITY Package quantity RECOMMENDED REFLOW PROFILE Preheating Soldering Natural cooling Peak 250°C Temperature 220°C 220°C 1500 pcs/reel TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating Storage Individual temperature range temperature range weight –40 to 105 °C –40 to 105 °C 0.6 g  Operating temperature range includes self-temperature rise.  The storage temperature range is for after the assembly. 180°C 5s 150°C 60 to 120s 40s Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/5) 20200805 inductor_commercial_power_vls6045ex_en.fm I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is less than 6 months. Be sure to follow the storage conditions (temperature: 5 to 30°C, humidity: 0 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (5/5) 20200805 inductor_commercial_power_vls6045ex_en.fm
VLS6045EX-6R8N 价格&库存
很抱歉,暂时无法提供与“VLS6045EX-6R8N”相匹配的价格&库存,您可以联系我们找货
