VSC/VSP Series
10W to 150W Single Output, 115VAC Input
Features
Input transient protected
2 year warranty
High quality design
200% Peak Power Version (VSP)
Broad product range
Key Market Segments & Applications
Specifications
Model
AC Input Voltage range
DC Input Voltage range
VDC
Inrush Current (100VAC)
(1)
A
Temperature Coefficient
Overcurrent Protection
(2)
Overvoltage Protection
V
Hold Up Time (Typ) at 100VAC
ms
Remote Sense
Operating Temperature
(3)
Storage Temperature
Humidity (non condensing)
Cooling
(4)
Withstand Voltage
Isolation Resistance
Vibration (non operating)
Shock
Safety Agency Approvals
Conducted & Radiated EMI
Recommended EMI Filter
Weight (Typ) (VSP)
Size (WxHxD)
Warranty
g
mm
yrs
VS10C
VS15C
VS30C
VS50P
VS75P
VS100P
VS150P
85-132VAC (47-440Hz)
110 - 175VDC
25
30
25
30
30
102% of Peak
~115% Diode Clamp
~115 - 135% Manual Reset
None
-10ºC to +60ºC, derate linearly to 70% load from 50ºC to 60ºC
-30 to +85ºC
Storage 10-95% RH, Operating 30-90% RH
Convection
Forced
Input to Ground 2kVAC (20mA), Input to Output 2kVAC (20mA),
Output to Ground 500VAC (100mA) for 1 min.
>100M at 25°C & 70%RH, Output to Ground 500VDC
10 - 55Hz (1 minute sweep), 19.6m/s 2 constant X, Y, Z 1 hour
< 196.1 m/s2
UL60950-1, CSA60950-1, EN60950-1
FCC Class B, VCCI-B
RSEL-20R5W
RSEL-2001W
RSEL-2002W RSEL-2003W
RSEL-2006W
65
80
150
200
280
350
480
See Outline Drawings
Two Years
Notes:
(1) 25°C ambient (cold start)
(2) Avoid prolonged operartion in overload
(3) VS50P derate to 60% at 60°C
(4) 0.7m/s forced air required, consult installation manual for derating with convection cooling
VS-P Models Last Time Buy November 2019
1-800-526-2324 • www.us.tdk-lambda.com/lp/
150
Disclaimer: us.tdk-lambda.com/lp/legal.htm
VSC/VSP Series
VSC30 Outline Drawing
VSP100 Outline Drawing
Model Selector
Model
Adjust
Voltage Range
V
V
VS10C-3
VS15C-3
VS30C-3
VS10C-5
VS15C-5
VS30C-5
VS10C-12
VS15C-12
VS30C-12
VS10C-15
VS15C-15
VS30C-15
VS10C-24
VS15C-24
VS30C-24
VS50P-24
VS75P-24
VS100P-24
VS150P-24
VS30C-36
VS30C-48
3.3
3.3
3.3
5
5
5
12
12
12
15
15
15
24
24
24
24
24
24
24
36
48
2.97-3.63
2.97-3.63
2.97-3.63
4.5-5.5
4.5-5.5
4.5-5.5
10.8-13.2
10.8-13.2
10.8-13.2
13.5-16.5
13.5-16.5
13.5-16.5
21.6-26.4
21.6-26.4
21.6-26.4
21.6-26.4
21.6-26.4
21.6-26.4
21.6-26.4
32.4-39.6
43.2-52.8
Other Industrial Products
Max Peak Load
Curr. Curr. Reg
A
A
mV
2
3
6
2
3
6
0.9
1.3
2.5
0.7
1
2
0.5
0.7
1.3
2.5
3.2
4.3
6.3
0.9
0.7
4.2
7.0
10
12
40
40
40
40
40
40
96
96
96
120
120
120
240
240
150
150
150
150
150
240
480
Line
Reg
mV
48
48
60
60
60
96
96
96
96
96
96
96
144
192
Ripple
Noise Eff.
mV
120
120
120
120
120
120
150
150
150
150
150
150
200
200
200
180
180
180
180
300
400
62
62
69
71
72
75
75
75
80
75
75
81
78
78
82
83
83
85
86
80
80
HWS
ZWS, ZWD, ZWQ
SC, SCS120
ZP
15W to 1500W Single output
5W to 240W Universal input
30W to 120W Single, dual & triple output
40W to 60W Single & multiple output
For Additional Information, please visit
us.tdk-lambda.com/lp/products/vsb-series.htm
Peak Current Note: For 10s maximum, 35% duty cycle, average power
not to exceed maximum ratings. See installation manual.
151
Revision A8: Jan 2019
很抱歉,暂时无法提供与“VS15C-12”相匹配的价格&库存,您可以联系我们找货
