VS50B-12
VS50B-12
    TDK(东电化)
    VS50B-12
VS50B-12 数据手册
VSC/VSP Series 10W to 150W Single Output, 115VAC Input Features  Input transient protected  2 year warranty  High quality design  200% Peak Power Version (VSP)  Broad product range Key Market Segments & Applications Specifications Model AC Input Voltage range DC Input Voltage range VDC Inrush Current (100VAC) (1) A Temperature Coefficient Overcurrent Protection (2) Overvoltage Protection V Hold Up Time (Typ) at 100VAC ms Remote Sense Operating Temperature (3) Storage Temperature Humidity (non condensing) Cooling (4) Withstand Voltage Isolation Resistance Vibration (non operating) Shock Safety Agency Approvals Conducted & Radiated EMI Recommended EMI Filter Weight (Typ) (VSP) Size (WxHxD) Warranty g mm yrs VS10C VS15C VS30C VS50P VS75P VS100P VS150P 85-132VAC (47-440Hz) 110 - 175VDC 25 30 25 30 30 20 20 102% of Peak ~115% Diode Clamp ~115 - 135% Manual Reset 20 17 None -10ºC to +60ºC, derate linearly to 70% load from 50ºC to 60ºC -30 to +85ºC Storage 10-95% RH, Operating 30-90% RH Convection Forced Input to Ground 2kVAC (20mA), Input to Output 2kVAC (20mA), Output to Ground 500VAC (100mA) for 1 min. >100M at 25°C & 70%RH, Output to Ground 500VDC 10 - 55Hz (1 minute sweep), 19.6m/s 2 constant X, Y, Z 1 hour < 196.1 m/s2 UL60950-1, CSA60950-1, EN60950-1 FCC Class B, VCCI-B RSEL-20R5W RSEL-2001W RSEL-2002W RSEL-2003W RSEL-2006W 65 80 150 200 280 350 480 See Outline Drawings Two Years Notes: (1) 25°C ambient (cold start) (2) Avoid prolonged operartion in overload (3) VS50P derate to 60% at 60°C (4) 0.7m/s forced air required, consult installation manual for derating with convection cooling VS-P Models Last Time Buy November 2019 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 150 Disclaimer: us.tdk-lambda.com/lp/legal.htm VSC/VSP Series VSC30 Outline Drawing VSP100 Outline Drawing Model Selector Model Adjust Voltage Range V V VS10C-3 VS15C-3 VS30C-3 VS10C-5 VS15C-5 VS30C-5 VS10C-12 VS15C-12 VS30C-12 VS10C-15 VS15C-15 VS30C-15 VS10C-24 VS15C-24 VS30C-24 VS50P-24 VS75P-24 VS100P-24 VS150P-24 VS30C-36 VS30C-48 3.3 3.3 3.3 5 5 5 12 12 12 15 15 15 24 24 24 24 24 24 24 36 48 2.97-3.63 2.97-3.63 2.97-3.63 4.5-5.5 4.5-5.5 4.5-5.5 10.8-13.2 10.8-13.2 10.8-13.2 13.5-16.5 13.5-16.5 13.5-16.5 21.6-26.4 21.6-26.4 21.6-26.4 21.6-26.4 21.6-26.4 21.6-26.4 21.6-26.4 32.4-39.6 43.2-52.8 Other Industrial Products Max Peak Load Curr. Curr. Reg A A mV 2 3 6 2 3 6 0.9 1.3 2.5 0.7 1 2 0.5 0.7 1.3 2.5 3.2 4.3 6.3 0.9 0.7 4.2 7.0 10 12 - 40 40 40 40 40 40 96 96 96 120 120 120 240 240 150 150 150 150 150 240 480 Line Reg mV 20 20 20 20 20 20 48 48 48 60 60 60 96 96 96 96 96 96 96 144 192 Ripple Noise Eff. mV % 120 120 120 120 120 120 150 150 150 150 150 150 200 200 200 180 180 180 180 300 400 62 62 69 71 72 75 75 75 80 75 75 81 78 78 82 83 83 85 86 80 80 HWS ZWS, ZWD, ZWQ SC, SCS120 ZP 15W to 1500W Single output 5W to 240W Universal input 30W to 120W Single, dual & triple output 40W to 60W Single & multiple output For Additional Information, please visit us.tdk-lambda.com/lp/products/vsb-series.htm Peak Current Note: For 10s maximum, 35% duty cycle, average power not to exceed maximum ratings. See installation manual. VS-P Models Last Time Buy November 2019 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 151 Revision A8: Jan 2019
VS50B-12
- 物料型号:VSC/VSP系列,包括VS10C、VS15C、VS30C、VS50P、VS75P、VS100P、VS150P等型号。 - 器件简介:这些电源模块具有输入瞬态保护、2年保修、高质量设计,并且有200%峰值功率版本(VSP)。 - 引脚分配:文档中未明确提供引脚分配信息,但通常电源模块会有输入、输出和可能的控制引脚。 - 参数特性:包括AC输入电压范围、DC输入电压范围、冲击电流、温度系数、过流保护、过压保护、保持时间、远程感应等。 - 功能详解:文档提供了不同型号的调整范围、最大峰值负载电流、电流调节、线路调节、纹波噪声效率等详细参数。 - 应用信息:文档提到了RoHS合规性,推荐了EMI滤波器型号,并提供了安全机构认证信息。 - 封装信息:提供了VSC30和VSP100型号的外形图,但未提供所有型号的封装信息
VS50B-12 价格&库存
很抱歉,暂时无法提供与“VS50B-12”相匹配的价格&库存,您可以联系我们找货
