WR-383250-17M2-G
WR-383250-17M2-G
    TDK(东电化)
    插件
    无线充电线圈 11.1uH ±5%
WR-383250-17M2-G 数据手册
PRODUCT SPECIFICATION SPEC. No: Attn: DATE: Dec.17.2012 CUSTOMER PRODUCT NAME: TDK PRODUCT NAME: WR-383250-17M2-G APPROVED BY: CUSTOMER COMMENT: REMARK: Please sign back specification after customer conformation until 2weeks. If customer can't sign back specification, customer should be approved TDK specification. TDK-EPC Corporation Head Office Address: 1-13-1, Nihonbashi, Chuo-ku, Tokyo 103-0027 , Japan ENGINEERING SALES MANAGER Sales Office Sales Tel. APPROVED SALES PRODUCT CHECKED ISSUED REVISED HISTORY CUSTOMER PRODUCT NAME: TDK PRODUCT NAME: NO. REV. WR-383250-17M2-G REVISED CONTENT REVISED REASON DATE To establish specification 1 2 3 0 2012.12.17 1/6 PRODUCT SPECIFICATION TDK PRODUCT NAME: SPEC. NO. CUSTOMER PRODUCT NAME: WR-383250-17M2-G (1) Apperance & Dimensions (Unit: mm) Weight: 4.19g (Typ.) Lead wire pitch (Promised position) TOP VIEW SIDE VIEW [ Remarks] 1. Lead Wire Pitch is the end of wire position, not Output terminal. 2. Marking Content: a. T: Manufacturing Centers b. Lot No.: □□ ○○ (1) (2) △△ (3) (1) Year: A.D. end number in double (2) Month: Jan.(01) , Feb.(02)…Dec.(12) (3) Day: 01,02,03,…31. 2/6 PRODUCT SPECIFICATION TDK PRODUCT NAME: SPEC. NO. CUSTOMER PRODUCT NAME: WR-383250-17M2-G (2) Air coil specification Wire Diameter: φ0.25*2 ( Bifilar Winding Coil) Coil Turns: 17Ts (3) Electrical Characteristics No. Parameter Specification 1 Inductance 11.1 µH ± 5 % 2 DC Resistance 0.27 Ω Max (At 25℃) Test Instrument HP 4284A DIGITAL LCR METER or EQUIVALENT (@100kHz 1.0 Vrms) CHEN HWA 502A METER or EQUIVALENT (4) Temperature Characteristics No. Parameter Specification 1 Operating Temperature -30~70℃ 2 Storage Temperature -40~85℃ (5) Application 1. Reflow and dip-flow soldering can not used for this product. 2. The product fit in with RoHS rule. 3. The product fit in with Halogen-Free. 3/6 PRODUCT SPECIFICATION TDK PRODUCT NAME: SPEC. NO. CUSTOMER PRODUCT NAME: WR-383250-17M2-G (6) Reliability Conditions No. Parameter Conditions 1 Low Temperature (Storage) (1) Temperature:-40±2℃ (2) Time:240Hrs 2 High Temperature (Storage) (1) Temperature:+85±2℃ (2) Time:240Hrs 3 Thermal Shock (Storage) (1) Temperature : - 40±5℃ / 30min ~ + 85±5℃ / 30min (2) Ambient Time : 5min (3) Times : 100cycles Vibration Unpacked: (1)frequency:10~500Hz sweep octave wave(1 oct/ min) (2)Amplitude:10G or 1.5mm P-P (3)Testing time : XYZ 2h/axis, total 6h 4 5 Shock Test Fixed within the jig (1) Acceleration:1000m / s2 (2) Pulse width : 6 msec (3) Direction:±X,±Y,±Z (4) Frequency of shock:3 times each (Total 18 times) Half-sine shock (1) 200G, 3ms(Gravity) (2) One shock per face (3) Total 6 shocks 6 7 8 Temperature / Humidity (Storage) (1) Temperature : +60±2℃ (2) Humidity: 90% RH. (3) Time: 240Hrs Drop Test (1) Height : 160cm to the concrete floor (fixture weight : 160g ) (2) Direction : 6 directions (3) Times : 3 times / direction Package Drop (1) Drop the sample package in a carton box. (2) Height : 100 cm (3) Direction :1corner,3 edges, 6 faces (4) Drop time : 16 times 4/6 PRODUCT SPECIFICATION TDK PRODUCT NAME: SPEC. NO. CUSTOMER PRODUCT NAME: WR-383250-17M2-G (7) Construction (2) (4) ( 3) (1) ( 3) (5) (8) Material List No. Material Name 1 Iron Sheet 2 PET Tape 3 Adhesive Tape 4 Air Coil 5 Ink 5/6 PRODUCT SPECIFICATION TDK PRODUCT NAME: SPEC. NO. CUSTOMER PRODUCT NAME: WR-383250-17M2-G (9) Packing 1. To stack the the Trays onto 5 Layers. : - PET tray dimension: 326*329*9.5mm (REF.) - 30 Pcs / per PET tray TOP one Tray is empty 5-Layers Total : 6x5=30 pcs Total : 30x4=120 pcs 2. To put 5 Trays of products into the small Carton and affixing the out-going label on the outside . - Small carton dimension: 331*337*33mm (REF.) - 5 PET Trays / per small carton ( One PET tray of the top side is empty in the small carton) Out-going Label CUST PROD ID( ID(P): WR-383250-17M2-XX Customer ROHS QTY(Q): 120 (6P):TXDF ):TXDF1010 TXDF10108 1010 8TWN050009010 TWN 050009010 TDK ITEM(1P): R-383250-17M2-XX LOT NO(1T): WL11K06001+M0001 2011/10/09 VDR(V):TDK DATE CODE(T): 1143 0001 001/014 12296A1181 MADE IN TAIWAN (S) (ITEM:WR-383250-17M2-XX) (1M)TTXDF10108 Out-going Label TDK TAIWAN CORPORATION 6/6 PRODUCT SPECIFICATION TDK PRODUCT NAME: SPEC. NO. CUSTOMER PRODUCT NAME: WR-383250-17M2-G 3. To put 3 small corton into the Carton . - Outer carton dimension: 347*340*124mm (REF.) - 3 small cartons / per outer carton - Total quantity : 360 Pcs 4. Packing. -To pack the carton by scoth tape and affix out-going label (outside) on it outside. -The inspection data in the box , there would be a signet mark on it outside. INSPECTION DATA ENCLOSED 檢 驗 紀 錄 表在 內 (3S) TTW+WL11K0600200101400000360 Customer   CUSTOMER: CUSTOMER:  CUST. CUST. PART NO( NO(P): 54H 54H20323- 20323-00M 00M BOX COUNT (6S) C/NO:1 001/014 ROHS TDK ITEM CODE(6P): TXDF1010 TXDF10108 10108TWN       SHIPPING MARK P/O NO.(K): 929429- 929429- 10 LOT NO.(1T): WL11K06002 DATE: Dec.19.2011 QTY(Q): 360 TDK ITEM (1P): WR-383250-17M2-XX Customer SHENZHEN MADE IN TAIWAN SUB P/O NO.(6K): (WR-383250-17M2-XX) -10 -10 WL11 WL11K 11K06002 12296A 12296A1181 TDK SPEC. C/NO: NO:1 WAREHOUSE NW 3.3 ( CT ) TDK TAIWAN CORPORATION GW 3.8 14 YANGMI, TAIWAN TTXDF10108 TTXDF10108
WR-383250-17M2-G 价格&库存
很抱歉,暂时无法提供与“WR-383250-17M2-G”相匹配的价格&库存,您可以联系我们找货
