WR-483250-15M2-G
WR-483250-15M2-G
    TDK(东电化)
    插件
    无线充电线圈 10.5uH ±5%
WR-483250-15M2-G 数据手册
PRODUCT SPECIFICATION SPEC. No: Attn: DATE: Dec.17.2012 CUSTOMER PRODUCT NAME: TDK PRODUCT NAME: WR-483250-15M2-G APPROVED BY: CUSTOMER COMMENT: REMARK: Please sign back specification after customer conformation until 2weeks. If customer can't sign back specification, customer should be approved TDK specification. TDK-EPC Corporation Head Office Address: 1-13-1, Nihonbashi, Chuo-ku, Tokyo 103-0027 , Japan ENGINEERING SALES MANAGER Sales Office Sales Tel. APPROVED SALES PRODUCT CHECKED ISSUED REVISED HISTORY CUSTOMER PRODUCT NAME: TDK PRODUCT NAME: NO. REV. WR-483250-15M2-G REVISED CONTENT REVISED REASON DATE To establish specification 1 0 2012.12.17 1/6 PRODUCT SPECIFICATION TDK PRODUCT NAME: SPEC. NO. CUSTOMER PRODUCT NAME: WR-483250-15M2-G (1) Apperance & Dimensions (Unit: mm) Weight: 6.30g (Typ.) TOP VIEW Lead wire pitch /PET position (Promised position) SIDE VIEW [ Remarks] 1. Lead Wire Pitch is the end of wire position, not Output terminal. 2. Marking Content: a. T: Manufacturing Centers b: Lot No.: □□ ○○ (1) (2) △△ (3) (1) Year: A.D. end number in double (2) Month: Jan.(01) , Feb.(02)…Dec.(12) (3) Day: 01,02,03,…31. 2/6 PRODUCT SPECIFICATION TDK PRODUCT NAME: SPEC. NO. CUSTOMER PRODUCT NAME: WR-483250-15M2-G (2) Air coil specification Wire Diameter: φ0.30*2 ( Bifilar Winding Coil) Coil Turns: 15Ts (3) Electrical Characteristics No. Parameter Specification Test Instrument 1 Inductance 10.5 µH ± 5 % HP 4284A DIGITAL LCR METER or EQUIVALENT (@100kHz 1.0 Vrms) 2 DC Resistance 0.20 Ω Max (At 25℃) CHEN HWA 502A OHM METER or EQUIVALENT (4) Temperature Characteristics No. Parameter Specification 1 Operating Temperature -30~70℃ 2 Storage Temperature -40~85℃ (5) Application 1. Reflow and dip-flow soldering can not used for this product. 2. The product fit in with RoHS rule. 3. The product fit in with Halogen-Free. 3/6 PRODUCT SPECIFICATION TDK PRODUCT NAME: SPEC. NO. CUSTOMER PRODUCT NAME: WR-483250-15M2-G (6) Reliability Conditions No. Parameter Conditions 1 Low Temperature (Storage) (1) Temperature:-40±2℃ (2) Time:240Hrs 2 High Temperature (Storage) (1) Temperature:+85±2℃ (2) Time:240Hrs 3 Thermal Shock (Storage) (1) Temperature : - 40±5℃ / 30min ~ + 85±5℃ / 30min (2) Ambient Time : 5min (3) Times : 100cycles Vibration Unpacked: (1)frequency:10~500Hz sweep octave wave(1 oct/ min) (2)Amplitude:10G or 1.5mm P-P (3)Testing time : XYZ 2h/axis, total 6h 4 5 Shock Test Fixed within the jig (1) Acceleration:1000m / s2 (2) Pulse width : 6 msec (3) Direction:±X,±Y,±Z (4) Frequency of shock:3 times each (Total 18 times) Half-sine shock (1) 200G, 3ms(Gravity) (2) One shock per face (3) Total 6 shocks 6 Temperature / Humidity (Storage) (1) Temperature : +60±2℃ (2) Humidity: 90% RH. (3) Time: 240Hrs 7 Drop Test (1) Height : 160cm to the concrete floor (fixture weight : 100g(REF) ) (2) Direction : 6 directions (3) Times : 3 times / direction Package Drop (1) Drop the sample package in a carton box. (2) Height : 100 cm (3) Direction :1corner,3 edges, 6 faces (4) Drop time : 16 times 8 4/6 PRODUCT SPECIFICATION TDK PRODUCT NAME: SPEC. NO. CUSTOMER PRODUCT NAME: WR-483250-15M2-G (7) Construction (4) (2) (3) (1) (2) (5) (8) Material List No. Material Name 1 Iron Sheet 2 PET Tape 3 Adhesive Tape 4 Air Coil 5 Ink 5/6 PRODUCT SPECIFICATION TDK PRODUCT NAME: SPEC. NO. CUSTOMER PRODUCT NAME: WR-483250-15M2-G (9) Packing 1. To stack the the Trays onto 5 Layers. : - PS tray dimension: 326*329*9.5mm (REF.) - 16 Pcs / per PS tray TOP one Tray is empry 5-Layers Total : 6x2+4=16pcs Total : 16x4=64pcs 2. To put 5 Trays of products into the small Carton and affixing the out-going label on the outside . - Small carton dimension: 331*337*33mm (REF.) - 5 PS Trays / per small carton ( One PS tray of the top side is empty in the small carton) Out-going Label CUST PROD ID( ID(P): WR-383250-17M2-XX Customer ROHS QTY(Q): 120 (6P):TXDF ):TXDF1010 TXDF10108 1010 8TWN050009010 TWN 050009010 TDK ITEM(1P): R-383250-17M2-XX LOT NO(1T): WL11K06001+M0001 2011/10/09 DATE CODE(T): 1143 0001 001/014 12296A1181 (S) MADE IN TAIWAN (ITEM:WR-383250-17M2-XX) VDR(V):TDK (1M)TTXDF10108 Out-going Label TDK TAIWAN CORPORATION 6/6 PRODUCT SPECIFICATION TDK PRODUCT NAME: SPEC. NO. CUSTOMER PRODUCT NAME: WR-483250-15M2-G 3. To put 3 small corton into the Carton . - Outer carton dimension: 347*340*124mm (REF.) - 3 small cartons / per outer carton - Total quantity : 192 Pcs 3 small cartons Outer carton 4. Packing. -To pack the carton by scoth tape and affix out-going label (outside) on it outside. -The Inspection data in the box , there would be a signet mark on it outside. scoth tape INSPECTION DATA ENCLOSED 檢 驗 紀 錄 表在 內 signet mark of Inspection data (3S) TTW+WL11K0600200101400000360 Customer  CUSTOMER: CUSTOMER:  CUST. 12 A34567- 34567-89A 89A CUST. PART NO( NO( P) :  12A BOX COUNT (6S) C/NO:1 TDK ITEM CODE(6P): 001/009 ROHS TXDF10105TWN       SHIPPING MARK P/O NO.(K): TSHV- TSHV- S001016344 LOT NO.(1T): WL12345678 DATE: Oct.07.2011 288 QTY(Q): Customer SHANGHAI TDK ITEM (1P): WRWR-483250483250 -15M 15 M2 -S- XX MADE IN TAIWAN SUB P/O NO.(6K): (WR (WRWR-483250483250- 15M 15 M2 -XX) XX) 4500059424 WLXXXXXXXX 12345A 12345A6789 TDK SPEC. C/NO:1 WAREHOUSE NW 3.6 ( CT ) GW 4.0 TDK TAIWAN CORPORATION out-going label (outside) YANGMEI, TAIWAN 9 TTXDF10105 TTXDF10105
WR-483250-15M2-G 价格&库存
很抱歉,暂时无法提供与“WR-483250-15M2-G”相匹配的价格&库存,您可以联系我们找货
