WR222230-26M8-G
WR222230-26M8-G
    TDK(东电化)
    无线充电线圈 27uH
WR222230-26M8-G 数据手册
W i r e l e s s P o w e r Tr a n s f e r November 2018 Wireless Power Transfer Small Rx (Receiving) Coil unit WR222230-26M8-G (2/3) Wireless Power Transfer Product compatible with RoHS directive Halogen-free Wireless Power Transfer Small Rx (Receiving) Coil unit Overview of WR222230-26M8-G FEATURES Receiving coils for Wireless Power Transfer. Flexible sheet type is used. These coils are designed for Max 2w output Custom design is available based on each design requirements. Halogen-free. SHAPE & DIMENSIONS ø22.0typ. Solder coat 5.0min. 0.83typ. (0.87max.) 29.0typ. Dimensions in mm ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLES L x W dimensions Thickness (mm) ø22.0 (mm)max. 0.87 Inductance [100kHz, 1Vrms] (µH) 27.0 DC resistance [25°C] ()max. 1.1 Part No. WR222230-26M8-G IC REFERENCE INFORMATION IC Texas Instruments Manufacturer material name bq51003 Web http://www.ti.com/lit/ug/tidu576a/tidu576a.pdf RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20181127 / wlc_rx_wr222230-26m8-g_en.fm (3/3) Wireless Power Transfer Reminders Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Fully caution, if metal piece contacted with top of coil surface then it could be danger of generated heat. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20181127 / wlc_rx_wr222230-26m8-g_en.fm
WR222230-26M8-G 价格&库存
很抱歉,暂时无法提供与“WR222230-26M8-G”相匹配的价格&库存,您可以联系我们找货
WR222230-26M8-G
  • 1+28.747411+3.73580
WR222230-26M8-G
    • 1+20.08800
    • 10+19.62360
    • 30+19.32120
    库存:5
