W i r e l e s s P o w e r Tr a n s f e r
November 2018
Wireless Power Transfer
Rx (receiving) coil units
WR483265-15F5-G
(2/3)
Product compatible with RoHS directive
Halogen-free
Overview of WR483265-15F5-G
FEATURES
Receiving coils for Wireless Power Transfer.
Pre cracked ferrite is available for durable construction.
Variety of thickness : from 0.50mm to 1.12mm.
Flexible sheet type is available.
Custom design is available based on each design requirements.
APPLICATION
Smartphones, cellular phones, handheld mobile terminals, and DSCs
SHAPE & DIMENSIONS
32.2typ.(32.5max.)
13.76typ.
4.5±1.0
48.2typ.(48.5max.)
Solder coat
3.0typ.
1.25max.
48.0typ.
Dimensions in mm
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLES
L x W dimensions Thickness
Efficiency
(mm)
48.2x38.2
(%)ref.
73
(mm)max.
1.25
Inductance
[100kHz, 1Vrms]
(µH)
13.3
DC resistance
[25°C]
()max.
0.20
Part No.
WR483265-15F5-G
Contact us for more information.
IC REFERENCE INFORMATION
IC
Please contact us.
Manufacturer material name
Web
RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html
Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm.
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
20181127 / wlc_rx_wr483265-15f5-g_en.fm
(3/3)
Reminders
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Fully caution, if metal piece contacted with top of coil surface then it could be danger of generated heat.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
很抱歉,暂时无法提供与“WR483265-15F5-G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+34.04039
- 10+21.75778
- 50+17.63433
- 100+16.49380
- 384+16.40607
- 768+14.56367
- 1536+13.59861
