WT-505060-10K2-A11-G
    TDK(东电化)
    无线充电线圈 6.3uH ±10%
WT-505060-10K2-A11-G 数据手册
PRODUCT SPECIFICATION SPEC. No: Attn: DATE: Dec.17.2012 CUSTOMER PRODUCT NAME: TDK PRODUCT NAME: WT-505060-10K2-A11-G APPROVED BY: CUSTOMER COMMENT: REMARK: Please sign back specification after customer conformation until 2weeks. If customer can't sign back specification, customer should be approved TDK specification. TDK-EPC Corporation Head Office Address: 1-13-1, Nihonbashi, Chuo-ku, Tokyo 103-0027 , Japan ENGINEERING SALES MANAGER Sales Office Sales Tel. APPROVED SALES PRODUCT CHECKED ISSUED REVISED HISTORY CUSTOMER PRODUCT NAME: TDK PRODUCT NAME: NO. REV. WT-505060-10K2-A11-G REVISED CONTENT REVISED REASON DATE To establish specification 1 0 2012.12.17 1/6 PRODUCT SPECIFICATION TDK PRODUCT NAME: SPEC. NO. CUSTOMER PRODUCT NAME: WT-505060-10K2-A11-G (1) Apperance & Dimensions (Unit: mm) Weight: 11.4 g (Typ.) Lead wire pitch position TOP VIEW SIDE VIEW BOTTOM VIEW [ Remarks] 1. Lead wire pitch is end of wire position, not ouput terminal. 2. Marking Content: a. T: Manufacturing Centers b: Lot No.: □□ ○○ △△ (1) (2) (3) (1) Year: A.D. end number in double (2) Month: Jan.(1), Feb.(02)…Dec.(12) (3) Day: 01,02,03,…31. 2/6 PRODUCT SPECIFICATION TDK PRODUCT NAME: SPEC. NO. CUSTOMER PRODUCT NAME: WT-505060-10K2-A11-G (2) Air coil specification Wire Diameter: φ0.08mm x 105 ( Type2 Wire) Coil Turns: 10TS ,1 layer (3) Electrical Characteristics No. Parameter Specification 1 Inductance 6.3 µH ±10% HP 4284A DIGITAL LCR METER or EQUIVALENT (@100kHz 1.0 Vrms) 2 Q Value 70 (Min.) HP 4284A DIGITAL LCR METER or EQUIVALENT (@100kHz 1.0 Vrms) 3 DC Resistance 0.06 Ω (Max.) (At 25℃) CHEN HWA 502A OHM METER or EQUIVALENT (4) Temperature Characteristics No. Parameter Specification 1 Operating Temperature -30~70℃ 2 Storage Temperature -40~85℃ (5) Application 1. The product fit in with RoHS rule. 2. The product fit in with Halogen-Free. 3. Reflow and dip-flow soldering can not used for this product. Test Instrument 3/6 PRODUCT SPECIFICATION TDK PRODUCT NAME: SPEC. NO. CUSTOMER PRODUCT NAME: WT-505060-10K2-A11-G (6) Reliability Conditions No. Parameter Conditions 1 Low Temperature (Storage) (1) Temperature:-40±2℃ (2) Time:240Hrs 2 High Temperature (Storage) (1) Temperature:+85±2℃ (2) Time:240Hrs 3 Thermal Shock (1) Temperature : - 40±5℃ / 30min ~ + 85±5℃ / 30min (2) Ambient Time : 5min (3) Times : 100cycles 4 Vibration Unpacked: (1)frequency:10~500Hz sweep 1 octave wave / 1 min (2)Amplitude:1.5mm (p-p) or 10G (3)Direction:X.Y.Z. direction (4)Time:X.Y.Z for 2 hours each. 5 (1) Temperature : +60±2℃ Temperature / Humidity (Storage) (2) Humidity: 90% RH. (3) Time: 240Hrs 6 Temperature / Humidity (OP) (1) Temperature : +60±2℃ (2) Humidity: 90% RH. (3) Time: 240Hrs (4) Current: DC 1.0A (5) Frequency: 100kHz Package Drop (1) Drop the sample package in a carton box. (2) Height : 100 cm (3) Direction :1corner,3 edges, 6 faces (4) Drop time : 16 times ESD(HBM) (1) Test Voltage: 1000V (2) Ambient: 25±5℃ (3) Time: Negative / Positive each 1 time (4) Resistance: 1500Ω (5) Capcitance: 100pF ESD(MM) (1) Test Voltage: 100V (2) Ambient: 25±5℃ (3) Time: Negative / Positive each 1 time (4) Capcitance: 200pF 7 8 9 4/6 PRODUCT SPECIFICATION TDK PRODUCT NAME: SPEC. NO. CUSTOMER PRODUCT NAME: WT-505060-10K2-A11-G (7) Construction (4) (3) (1) (2) (1) (5) (6) (8) Material List No. Material Name 1 PET Tape 2 Ferrite Sheet 3 Adhesive Tape 4 Air Coil 5 Glue 6 Ink 5/6 PRODUCT SPECIFICATION TDK PRODUCT NAME: SPEC. NO. CUSTOMER PRODUCT NAME: WT-505060-10K2-A11-G (9) Packing 1. To stack the the Trays onto 4 Layers: - PET tray dimension: 326*329*11.0mm (REF.) - 12 Pcs / per PET tray TOP Tray is empty 4-Layers Total : 12x3=36pcs Total : 4x3=12pcs 2. To put 2 Trays of products into the small Carton and affixing the out-going label on the outside . - Small carton dimension: 331*337*33mm (REF.) - 4 PET Trays / per small carton ( PET tray of the top side is empty in the small carton) Out-going Label Foxconn Customer CUST PROD ID( ID(P): 123456789. 123456789. ROHS QTY(Q): 72 (6P ):TTXDF ):TTXDF12345 TTXDF12345TWN 12345TWN273711000 TWN273711000 TDK ITEM(1P): WT-505060-10K2-A11-G WR-483250-15M2-F LOT NO(1T): WL12K34567+M0001 2011/11/22 VDR(V):TDK DATE CODE(T): 0001 001/009 12325A0435 (S) MADE IN TAIWAN (ITEM:WR-483250-15M2-F) WT-505060-10K2-A11-G) 1411 (1M)TTXDF12345 Out-going Label TDK TAIWAN CORPORATION 6/6 PRODUCT SPECIFICATION TDK PRODUCT NAME: SPEC. NO. CUSTOMER PRODUCT NAME: WT-505060-10K2-A11-G 3. To put 3 small corton into the Carton . - Outer carton dimension: 347*340*124mm (REF.) - 3 small cartons / per outer carton - Total quantity : 108 Pcs 3 small cartons Outer carton 4. Packing. -To pack the carton by scoth tape and affix out-going label (outside) on it outside. -The Inspection data in the box , there would be a signet mark on it outside. scoth tape INSPECTION DATA ENCLOSED 檢 驗 紀 錄 表在 內 signet mark of Inspection data (3S) TTW+WL11K0600200101400000360  CUSTOMER: CUSTOMER: Customer Foxconn  CUST. CUST. PART NO( NO( P):  12A 12A34567- 34567-89A 89A BOX COUNT (6S) C/NO:1 001/009 ROHS TDK ITEM CODE(6P): TTXDF12345 TTXDF12345TWN 12345TWN       SHIPPING MARK P/O NO.(K): LOT NO.(1T): TTTT- TTTT-S 123456789 WL12345678 DATE: QTY(Q): Foxconn Customer Location Nov.22.2011 288 TDK ITEM (1P): WTWR-483250-15M2-F WT - 505060505060-10K210K2-A11A11-G MADE IN TAIWAN SUB P/O NO.(6K): (WR-483250-15M2-F) (WT(WT-505060505060-10K210K2-A11A11-G) 4500059424 WL12 WL12K 12K34567 12345A 12345 A6789 TDK SPEC. C/NO:1 WAREHOUSE NW 3.6 ( CT ) GW 4.0 TDK TAIWAN CORPORATION out-going label (outside) YANGMEI, TAIWAN 9 TTXDF10105 TTXDF10105
WT-505060-10K2-A11-G 价格&库存
很抱歉,暂时无法提供与“WT-505060-10K2-A11-G”相匹配的价格&库存,您可以联系我们找货
