WT-505060-20K2-A10-G 数据手册
PRODUCT SPECIFICATION
SPEC. No:
Attn:
DATE: Dec.17.2012
CUSTOMER PRODUCT NAME:
TDK PRODUCT NAME:
APPROVED BY:
CUSTOMER COMMENT:
REMARK:
Please sign back specification after customer conformation until 2weeks.
If customer can't sign back specification, customer should be approved TDK specification.
TDK-EPC Corporation
Head Office Address:
1-13-1, Nihonbashi, Chuo-ku, Tokyo
103-0027 , Japan
ENGINEERING
SALES
MANAGER
Sales Office
Sales Tel.
APPROVED
SALES
PRODUCT
CHECKED
ISSUED
REVISED HISTORY
TDK PRODUCT NAME:
NO. REV.
REVISED CONTENT
REVISED REASON
DATE
To establish specification
1
1/6
TDK PRODUCT NAME:
SPEC. NO.
(1) Apperance & Dimensions (Unit: mm)
Weight: 16.5 g (Typ.)
Lead wire pitch
position
TOP VIEW
SIDE VIEW
BOTTOM VIEW
[ Remarks]
1. Lead wire pitch is end of wire position, not ouput terminal.
2. Marking Content:
a. T: Manufacturing Centers
b: Lot No.: □□ ○○ △△
(1)
(2)
(3)
(1) Year: A.D. end number in double
(2) Month: Jan.(1), Feb.(02)…Dec.(12)
(3) Day: 01,02,03,…31.
2/6
TDK PRODUCT NAME:
SPEC. NO.
(2) Air coil specification
Wire Diameter: φ0.08mm x 105 ( Type2 Wire)
Coil Turns: 20TS ( 10Ts / 1 layer, Total 2 layers)
(3) Electrical Characteristics
No.
Parameter
Specification
1
Inductance
24 µH ±10%
HP 4284A DIGITAL LCR METER
or EQUIVALENT
(@100kHz 1.0 Vrms)
2
Q Value
80 (Min.)
or EQUIVALENT
(@100kHz 1.0 Vrms)
3
DC
Resistance
0.1 Ω (Max.)
(At 25℃)
CHEN HWA 502A OHM METER
or EQUIVALENT
(4) Temperature Characteristics
No.
Parameter
Specification
1
Operating Temperature
-30~70℃
2
Storage Temperature
-40~85℃
(5) Application
1. The product fit in with RoHS rule.
2. The product fit in with Halogen-Free.
3. Reflow and dip-flow soldering can not used for this product.
Test Instrument
3/6
TDK PRODUCT NAME:
SPEC. NO.
(6) Reliability Conditions
No. Parameter
Conditions
1
Low Temperature
(Storage)
(1) Temperature:-40±2℃
(2) Time:240Hrs
2
High Temperature
(Storage)
(1) Temperature:+85±2℃
(2) Time:240Hrs
3
Thermal Shock
(1) Temperature : - 40±5℃ / 30min ~ + 85±5℃ / 30min
(2) Ambient Time : 5min
(3) Times : 100cycles
4
Vibration
Unpacked:
(1)frequency:10~500Hz sweep
1 octave wave / 1 min
(2)Amplitude:1.5mm (p-p) or 10G
(3)Direction:X.Y.Z. direction
(4)Time:X.Y.Z for 2 hours each.
5
(1) Temperature : +60±2℃
Temperature / Humidity (Storage) (2) Humidity: 90% RH.
(3) Time: 240Hrs
6
Temperature / Humidity (OP)
(3) Time: 240Hrs
(4) Current: DC 1.0A
(5) Frequency: 100kHz
Package Drop
(1) Drop the sample package in a carton box.
(2) Height : 100 cm
(3) Direction :1corner,3 edges, 6 faces
(4) Drop time : 16 times
ESD(HBM)
(1) Test Voltage: 1000V
(2) Ambient: 25±5℃
(3) Time: Negative / Positive each 1 time
(4) Resistance: 1500Ω
(5) Capcitance: 100pF
ESD(MM)
(1) Test Voltage: 100V
(2) Ambient: 25±5℃
(4) Capcitance: 200pF
7
8
9
4/6
TDK PRODUCT NAME:
SPEC. NO.
(7) Construction
(4)
(1)
(3)
(2)
(1)
(5)
(6)
(8) Material List
No. Material Name
1
PET Tape
2
Ferrite Sheet
3
Adhesive Tape
4
Air Coil
5
Glue
6
Ink
5/6
TDK PRODUCT NAME:
SPEC. NO.
(9) Packing
1. To stack the the Trays onto 4 Layers:
- PET tray dimension: 326*329*11.0mm (REF.)
- 12 Pcs / per PET tray
TOP Tray is empty
4-Layers
Total : 12x3=36pcs
Total : 4x3=12pcs
2. To put 2 Trays of products into the small Carton and affixing the out-going label on the outside .
- Small carton dimension: 331*337*33mm (REF.)
- 4 PET Trays / per small carton ( PET tray of the top side is empty in the small carton)
Out-going Label
Foxconn
Customer
CUST PROD ID(
ID(P): 123456789.
123456789.
ROHS
QTY(Q): 72
(6P ):TTXDF
):TTXDF12345
TTXDF12345TWN
12345TWN273711000
TWN273711000
TDK ITEM(1P): WT-505060-20K2-A10-G
WR-483250-15M2-F
LOT NO(1T): WL12K34567+M0001
2011/11/22
VDR(V):TDK
DATE CODE(T):
0001
001/009
12325A0435
(S)
MADE IN TAIWAN
(ITEM:WR-483250-15M2-F)
WT-505060-20K2-A10-G)
1411
(1M)TTXDF12345
Out-going Label
TDK TAIWAN CORPORATION
6/6
TDK PRODUCT NAME:
SPEC. NO.
3. To put 3 small corton into the Carton .
- Outer carton dimension: 347*340*124mm (REF.)
- 3 small cartons / per outer carton
- Total quantity : 108 Pcs
3 small cartons
Outer carton
4. Packing.
-To pack the carton by scoth tape and affix out-going label (outside) on it outside.
-The Inspection data in the box , there would be a signet mark on it outside.
scoth tape
INSPECTION DATA
ENCLOSED
檢 驗 紀 錄 表在 內
signet mark of Inspection data
(3S) TTW+WL11K0600200101400000360
CUSTOMER:
CUSTOMER:
Customer
Foxconn
CUST.
CUST. PART NO(
NO( P): 12A
12A34567-
34567-89A
89A
BOX COUNT
(6S) C/NO:1
001/009
ROHS
TDK ITEM CODE(6P):
TTXDF12345
TTXDF12345TWN
12345TWN
SHIPPING MARK
P/O NO.(K):
LOT NO.(1T):
TTTT-
TTTT-S 123456789
WL12345678
DATE:
QTY(Q):
Foxconn
Customer
Location
Nov.22.2011
288
TDK ITEM (1P): WTWR-483250-15M2-F
WT
- 505060505060-20K220K2-A10A10-G
MADE IN TAIWAN
SUB P/O NO.(6K):
(WR-483250-15M2-F)
(WT(WT-505060505060-20K220K2-A10A10-G)
4500059424
WL12
WL12K
12K34567
12345A
12345 A6789
TDK SPEC.
C/NO:1
WAREHOUSE
NW
3.6
( CT )
GW
4.0
YANGMEI, TAIWAN
9
TTXDF10105
TTXDF10105
WT-505060-20K2-A10-G 价格&库存
很抱歉,暂时无法提供与“WT-505060-20K2-A10-G”相匹配的价格&库存,您可以联系我们找货
