WTM905525-12F2-12V-G
    TDK(东电化)
WTM905525-12F2-12V-G 数据手册
W i r e l e s s P o w e r Tr a n s f e r May 2019 Wireless Power Transfer Tx Coil Modules (WPC Compliant) WTM905525-12F2-12V-G Wireless Power Transfer Wireless Power Transfer Tx Coil Modules (WPC Compliant) RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free WTM905525-12F2-12V-G FEATURES Turnkey solution for wireless power transfer, including transmitter coil and circuit 12V input wireless power consortium (WPC1.2.2) type MP-A2 transmitter system Fully WPC compliant, including foreign object detection (FOD) method APPLICATIONS Information and communication products Industrial, medical and other products SHAPE & DIMENSIONS Top view Side view Bottom view 4.34max. 87.00±2.0 52.00±1.0 52.00±1.0 5.00typ. Dimensions in mm AIR COIL SPECIFICATIONS Number of Coils 1 Wire Diameters ø0.08mm x 105 strands Coil Turns 12 / layer, total 1 layer Description of icons: See the following for more details. https://product.tdk.com/info/en/environment/icon.html • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190515 / wlc_tx_wtm905525-12f2-12v-g_en.fm Wireless Power Transfer WTM905525-12F2-12V-G MAXIMUM RATINGS Operating Temperature / Humidity –30 to +70°C / 10 to 95% R.H. Storage Temperature / Humidity –40 to +85°C / 10 to 95% R.H. ELECTRICAL CHARACTERISTICS Tx Module Input Voltage (V) 12 WPC Compliant Yes Transfer Power (W) 15 Efficiency (%) typ. 75 Test Environment : Test Instrument : Chroma 8000 system or EQUIVALENT Ambient Temperature : 20 to 30 °C Relative Humidity : 25 to 75 %R.H. Rx module : WRM483265-10F5-12V-G Tx & Rx coil distance : 3.4mm IC INFORMATIONS IC P9242-R Manufacturer IDT (Integrated Device Technology) * Please contact us for more detail. PACKAGING : BOX TYPE Dimensions (mm) Tray Small carton Outer carton 365x275x10 388x281.5x40 404x298x108 Quantity (pcs) Qty per tray Qty per small carton Qty per outer carton 10 30 60 OTHERS Weight (g) typ. 50 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190515 / wlc_tx_wtm905525-12f2-12v-g_en.fm Wireless Power Transfer WTM905525-12F2-12V-G BLOCK DIAGRAMS EEPROM Control logic SCL (External control) OSC Half Bridge In1 Transmitter coil SDA ISNS Half Bridge 5V DC LDO5/18/33 PWM generator 12V Adapter In2 GND PIN LAYOUTS Pin Configuration (1) Type C connector input (CN1) • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190515 / wlc_tx_wtm905525-12f2-12v-g_en.fm Wireless Power Transfer Reminders Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Fully caution, if metal piece contacted with top of coil surface then it could be danger of generated heat. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190515 / wlc_tx_wtm905525-12f2-12v-g_en.fm
WTM905525-12F2-12V-G 价格&库存
很抱歉,暂时无法提供与“WTM905525-12F2-12V-G”相匹配的价格&库存,您可以联系我们找货
