ZCAT12VN2-BK
ZCAT12VN2-BK
    TDK(东电化)
    FILTER_D31.2X34.6MM
    ZCAT12VN2-BK
ZCAT12VN2-BK 数据手册
Clamp Filters (Ferrite Core with Case) For automobile ECU ZCAT series Type: ZCAT-V-BK Issue date: September 2012 • All specifications are subject to change without notice. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. (1/2) Clamp Filters For Automobile ECU Conformity to RoHS Directive ZCAT Series ZCAT-V-BK FEATURES • Can easily be attached without cutting the cable. • Possesses better mechanical strength and operational temperature range (–40 to + 125°C) than existing products. • The plastic case has a self-sustaining mechanism that prevents slipping on the cable after being clamped. • Possesses excellent high-frequency noise absorption effect. • Works against common mode noise, allowing for noise suppression without affecting signal quality. • Effective for EMS (Electromagnetic Susceptibility), immunity against surges/noise. APPLICATIONS Best for providing noise suppression of in-vehicle ECUs PRODUCT IDENTIFICATION ZCAT (1) 12 (2) V (3) (N2) – BK (4) (5) (1) Series name (2) Max external diameter of the cable to which the product is applied (mm) (3) Usage mark In-vehicle: V=Vehicle (4) Shape code (5) Outer color code BK: Only Black PACKAGING STYLE AND QUANTITIES Type ZCAT08V-BK ZCAT12V-BK ZCAT12VN2-BK Quantity 350 pieces/box 120 pieces/box 150 pieces/box SPECIFICATIONS Operating temperature range Temperature range for engagement work –40 to +125°C 0 to +50°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 002-01 / 20120913 / e9a15_zcat_v (2/2) SHAPES AND DIMENSIONS V TYPE VN2 TYPE A INTERNAL CONSTRUCTION C A C B E B Ferrite core D D Plastic case Dimensions in mm Part No. A B C D E ZCAT08V-BK ZCAT12V-BK ZCAT12VN2-BK 32.5±1.5 34.6±1.5 34.6±1.5 8.0±1.5 12.0±1.5 12.5±1.5 18.4±1.5 27.5±1.5 31.2±1.5 18.9±1.5 27.0±1.5 27.2±1.5 — — (6.0) Applicable cable outer dia. max. 8.0 12.0 12.0 Weight (g) 17.0 44.4 45.5 ELECTRICAL CHARACTERISTICS Part No. Impedance(:)min. [100MHz] ZCAT08V-BK ZCAT12V-BK ZCAT12VN2-BK 120 140 140 • Test conditions Impedance meter or equivalent/ø1mm solder plated copper wire passes through(1ts)/Unloaded TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS ZCAT08V ZCAT12V 1000 10 1 10 100 Frequency(MHz) Impedance(Ω) 100 1 ZCAT12VN 1000 Impedance(Ω) Impedance(Ω) 1000 100 1000 10 1 1 10 100 Frequency(MHz) 1000 100 10 1 1 10 100 Frequency(MHz) 1000 • All specifications are subject to change without notice. 002-01 / 20120913 / e9a15_zcat_v
