ZCAT2017-0930B-M
ZCAT2017-0930B-M
    TDK(东电化)
    FILTER_D20X21MM
    ZCAT2017-0930B-M
ZCAT2017-0930B-M 数据手册
9A15_ZCAT (1/4) EMC Components ZCAT Series Clamp Filters For Cable FEATURES • Unique plastic case ensures simple, convenient installation and includes a self-holding mechanism to prevent slippage on cables. • Ferrite core provides excellent absorption of high-frequency EMC. • Highly effective as countermeasure against common mode EMC without adverse effect on signal quality. • Large core size prevents saturation during large signal surges. ,,, ,,,,,,, ,,,,, ,,,,, ,,,,, ,,,,, ,,,,, ,,,,, ,,,,, , , ,,,,,,,,,,,,, ,,,,,,,,, ,,,,,,,,, ,,,,,,,,, ,,,,,,,,, ,,,,, ,,,,,,,,,,,,, ,,,,,,,,, , ,, ,,,,,,, ,,,,, ,,,,, ,,,,, ,,,,, ,,, ,,,,,,, ,,,,, ,,,,, INTERNAL CONSTRUCTION Ferrite core Plastic case ZCAT-C TYPE APPLICATIONS Personal computers, word processors, monitors, hard disk drives, digital telephones, audio devices, electronic musical instruments, video games, copiers and facsimiles. PRODUCT IDENTIFICATION ZCAT 24 (1) (2) 36 – 13 30 A – M – BK (3) (4) (5) (6) (7) (8) (1) Series name (2) Outer dimensions(mm) (3) Length(mm) (4) Inner dimensions(mm) (5) Material code (6) Fixed type code A: Cable fixed Hold the cable to secure it with the main body AP:Cable fixed (with lock mechanism) B: Clamp fixed C: Cable coil securing type (Coil the cable one time within the case to fix it/with lock mechanism.) D: Flat cable type DT: Flat cable type (Hold with adhesive pad.) Non code: Band fixed (Secure the cable and main body with the nylon belt.) (7) TDK internal code M:Standard type Non code: High impedance type (8) Outer color code BK: Black Non code: Gray PACKAGING STYLE AND QUANTITIES Part No. ZCAT3035 ZCAT2017-B ZCAT2235 ZCAT2436 ZCAT2032 ZCAT2035 ZCAT2132 ZCAT2749 ZCAT1730 ZCAT2017 ZCAT1325 ZCAT1518 ZCAT1525 ZCAT4625-D ZCAT6819-D Quantity 140 pieces/box 350 pieces/box 350 pieces/box 350 pieces/box 400 pieces/box 400 pieces/box 400 pieces/box 400 pieces/box 500 pieces/box 800 pieces/box 900 pieces/box 900 pieces/box 900 pieces/box 240 pieces/box 160 pieces/box Specifications which provide more details for the proper and safe use of the described product are available upon request. All specifications are subject to change without notice. 9A15_ZCAT (2/4) EMC Components ZCAT Series Clamp Filters For Cable ZCAT-A, ZCAT-AP TYPE D A E C B øC A B E D B øD A ZCAT-B TYPE ZCAT-C TYPE øC SHAPES AND DIMENSIONS ZCAT TYPE ZCAT-D TYPE A D B C B A C D Applicable cable thickness: 1.3mm max. Dimensions in mm Part No. A B øC øD E Applicable cable outer dia. 22±1 18±1 7±1 15±1 – 7max. ZCAT1518-0730-M(-BK)∗1 22±1 18±1 7±1 15±1 – 7max. ZCAT1518-0730(BK)∗2 ZCAT2017-0930-M(-BK) 21±1 17±1 9±1 20±1 – 9max. 36±1 32±1 9±1 19.5±1 – 9max. ZCAT2032-0930-M(-BK)∗1 36±1 32±1 9±1 19.5±1 – 9max. ZCAT2032-0930(-BK)∗2 36±1 32±1 11±1 20.5±1 – 11max. ZCAT2132-1130-M(-BK)∗1 ZCAT2132-1130(-BK)∗2 36±1 32±1 11±1 20.5±1 – 11max. 39±1 34±1 13±1 30±1 – 13max. ZCAT3035-1330-M(-BK)∗1 39±1 34±1 13±1 30±1 – 13max. ZCAT3035-1330(-BK)∗2 ZCAT1525-0430AP-M(-BK) 25±1 20±1 4±1 15±1 11.5±1 2.5 to 4(USB) 25±1 20±1 5±1 12.8±1 11.2±1 3 to 5(USB) ZCAT1325-0530A-M(-BK)∗1 ZCAT1325-0530A(-BK) 25±1 20±1 5±1 12.8±1 11.2±1 3 to 5(USB) ZCAT1730-0730A-M(-BK) 30±1 23±1 7±1 16.5±1 15±1 4 to 7(USB/IEEE1394) 35±1 28±1 9±1 19.5±1 17.4±1 6 to 9 ZCAT2035-0930A-M(-BK)∗1 ZCAT2035-0930A(-BK) 35±1 28±1 9±1 19.5±1 17.4±1 6 to 9 ZCAT2235-1030A-M(-BK) 35±1 28±1 10±1 21.5±1 20±1 8 to 10 ZCAT2436-1330A-M(-BK) 36±1 29±1 13±1 23.5±1 22±1 10 to 13 ZCAT2017-0930B-M(-BK) 21±1 17±1 9±1 20±1 28.5±1 9max. ZCAT2749-0430C-M(-BK) 49±1 27±1 4.5±1 19.5±1 – 4.5max. ZCAT4625-3430D(-BK) 45.5±1 24.5±1 34±1 12±1 – For 26 wires flat cable 45.5±1 24.5±1 34±1 13±1 – For 26 wires flat cable ZCAT4625-3430DT(-BK)∗3 ZCAT6819-5230D(-BK) 67.5±1 18.5±1 52±1 16±1 – For 40 wires flat cable 67.5±1 18.5±1 52±1 17±1 – For 40 wires flat cable ZCAT6819-5230DT(-BK)∗3 ∗1 Set M marking on product. ∗2 These products are delivered with fixed band. ∗3 ZCAT-DT type: Adapted for flat cables and hold with adhesive pad. • ZCAT-B type: Clamp fixed type installation hole diameter ø4.8 to 4.9mm, thickness of board 0.5 to 2mm. • ZCAT-AP, ZCAT-C type: Once closed, the case will not be easily opened manually. Weight(g) 6 6 11 22 22 22 22 63 63 7 7 7 12 22 22 27 29 12 26 32 32 58 58 90mm STRUCTURE OF THE MOUNTING BAND Material: 66-nylon (natural color) 2.3mm Specifications which provide more details for the proper and safe use of the described product are available upon request. All specifications are subject to change without notice. Impedance freq. characteristics Fig. 1 2 3 4 5 6 7 8 9 6 6 7 6 4 5 4 10 3 11 12 12 12 12 9A15_ZCAT (3/4) EMC Components ZCAT Series Clamp Filters For Cable ELECTRICAL CHARACTERISTICS TYPICAL EMC SUPPRESSION EFFECTS RADIATION LEVEL vs. FREQUENCY CHARACTERISTICS 80 Radiation field intensity (dBµV/m) Impedance (Ω)min.[50 to 500MHz] 35 35 80 50 100 50 50 50 80 80 50 35 80 35 35 Without EMC filter 60 40 20 0 • Test conditions: R-X meter at unloaded condition, ø1mm solder plated copper wire passes through. Radiation field intensity (dBµV/m) Part No. ZCAT1518-0730-M ZCAT2017-0930-M ZCAT2032-0930-M ZCAT2132-1130-M ZCAT3035-1330-M ZCAT1525-0430AP-M ZCAT1325-0530A-M ZCAT1730-0730A-M ZCAT2035-0930A-M ZCAT2235-1030A-M ZCAT2436-1330A-M ZCAT2017-0930B-M ZCAT2749-0430C-M ZCAT4625-3430D(T) ZCAT6819-5230D(T) 30 100 Frequency (MHz) 80 With EMC filter ZCAT2035-0930A-M 60 40 20 0 30 100 Frequency (MHz) TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS ZCAT1518-0730 100 Frequency(MHz) 10 10 1000 Fig.1 Impedance(Ω) Impedance(Ω) Fig.5 1000 100 Frequency(MHz) Fig.6 1000 1000 ZCAT3035-1330-M 1000 100 10 10 100 Frequency(MHz) Fig.4 1000 100 10 10 10 10 1000 ZCAT2132-1130 ZCAT1325-0530A 1000 100 100 Frequency(MHz) 100 Fig.3 ZCAT2132-1130-M ZCAT1325-0530A-M ZCAT1525-0430AP-M ZCAT1730-0730A-M 1000 100 Frequency(MHz) 10 10 1000 Fig.2 ZCAT2032-0930 ZCAT2035-0930A 10 10 100 Frequency(MHz) 100 Impedance(Ω) 10 10 100 1000 Impedance(Ω) 100 ZCAT2032-0930-M ZCAT2035-0930A-M ZCAT2235-1030A-M 1000 Impedance(Ω) 1000 Impedance(Ω) Impedance(Ω) 1000 ZCAT2017-0930-M ZCAT2017-0930B-M 300 Impedance(Ω) ZCAT1518-0730-M 300 100 Frequency(MHz) 1000 Fig.7 Specifications which provide more details for the proper and safe use of the described product are available upon request. All specifications are subject to change without notice. 100 10 10 100 Frequency(MHz) Fig.8 1000 9A15_ZCAT (4/4) EMC Components ZCAT Series Clamp Filters For Cable TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS ZCAT2436-1330A-M 100 10 10 100 Frequency(MHz) Fig.9 1000 100 10 10 ZCAT4625-3430D ZCAT6819-5230D 1000 Impedance(Ω) 1000 Impedance(Ω) Impedance(Ω) 1000 ZCAT2749-0430C-M(2TS) 100 Frequency(MHz) Fig.10 1000 1000 Impedance(Ω) ZCAT3035-1330 100 10 10 100 Frequency(MHz) 100 1000 Fig.11 10 10 100 Frequency(MHz) 1000 Fig.12 9A15_ZCAT 001030 Specifications which provide more details for the proper and safe use of the described product are available upon request. All specifications are subject to change without notice.
ZCAT2017-0930B-M 价格&库存
很抱歉,暂时无法提供与“ZCAT2017-0930B-M”相匹配的价格&库存,您可以联系我们找货
