E M C
C o m p o n e n t s
Clamp filters
For cable
RoHS
REACH
SVHC-Free
Cl
Br
Pb
Halogen
Free
Lead
Free
ZCAT series
FEATURES
Using TDK's unique structure where the ferrite core is mounted and integrated in a plastic case, it is possible to attach them to interface
cables and power cables with one touch without having to cut the cables.
Have excellent absorption of high-frequency noise using the high-frequency absorption characteristics of the ferrite core.
Effective for common mode noise, so can be implemented as a noise countermeasure without influencing signal quality.
Series are according to the outer diameter of the cable in order to be compatible with various cable sizes.
APPLICATION
PCs, monitors, HDDs, digital telephones, audio equipment, electronic musical instruments, video games, copiers, and facsimiles
PART NUMBER CONSTRUCTION
ZCAT
2436-13
30
A
-BK
Series
name
Shape dimensions
(mm)
Product internal
code
Fixing type code
Outer color code
A
B
D
DT
Non code
Fixed cable type
(cable is affixed to the main body)
Chassis fixed type
Flat cable type
Flat cable type
(double-sided tape fixed type)
Band fixed type
(cable is affixed to the body by a cable tie)
-BK
Black
Non code Gray
PRODUCT LINEUP
ZCAT1518-0730(-BK)
ZCAT2017-0930(-BK)
ZCAT2032-0930(-BK)
ZCAT2132-1130(-BK)
ZCAT3035-1330(-BK)
ZCAT1325-0530A(-BK)
ZCAT1730-0730A(-BK)
ZCAT2035-0930A(-BK)
ZCAT2235-1030A(-BK)
ZCAT2436-1330A(-BK)
Impedance( )min.
[10 to 100MHz]
25
40
80
50
40
50
50
30
[100 to 500MHz]
50
50
100
80
150
100
80
100
100
80
[50 to 500MHz]
ZCAT2017-0930B(-BK)
ZCAT3618-2630D(-BK)
30
ZCAT4625-3430D(-BK)
35
ZCAT6819-5230D(-BK)
35
ZCAT3618-2630DT(-BK)
30
ZCAT4625-3430DT(-BK)
35
ZCAT6819-5230DT(-BK)
35
ZCAT10D(-BK)
25
70
ZCAT13D(-BK)
40
100
ZCAT20D(-BK)
60
150
Type
Part No.
ZCAT
ZCAT-A
ZCAT-B
ZCAT-D
ZCAT-DT
ZCAT**D
Background yellow: The products which are planning to stop production.
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/9)
20220609
clamp-filter_commercial_zcat_en.fm
E M C
C o m p o n e n t s
ZCAT type
CHARACTERISTICS SPECIFICATION TABLE
Impedance( )min.
Part No.
[10 to 100MHz]
[100 to 500MHz]
[50 to 500MHz]
25
50
ZCAT1518-0730(-BK)
ZCAT2017-0930(-BK)
ZCAT2032-0930(-BK)
50
100
40
80
ZCAT2132-1130(-BK)
ZCAT3035-1330(-BK)
80
150
A cable tie is included when shipped.
• Test conditions: When passing through an impedance meter (unloaded) ø1mm copper cable
Operating
temperature range
(°C)
–40 to 85
Individual weight
(g)
6
11
21
22
62
IMPEDANCE VS. FREQUENCY CHARACTERISTICS
1000
ZCAT3035-1330
ZCAT2132-1130
100
Impedance (Ω)
ZCAT2032-0930
ZCAT2017-0930
ZCAT1518-0730
10
1
1
10
100
1000
Frequency(MHz)
SHAPE & DIMENSIONS
A
D
B
C
Part No.
ZCAT1518-0730(-BK)
ZCAT2017-0930(-BK)
ZCAT2032-0930(-BK)
ZCAT2132-1130(-BK)
ZCAT3035-1330(-BK)
INTERNAL CONSTRUCTION
Dimensions (mm)
A
B
22±1
18±1
21±1
17±1
36±1
32±1
36±1
32±1
39±1
34±1
C
7±1
9±1
9±1
11±1
13±1
D
15±1
20±1
19.5±1
20.5±1
30±1
Applicable cable
outer diameter
7max.
9max.
9max.
11max.
13max.
STRUCTURE OF THE CABLE TIE
Ferrite core
2.5mm typ.
104mm typ.
Plastic case
(2/9)
20220609
E M C
C o m p o n e n t s
ZCAT-A type
Impedance( )min.
Part No.
[10 to 100MHz]
[100 to 500MHz]
[50 to 500MHz]
ZCAT1325-0530A(-BK)
50
100
ZCAT1730-0730A(-BK)
40
80
ZCAT2035-0930A(-BK)
50
100
ZCAT2235-1030A(-BK)
50
100
ZCAT2436-1330A(-BK)
30
80
Operating
temperature range
(°C)
–40 to 85
Individual weight
(g)
6
12
21
26
29
1000
ZCAT2235-1030A
100
Impedance (Ω)
ZCAT2035-0930A
ZCAT2436-1330A
ZCAT1325-0530A
ZCAT1730-0730A
10
1
1
10
100
1000
Frequency(MHz)
SHAPE & DIMENSIONS
A
E
B
C
Part No.
D
ZCAT1325-0530A(-BK)
ZCAT1730-0730A(-BK)
ZCAT2035-0930A(-BK)
ZCAT2235-1030A(-BK)
ZCAT2436-1330A(-BK)
Dimensions (mm)
A
B
C
25±1 20±1 5±1
30±1 23±1 7±1
35±1 28±1 9±1
35±1 28±1 10±1
36±1 29±1 13±1
D
12.8±1
16.5±1
19.5±1
21.5±1
23.5±1
E
11.2±1
15±1
17.4±1
20±1
22±1
Applicable cable
outer diameter
3 to 5(USB)
4 to 7(USB/IEEE1394)
6 to 9
8 to 10
10 to 13
Ferrite core
Plastic case
(3/9)
20220609
E M C
C o m p o n e n t s
ZCAT-B type
Impedance( )min.
Part No.
[10 to 100MHz]
[100 to 500MHz]
[50 to 500MHz]
ZCAT2017-0930B(-BK)
• Chassis fixed type attachment hole: ø4.8 to 4.9mm, Plate thickness: 0.5 to 2mm
Operating
temperature range
(°C)
–40 to 85
Individual weight
(g)
12
1000
Impedance (Ω)
100
10
1
1
10
100
1000
Frequency(MHz)
SHAPE & DIMENSIONS
A
E
Part No.
C
D
B
ZCAT2017-0930B(-BK)
Dimensions (mm)
A
B
C
21±1 17±1 9±1
D
20±1
E
(29)
Applicable cable
outer diameter
9max.
Ferrite core
Plastic case
(4/9)
20220609
E M C
C o m p o n e n t s
ZCAT-D type
Impedance( )min.
Part No.
[10 to 100MHz]
[100 to 500MHz]
[50 to 500MHz]
ZCAT3618-2630D(-BK)
30
ZCAT4625-3430D(-BK)
35
ZCAT6819-5230D(-BK)
35
Operating
temperature range
(°C)
Individual weight
(g)
16
34
60
–40 to 85
1000
Impedance (Ω)
100
ZCAT4625-3430D
ZCAT6819-5230D
ZCAT3618-2630D
10
1
1
10
100
1000
Frequency(MHz)
SHAPE & DIMENSIONS
A
B
Part No.
ZCAT3618-2630D(-BK)
ZCAT4625-3430D(-BK)
ZCAT6819-5230D(-BK)
D
C
Applicable cable
thickness:
1.3mm max.
Dimensions (mm)
A
B
35.5±1 17.5±1
45.5±1 24.5±1
67.5±1 18.5±1
C
26±1
34±1
52±1
D
11.5±1
12±1
16±1
Applicable cable
outer diameter
For 20 wires flat cable
For 26 wires flat cable
For 40 wires flat cable
Ferrite core
Plastic case
(5/9)
20220609
The products in this catalog will be stopped production
E M C
C o m p o n e n t s
ZCAT-DT type
Impedance( )min.
Part No.
[10 to 100MHz]
[100 to 500MHz]
[50 to 500MHz]
30
35
35
Double-sided tape fixed type (tape included when shipped).
Operating
temperature range
(°C)
Individual weight
(g)
16
34
60
–40 to 85
1000
Impedance (Ω)
100
ZCAT4625-3430DT
ZCAT6819-5230DT
ZCAT3618-2630DT
10
1
1
10
100
1000
Frequency(MHz)
SHAPE & DIMENSIONS
B
A
Part No.
D
C
Applicable cable
thickness:
1.3mm max.
Dimensions (mm)
A
B
35.5±1 17.5±1
45.5±1 24.5±1
67.5±1 18.5±1
C
26±1
34±1
52±1
D
12.5±1
13±1
17±1
Applicable cable
outer diameter
Ferrite core
Plastic case
(6/9)
20220609
E M C
C o m p o n e n t s
ZCAT**D type
Impedance( )min.
Part No.
[10 to 100MHz]
[100 to 500MHz]
[50 to 500MHz]
ZCAT10D(-BK)
25
70
ZCAT13D(-BK)
40
100
ZCAT20D(-BK)
60
150
Operating
temperature range
(°C)
–40 to 85
Individual weight
(g)
6
15
45
1000
Impedance (Ω)
100
ZCAT20D
ZCAT13D
10
ZCAT10D
1
1
10
100
1000
Frequency(MHz)
SHAPE & DIMENSIONS
C
A
D
ZCAT10D(-BK)
ZCAT13D(-BK)
ZCAT20D(-BK)
E
B
Part No.
Dimensions (mm)
A
B
C
27±1 14.5±1 10±1
34±1 20±1 13±1
35±1 30±1 20±1
D
4±1
5±1
5±1
E
7±1
8.5±1
15±1
Applicable cable
outer diameter
4max.
5max.
5max.
Ferrite core
Plastic case
(7/9)
20220609
E M C
C o m p o n e n t s
ZCAT series
OUTER BOX SIZE, PACKAGE QUANTITY
ZCAT1518-0730(-BK)
ZCAT2017-0930(-BK)
ZCAT2032-0930(-BK)
ZCAT2132-1130(-BK)
ZCAT3035-1330(-BK)
ZCAT1325-0530A(-BK)
ZCAT1730-0730A(-BK)
ZCAT2035-0930A(-BK)
ZCAT2235-1030A(-BK)
ZCAT2436-1330A(-BK)
Number of
products
(pieces/trays)
112
80
60
60
40
112
84
60
50
50
Number of
interior trays
(trays/box)
8
8
7
8
5
12
10
8
8
8
Package
quantity
(pieces/box)
896
640
420
480
200
1,344
840
480
400
400
ZCAT2017-0930B(-BK)
70
5
350
385x331x216
ZCAT3618-2630D(-BK)
80
6
480
395×250×225
ZCAT4625-3430D(-BK)
40
6
240
395×250×225
ZCAT6819-5230D(-BK)
160
395×250×225
80
6
480
395×250×225
40
6
240
395×250×225
160
395×250×225
ZCAT10D(-BK)
77
10
770
490×350×220
ZCAT13D(-BK)
50
9
450
490×350×220
ZCAT20D(-BK)
40
7
280
490×350×220
Type
Part No.
ZCAT
ZCAT-A
Outer box size
490×350×220
490×350×220
490×350×220
490×350×220
490×350×220
490×350×220
490×350×220
490×350×220
490×350×220
490×350×220
ZCAT-B
ZCAT-D
ZCAT-DT
ZCAT**D
(8/9)
20220609
E M C
C o m p o n e n t s
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is within 6 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 20 to 75% RH or
less).
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
The case may crack when it is handled below freezing point or when it experiences a fall or other mechanical shock, as it is made of
plastic; please exercise caution when handling the case.
In a case where the product is attached to a cable larger than the product's internal diameter, the ferrite core may be damaged.
Please confirm compatibility with the cable before use.
Dropping or forcible engagement may cause damage to the product.
Please handle the product with care when engaging.
Do not detach and reuse a product that has been engaged.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(9/9)
20220609
很抱歉,暂时无法提供与“ZCAT2235-1030A-BK”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2+35.650792+4.33130
- 10+26.1588910+3.17811
- 25+22.5773525+2.74298
- 50+19.9842950+2.42794
- 100+17.48490100+2.12428
- 250+12.74814250+1.54880
- 400+11.13108400+1.35234
