ZCAT2235-1030A
ZCAT2235-1030A
    TDK(东电化)
    FILTER_D21.5X35MM
    FERRITE CORE 100 OHM HINGED 10MM
ZCAT2235-1030A 数据手册
E M C C o m p o n e n t s July 2013 Clamp Filters (Ferrite Core with Case) For cable ZCAT series ZCAT ZCAT-A ZCAT-B ZCAT-D/-DT (2/13) E M C C o m p o n e n t s REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The storage period is less than 6 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH or less). The case may crack when it is handled below freezing point or when it experiences a fall or other mechanical shock, as it is made of plastic; please exercise caution when handling the case. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). In a case where the product is attached to a cable larger than the product's internal diameter, the ferrite core may be damaged. Please confirm compatibility with the cable before use. Dropping or forcible engagement may cause damage to the product. Please handle the product with care when engaging. Do not detach and reuse a product that has been engaged; this may damage the engaged portion. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 001-01 / 20130723 / e9a15_zcat.fm (3/13) E M C C o m p o n e n t s Clamp Filters (Ferrite Core with Case) Product compatible with RoHS directive Halogen-free For cable Overview of the ZCAT Series FEATURES Using TDK's unique structure where the ferrite core is mounted and integrated in a plastic case, it is possible to attach them to interface cables and power cables with one touch without having to cut the cables. Have excellent absorption of high-frequency noise using the high-frequency absorption characteristics of the ferrite core. Effective for common mode noise, so can be implemented as a noise countermeasure without influencing signal quality. Series are according to the outer diameter of the cable in order to be compatible with various cable sizes. APPLICATION PCs, word processors, monitors, HDDs, digital telephones, audio equipment, electronic musical instruments, video games, copiers, and facsimiles PART NUMBER CONSTRUCTION ZCAT 24 36 Series name Outer dimensions (mm) Length dimensions (mm) - 13 30 A BK Inner Core material code Fixing type code Outer color code dimensions (mm) A B D DT Non code BK Black Non code Gray Fixed cable type (Cable is clamped inside the main body) Chassis fixed type Flat cable type Flat cable type (Double-sided tape fixed type) Band fixed type (Cable is secured to the main body by a nylon band) OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT Temperature range Operating Storage condition after temperature engagement (°C) (°C) ZCAT3035 –40 to +85 –40 to +85 ZCAT2017-B –40 to +85 –40 to +85 ZCAT2235 –40 to +85 –40 to +85 ZCAT2436 –40 to +85 –40 to +85 ZCAT2032 –40 to +85 –40 to +85 ZCAT2035 –40 to +85 –40 to +85 ZCAT2132 –40 to +85 –40 to +85 ZCAT1730 –40 to +85 –40 to +85 ZCAT2017 –40 to +85 –40 to +85 ZCAT1325 –40 to +85 –40 to +85 ZCAT1518 –40 to +85 –40 to +85 ZCAT3618-D –40 to +85 –40 to +85 ZCAT4625-D –40 to +85 –40 to +85 ZCAT6819-D –40 to +85 –40 to +85 ZCAT10D –40 to +85 –40 to +85 ZCAT13D –40 to +85 –40 to +85 ZCAT20D –40 to +85 –40 to +85 Operating temperature range includes self-temperature rise. Type Temperature range for engagement work (°C) 0 to +50 0 to +50 0 to +50 0 to +50 0 to +50 0 to +50 0 to +50 0 to +50 0 to +50 0 to +50 0 to +50 0 to +50 0 to +50 0 to +50 0 to +50 0 to +50 0 to +50 Package quantity Individual weight (pieces/box) 200 350 400 400 420 480 480 840 640 1,344 896 480 240 160 770 450 280 (g) 64.8 11.5 26.0 29.0 22.7 21.2 21.6 11.6 11.0 6.37 6.1 15.6 32.5 58.4 5.6 14.8 46.3 RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://www.tdk.co.jp/rohs/ Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm. • All specifications are subject to change without notice. 001-01 / 20130723 / e9a15_zcat.fm (4/13) E M C C o m p o n e n t s ZCAT series ZCAT Type SHAPE & DIMENSIONS A D B C Dimensions in mm A ZCAT1518-0730(-BK) 22±1 21±1 ZCAT2017-0930(-BK) ZCAT2032-0930(-BK) 36±1 36±1 ZCAT2132-1130(-BK) 39±1 ZCAT3035-1330(-BK) A fixing band is included when shipped. B C D E 18±1 17±1 32±1 32±1 34±1 7±1 9±1 9±1 11±1 13±1 15±1 20±1 19.5±1 20.5±1 30±1 – – – – – INTERNAL CONSTRUCTION STRUCTURE OF THE FIXING BAND Ferrite core 2.4 to 2.6mm 102 to 106mm Part No. Applicable cable outer diameter 7max. 9max. 9max. 11max. 13max. Material: 66-nylon (natural color) Plastic case • All specifications are subject to change without notice. 001-01 / 20130723 / e9a15_zcat.fm (5/13) E M C C o m p o n e n t s ZCAT series ZCAT Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Impedance(: )min. [10 to 100MHz] 25 20 50 40 80 [100 to 500MHz] 50 50 100 80 150 Part No. [50 to 500MHz] — — — — — ZCAT1518-0730(-BK) ZCAT2017-0930(-BK) ZCAT2032-0930(-BK) ZCAT2132-1130(-BK) ZCAT3035-1330(-BK) • Test conditions: When passing through an impedance meter (unloaded) ø1mm copper cable IMPEDANCE VS. FREQUENCY CHARACTERISTICS ZCAT1518-0730 ZCAT2017-0930 10 10 100 Frequency (MHz) ZCAT2132-1130 10 100 Frequency (MHz) 1000 10 1 1 10 100 Frequency (MHz) 1000 1000 Impedance (Ω) Impedance (Ω) 10 100 ZCAT3035-1330 1000 100 10 1 1 100 1 1 1000 1000 Impedance (Ω) 100 1 1 ZCAT2032-0930 1000 Impedance (Ω) Impedance (Ω) 1000 10 100 Frequency (MHz) 1000 100 10 1 1 10 100 Frequency (MHz) 1000 • All specifications are subject to change without notice. 001-01 / 20130723 / e9a15_zcat.fm (6/13) E M C C o m p o n e n t s ZCAT series ZCAT-A Type SHAPE & DIMENSIONS E C D A B Dimensions in mm Part No. A B C D E ZCAT1325-0530A(-BK) ZCAT1730-0730A(-BK) ZCAT2035-0930A(-BK) ZCAT2235-1030A(-BK) ZCAT2436-1330A(-BK) 25±1 30±1 35±1 35±1 36±1 20±1 23±1 28±1 28±1 29±1 5±1 7±1 9±1 10±1 13±1 12.8±1 16.5±1 19.5±1 21.5±1 23.5±1 11.2±1 15±1 17.4±1 20±1 22±1 Applicable cable outer diameter 3 to 5(USB) 4 to 7(USB/IEEE1394) 6 to 9 8 to 10 10 to 13 INTERNAL CONSTRUCTION Ferrite core Plastic case • All specifications are subject to change without notice. 001-01 / 20130723 / e9a15_zcat.fm (7/13) E M C C o m p o n e n t s ZCAT series ZCAT-A Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Impedance(: )min. [10 to 100MHz] 50 40 50 50 30 [100 to 500MHz] 100 80 100 100 80 Part No. [50 to 500MHz] — — — — — ZCAT1325-0530A(-BK) ZCAT1730-0730A(-BK) ZCAT2035-0930A(-BK) ZCAT2235-1030A(-BK) ZCAT2436-1330A(-BK) • Test conditions: When passing through an impedance meter (unloaded) ø1mm copper cable IMPEDANCE VS. FREQUENCY CHARACTERISTICS ZCAT1325-0530A ZCAT1730-0730A 10 10 100 Frequency (MHz) ZCAT2235-1030A 10 100 Frequency (MHz) 1000 10 1 1 10 100 Frequency (MHz) 1000 1000 Impedance (Ω) Impedance (Ω) 10 100 ZCAT2436-1330A 1000 100 10 1 1 100 1 1 1000 1000 Impedance (Ω) 100 1 1 ZCAT2035-0930A 1000 Impedance (Ω) Impedance (Ω) 1000 10 100 Frequency (MHz) 1000 100 10 1 1 10 100 Frequency (MHz) 1000 • All specifications are subject to change without notice. 001-01 / 20130723 / e9a15_zcat.fm (8/13) E M C C o m p o n e n t s ZCAT series ZCAT-B Type SHAPE & DIMENSIONS A C E D B Dimensions in mm Part No. A B C D E ZCAT2017-0930B(-BK) 21±1 17±1 9±1 20±1 (29) • Chassis fixed type attachment hole: ø4.8 to 4.9mm, Plate thickness: 0.5 to 2mm Applicable cable outer diameter 9max. INTERNAL CONSTRUCTION Ferrite core Plastic case • All specifications are subject to change without notice. 001-01 / 20130723 / e9a15_zcat.fm (9/13) E M C C o m p o n e n t s ZCAT series ZCAT-B Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Impedance(: )min. [10 to 100MHz] 20 [100 to 500MHz] 50 [50 to 500MHz] — Part No. ZCAT2017-0930B(-BK) • Test conditions: When passing through an impedance meter (unloaded) ø1mm copper cable IMPEDANCE VS. FREQUENCY CHARACTERISTICS ZCAT2017-0930B Impedance (Ω) 1000 100 10 1 1 10 100 Frequency (MHz) 1000 • All specifications are subject to change without notice. 001-01 / 20130723 / e9a15_zcat.fm (10/13) E M C C o m p o n e n t s ZCAT series ZCAT-D, ZCAT-DT Type SHAPE & DIMENSIONS B A D C Applicable cable thickness: 1.3mm max. Dimensions in mm Part No. A B C ZCAT3618-2630D(-BK) 35.5±1 17.5±1 26±1 35.5±1 17.5±1 26±1 ZCAT3618-2630DT(-BK) ZCAT4625-3430D(-BK) 45.5±1 24.5±1 34±1 ZCAT4625-3430DT(-BK) 45.5±1 24.5±1 34±1 ZCAT6819-5230D(-BK) 67.5±1 18.5±1 52±1 67.5±1 18.5±1 52±1 ZCAT6819-5230DT(-BK) Double-sided tape fixed type (tape included when shipped). D E 11.5±1 12.5±1 12±1 13±1 16±1 17±1 – – – – – – Applicable cable outer diameter For 20 wires flat cable For 20 wires flat cable For 26 wires flat cable For 26 wires flat cable For 40 wires flat cable For 40 wires flat cable INTERNAL CONSTRUCTION Ferrite core Plastic case • All specifications are subject to change without notice. 001-01 / 20130723 / e9a15_zcat.fm (11/13) E M C C o m p o n e n t s ZCAT series ZCAT-D, ZCAT-DT Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Impedance(: )min. [10 to 100MHz] — — — [100 to 500MHz] — — — Part No. [50 to 500MHz] 30 35 35 ZCAT3618-2630D(T)(-BK) ZCAT4625-3430D(T)(-BK) ZCAT6819-5230D(T)(-BK) • Test conditions: When passing through an impedance meter (unloaded) ø1mm copper cable IMPEDANCE VS. FREQUENCY CHARACTERISTICS ZCAT3618-2630D ZCAT4625-3430D 10 10 100 Frequency (MHz) 1000 1000 Impedance (Ω) Impedance (Ω) Impedance (Ω) 100 1 1 ZCAT6819-5230D 1000 1000 100 10 1 1 10 100 Frequency (MHz) 1000 100 10 1 1 10 100 Frequency (MHz) 1000 • All specifications are subject to change without notice. 001-01 / 20130723 / e9a15_zcat.fm (12/13) E M C C o m p o n e n t s ZCAT series ZCAT10D, 13D, 20D Type SHAPE & DIMENSIONS C D E B A Dimensions in mm Part No. A B C D E ZCAT 10D-(BK) ZCAT 13D-(BK) ZCAT 20D-(BK) 27±1 34±1 35±1 14.5±1 20±1 30±1 10±1 13±1 20±1 4±1 5±1 5±1 7±1 8.5±1 15±1 Applicable cable outer diameter 4max. 5max. 5max. INTERNAL CONSTRUCTION Ferrite core Plastic case • All specifications are subject to change without notice. 001-01 / 20130723 / e9a15_zcat.fm (13/13) E M C C o m p o n e n t s ZCAT series ZCAT10D, 13D, 20D Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Impedance(: )min. [10 to 100MHz] 25 40 60 [100 to 500MHz] 70 100 150 [50 to 500MHz] — — — Part No. ZCAT 10D-(BK) ZCAT 13D-(BK) ZCAT 20D-(BK) • Test conditions: When passing through an impedance meter (unloaded) ø1mm copper cable IMPEDANCE VS. FREQUENCY CHARACTERISTICS ZCAT10D ZCAT13D 10 10 100 Frequency (MHz) 1000 1000 Impedance (Ω) 100 1 1 ZCAT20D 1000 Impedance (Ω) Impedance (Ω) 1000 100 10 1 1 10 100 Frequency (MHz) 1000 100 10 1 1 10 100 Frequency (MHz) 1000 • All specifications are subject to change without notice. 001-01 / 20130723 / e9a15_zcat.fm
ZCAT2235-1030A 价格&库存
很抱歉,暂时无法提供与“ZCAT2235-1030A”相匹配的价格&库存,您可以联系我们找货
